S15OB381-068
S15OB381-068
    GOERTEK(歌尔)
    ANALOG MEMS MICROPHONE
S15OB381-068 数据手册
Confidential Degree : Confidential Specification of MEMS Microphone (RoHS Compliance & Halogen Free) Customer Name : Customer Model : Goermicro Model : S15OB381-068 Goermicro CUSTOMER APPROVAL DESIGN Zamp.Wang 2021.06.22 CHKD Hubery.Zhang 2021.06.22 STANDARD Angela.Kong 2021.06.22 APVD Jenny.Liu 2021.06.22 Tel : + 86 536 3051234 E- Mail : Goermicro@Goermicro.com Website: http://www.Goermicro.com Address: No.268 Dongfang Road, High-Tech Industry Development District, Weifang, Shandong, P.R.C. Version:3.0 Confidential in Goermicro, shall not be spread if not be privileged. page 1/14 Confidential Degree : Confidential Restricted 1 Security Warning The information contained in this document is the exclusive property of Goermicro Inc. and should not be disclosed to any third party without the written consent of Goermicro Inc. 2 Publication History Version 1.0 2.0 3.0 Version:3.0 Description Date Author New Design 2020.04.02 Aaron Rock 2020.09.02 Lamon Roy 2021.06.22 Zamp Jenny Update Acoustic and Electrical Characteristics Update Acoustic and Electrical Characteristics Confidential in Goermicro, shall not be spread if not be privileged. Approved page 2/14 Confidential Degree : Confidential Contents 1 2 3 4 5 6 7 Introduction Test Condition Acoustic and Electrical Characteristics Frequency Response Curve and Limits Measurement Circuit Test Setup Drawing Mechanical Characteristics 4 4 4 4 5 5 6 7.1 Appearance Drawing 6 7.2 Weight 6 8 Reliability Test 7 8.1 Vibration Test 7 8.2 Drop Test 7 8.3 Temperature Test 7 8.4 Humidity Test 7 8.5 Mechanical Shock Test 7 8.6 Thermal Shock Test 7 8.7 Reflow Test 7 8.8 Electrostatic Discharge Test 9 Package 7 8 9.1 Tape Specification 8 9.2 Reel Dimension 9 9.3 The Content of Box 9 9.4 Packing Explain 10 10 Storage and Transportation 11 Land Pattern Recommendation 10 11 11.1 The Pattern of MIC Pad 11 11.2 Recommended Soldering Surface Land Pattern 11 12 Soldering Recommendation 12 12.1 Soldering Machine Condition 12 12.2 The Drawing and Dimension of Nozzle 12 12.3 Reflow Profile 13 13 Cautions 14 13.1 Board Wash Restrictions 14 13.2 Vacuum Restrictions 14 13.3 Ultrasonic Restrictions 14 13.4 Air Blow Restrictions 14 14 Output Inspection Standard Version:3.0 Confidential in Goermicro, shall not be spread if not be privileged. 14 page 3/14 Confidential Degree : Confidential 1 Introduction: MEMS MIC which is able to endure reflow temperature up to 260℃ for 50 seconds can be used in SMT process. It is widely used in telecommunication and electronics device such as mobile phone, laptop computers, and other portable electronic devices etc. 2 Test Condition (Vs=2.7V, L=50cm) StandardConditions (As IEC 60268-4) Temperature Humidity Air pressure Environment Conditions +15℃~ +35℃ 25%R.H.~75%R.H. 86kPa~106kPa +20℃ ± 2℃ 60%R.H.