SD18OB371-077
SD18OB371-077
    GOERTEK(歌尔)
    100 Hz ~ 8 kHz 麦克风 MEMS(硅) 1.62 V ~ 3.6 V 全向 (-37dB ±1dB @ 94dB SPL) 焊盘
SD18OB371-077 数据手册
Confidential Degree:Confidential Specification of SMD Digital Microphone (RoHS Compliance & Halogen Free) Customer Name : Customer Model : Goermicro Model : SD18OB371-077 10644 ISO/TS16949:2009 013 013 2551 2728 ISO14001:2004 ISO9001:2008 Version:5.0 Tel : + 86 536 3051234 E- Mail : goermicro@goermicro.com Website: http://www.goermicro.com Address: No.268 Dongfang Road, High-Tech Industry Development District, Weifang, Shandong, P.R.C. Confidential in Goermicro, shall not be spread if not be privileged page 1/17 Confidential Degree:Confidential Restricted 1 Security Warning The information contained in this document is the exclusive property of Goermicro Inc. and should not be disclosed to any third party without the written consent of Goermicro Inc. 2 Publication History Version Description Date Author Approved 1.0 New Design 2019.07.29 Hubery Sunny 2.0 Update the interface information in 3.4 & Note3 2019.11.19 Update acoustic port protection in 12.3 Hubery Sunny 3.0 Add low power mode characteristics @1.024MHz in 3.2 Update Clock Rise/Fall Time in 3.4 2020.07.02 Zamp Sunny 4.0 Update Document Template, Update THD Performance 2021.06.08 Zamp Jenny 5.0 Update the Logo to Goermicro 2021.08.25 Enoch Roy Version:5.0 Confidential in Goermicro, shall not be spread if not be privileged page 2/17 Confidential Degree:Confidential Contents 1 Introduction 2 Test Condition 3 Acoustic and Electrical Characteristics 3.1 Standard Mode 4 4 4 4 3.2 Low Power Mode 4 3.3 Frequency Response Curve and Limits 5 3.4 Microphone Interface Specifications 6 3.5 Genal Microphone Specifications 4 Measurement Circuit 5 Test Setup Drawing 6 Mechanical Characteristics 6.1 Appearance Drawing 6 8 8 9 9 9 6.2 Weight 7 Reliability Test 10 7.1 Vibration Test 10 7.2 Drop Test 10 7.3 Temperature Test 10 7.4 Humidity Test 10 7.5 Mechanical Shock Test 10 7.6 Thermal Shock Test 10 7.7 Reflow Test 10 7.8 Electrostatic Discharge Test 10 8 Package 11 8.1 Tape Specification 11 8.2 Reel Dimension 12 8.3 The Content of Box 12 8.4 Packing Explain 13 9 Storage and Transportation 13 10 Land Pattern Recommendation 14 10.1 Recommended Land Pattern 14 10.2 Recommended Solder Stencil Pattern 14 11 Soldering Recommendation 15 11.1 Soldering Machine Condition 15 11.2 The Drawing and Dimension of Nozzle 15 11.3 Reflow Profile 16 12 Cautions 17 12.1 Board Wash Restrictions 17 12.2 Ultrasonic Restrictions 17 12.3 Acoustic Port Protection 17 13 Output Inspection Standard Version:5.0 Confidential in Goermicro, shall not be spread if not be privileged 