~70%R.H. 86kPa~106kPa Basic Test Conditions 3 Acoustic and Electrical Characteristics Symbol Item Operating Voltage Range Test Conditions VS Min Typ Max Unit 1.5 2.7 3.6 V 150 μA -37 dBV Current Consumption I Vs=2.7V Sensitivity S f=1kHz, Pin=1Pa S/N Ratio SNR f=1kHz, Pin=1Pa A-Weighted Curve 64 dB Total Harmonic Distortion THD 1%THD@1kHz 116 dB SPL Acoustic Overload Point AOP 10%THD@1kHz 128 dB SPL Phase Response PR Vdd=2.7V,94dBSPL,test , Frequency 100Hz to 10Khz Power Supply Rejection PSR 100mVpp square wave@217Hz, VS=2.7V, A-Weighted -96 dBV Low Frequency Roll-off LFRO -3dB corner refrence to 1kHz sensitivity 10 Hz Power Supply Rejection Ration PSRR 200mVpp sinewave@1k Hz, VS=2.7V 68 dB Output Impedance Decreasing Voltage Characteristic Zout f=1kHz, Pin=1Pa S f=1kHz, Pin=1Pa Vs=3.6 --1.5V -39 -5 ° 5 Ω 400 No Change D(θ) Directivity -38 Omnidirectional Relative Response (dB) 4 Frequency Response Curve and Limits +6 +5 +4 +2 +3 +1.5 +2 +2 +2 +2 +2 +2 +1 0 -2 -2.5 -4 -2 -2 -2 -2 -2 -2 1k 1.1k 3k 6k -1 -6 20 Version:3.0 50 100 200 300 500 8k 10k Frequency (Hz) Confidential in Goermicro, shall not be spread if not be privileged. page 4/14 Confidential Degree : Confidential 5 Measurement Circuit Term.1 (Power) CP VDD + 2.7V Filter Term.2 (Output) Amp OUTPUT C=10μF Term.3 (GND) MEMS Microphone GND 6 Test Setup Drawing Power Amplifier Free-field 1/2" Microphone 50cm Speaker Audio Analyzer MIC Input Output Power&Load Remote Control Turn Table Anechoic Room Version:3.0 Confidential in Goermicro, shall not be spread if not be privileged. page 5/14 Confidential Degree : Confidential 7 Mechanical Characteristics 7.1 Appearance Drawing (Unit: mm) W H 1.600 2X0.650 2X0.545 3 0.875 L 2.51 GWWD YLLL 1.61 R0.25 Ø1.450 AP 0.280 1.205 2 1 0.925 Ø0.950 Identification Number Bottom View Top View Pin# 1 Power 2 Output 3 GND Dimension Item Function Tolerance Units Length(L) 2.75 ±0.10 mm Width(W) 1.85 ±0.10 mm Height(H) Acoustic Port(AP) 0.90 ±0.10 mm Ø0.25 ±0.05 mm Note: 1. Tolerance ±0.1 mm unless otherwise specified. 2. Identification Number Convention: Job Identification Number. Identification Number GWWD Y LLL G : Goermicro W W :Week Y :Year L L L D :Day : Serial Number 2D Code 7.2 Weight The weight of the MIC is Less than 0.02g. Version:3.0 Confidential in Goermicro, shall not be spread if not be privileged. page 6/14 Confidential Degree : Confidential 8 Reliability Test 8.1 Vibration Test To be no interference in operation after vibrations, 4 cycles, from 20 to 2,000Hz in each direction(X,Y,Z), 48 minutes, using peak acceleration of 20g, sensitivity should vary within ±3dB from initial sensitivity(IEC 60068-2-6:2007). (The measurement to be done after 2 hours of condition at 15℃-35℃, R.H. 25%~75%) 8.2 Drop Test To be no interference in operation after dropped to 1.0cm steel plate 12 times from 1.5 meter height in state of JIG,JIG weight of 100g, sensitivity should vary within ±3dB from initial sensitivity(IEC60068-2-31:2008). (The measurement to be done after 2 hours of condition at 15℃-35℃, R.H. 25%~75%) a) After exposure at +125℃ for 200 hours, sensitivity should vary within ±3dB from initial sensitivity(IEC 60068-2-1:2007). (The measurement to be done after 2 hours of condition at 15℃-35℃, R.H. 25%~75%) 8.3 Temperature b) After exposure at -40℃ for 200 hours, sensitivity should vary within ±3dB from initial Test sensitivity(IEC 60068-2-1:2007).   (The measurement to be done after 2 hours of condition at 15℃-35℃, R.H. 25%~75%) 8.4 Humidity Test After exposure at +85℃ and 85% relative humidity for 200 hours, sensitivity should vary within ±3dB from initial sensitivity(IEC 60068-2-67:2019). (The measurement to be done after 2 hours of condition at 15℃-35℃, R.H. 25%~75%) Then subject samples to three one-half sine shock pulses (3000 g for 0.3 milliseconds) in 8.5 each direction (for six axes in total) along each of the three mutually perpendicular axes Mechanical for a total of 18 shocks, sensitivity should vary within ±3dB from initial sensitivity Shock Test (IEC60068-2-27:2008). (The measurement to be done after 2 hours of condition at 15℃-35℃, R.H. 25%~75%) After exposure at -40℃ for 30 minutes, at +125℃ for 30 minutes (change time 20 seconds) 8.6 32 cycles, sensitivity should vary within ±3dB from initial sensitivity(IEC 60068-2-14:2009). Thermal Shock Test (The measurement to be done after 2 hours of condition at 15℃-35℃, R.H. 25%~75%) 8.7 Reflow Test Adopt the reflow curve of item 12.3, after three reflows, sensitivity should vary within ±2dB from initial sensitivity(Refer to customer's request). (The measurement to be done after 2 hours of condition at 15℃-35℃, R.H. 25%~75%) 8.8 Under C=150pF, R=330ohm. Electrostatic Air discharge to case with±8kV and contact discharge to I/O terminals with±2kV , 10 times, Discharge Grounding. Sensitivity should vary within ±3dB from initial sensitivity(IEC61000-4-2:2008). Test Version:3.0 Confidential in Goermicro, shall not be spread if not be privileged. page 7/14 Confidential Degree : Confidential 9 Package 9.1 Tape Specification P0 ØD0 E P2 A B W F A B ØD1 P1 Power Pin 1 B-B A-A T 10° 10° B0 A0 K0 The Dimensions as Follows: ITEM W E F ØD0 ØD1 DIM(mm) 12.0±0.30 1.75±0.10 5.5±0.05 1.50+0.10 0 0.50+0.10 0 ITEM P0 10P0 P1 A0 DIM(mm) 4.00±0.10 40.00±0.20 8.00±0.10 2.95±0.05 ITEM K0 P2 T DIM(mm) 1.10±0.10 2.00±0.05 0.30±0.05 Version:3.0 Confidential in Goermicro, shall not be spread if not be privileged. B0 2.05±0.05 page 8/14 Confidential Degree : Confidential 9.2 Reel Dimension 7'' reel for sample stage 13'' reel will be provided for the mass production stage The following is 13'' reel dimensions (unit:mm) 12.4±0.2 inner side DETAIL "A" A 11 12 1 10 2 9 8 7 65 3 4 1.9±0.4 Ø100±0.5 Ø330(max) Ø21±0.4 Ø13±0.2 120° 9.3 The Content of Box(13'' reel) Packing (5,500PCS) Antistatic Bag (5,500PCS) Two Inner Box(55,000PCS) Version:3.0 5 Antistatic Bags (27,500PCS) Inner Box(27,500PCS) (340mm 135mm 355mm) Outer Box(55,000PCS) (360mm 300mm 388mm) Confidential in Goermicro, shall not be spread if not be privileged. page 9/14 Confidential Degree : Confidential 9.4 Packing Explain 9.4.1 The Label Content of the Reel 11121 10 2 9 87 3 6 54 xx xx x xx xx xxxx x xx x x xx xxx xxx x x xx xxx x xx The Content Includes: Product type, Lot, Customer P/N; and other essential information such as Quantity, Date etc. 9.4.2 The RoHS Label 11121 10 2 9 87 3 6 54 RoHS Compliance& Halogen Free Mark RoHS 10 Storage and Transportation 10.1 Keep MEMS MIC in warehouse with less than 75% humidity and without sudden temperature change, acid air, any other harmful air or strong magnetic field. Recommend storage period no more than 1 year and floor life(out of bag) at factory no more than 4 weeks. 10.2 The MEMS MIC with normal pack can be transported by ordinary conveyances. Please protect products against moist, shock, sunburn and pressure during transportation. 10.3 Storage Temperature Range:-40℃~+70℃(Microphone units with package) 10.4 Operating Temperature Range:-40℃~+100℃ Note1: MSL(moisture sensitivity level) Class 1(IPC/JEDEC-J-STD-020 Revision C) Note2: Static sensitive device Version:3.0 Confidential in Goermicro, shall not be spread if not be privileged. page 10/14 Confidential Degree : Confidential 11 Land Pattern Recommendation 11.1 The Pattern of MIC Pad(Unit:mm) 2-0.65 1.6 0.875 1.205 Ø0.25 2-0.545 Ø1.45 Ø0.95 0.925 11.2 Recommended Soldering Surface Land Pattern(Unit:mm) 0.1 1.6 2-0.545 1.205 2-0.65 Ø1.45 Ø0.95 Version:3.0 Confidential in Goermicro, shall not be spread if not be privileged. page 11/14 Confidential Degree : Confidential 12 Soldering Recommendation 12.1 Soldering Machine Condition 8 zones Temperature Control Heater Type Hot Air Solder Type Lead-free 12.2 The Drawing and Dimension of Nozzle Inside Diameter: Ø1.0mm; Please don't vacuum over the acoustic port directly. Please don't blow the acoustic port directly. 0.25(Typ) 2.75 1.85 Pick Area 0.25(Typ) Ø1.0 Version:3.0 Confidential in Goermicro, shall not be spread if not be privileged. page 12/14 Confidential Degree : Confidential 12.3 Reflow Profile Temp. °C Tp Max. Ramp-up rate = 3℃/s Max. Ramp-down rate = 6℃/s TL tp tL Tsmax Preheat area Tsmin ts 25 time 25℃ to peak Time. sec Key Features of The Profile: Average Ramp-up rate(Tsmax to Tp) 3℃/s max. Preheat : Temperature Min(Tsmin) Temperature Max(Tsmax) Time(Tsmin to Tsmax)(ts) 150℃ 200℃ 60~180s Time maintained above : Tempreature(TL) Time(tL) 217℃ 60~150s Peak Temperature(Tp) 260℃ Time within 5℃ of actual Peak Temperature(tp) : 30~40s Ramp-down rate(Tp to Tsmax) 6℃/s max Time 25℃ to Peak Temperature 8min max When MEMS MIC is soldered on PCB, the reflow profile is set according to solder paste and the thickness of PCB etc. Version:3.0 Confidential in Goermicro, shall not be spread if not be privileged. page 13/14 Confidential Degree : Confidential 13 Cautions 13.1 Board Wash Restrictions It is very important not to board wash the PCBA after reflow process, otherwise this could damage the microphone. 13.2 Vacuum Restrictions It is very important not to put a vacuum over the acoustic port of the microphone. otherwise this could damage the microphone. 13.3 Ultrasonic Restrictions It is very important not to use ultrasonic process. otherwise this could damage the microphone. 13.4 Air Blow Restrictions It is very important not tnot o use air gun near the port hloe of the microphone, otherwise this could damage the microphone. 14 Output Inspection Standard Output inspection standard is executed according to . Version:3.0 Confidential in Goermicro, shall not be spread if not be privileged. page 14/14
S15OB381-068 价格&库存
很抱歉,暂时无法提供与“S15OB381-068”相匹配的价格&库存,您可以联系我们找货
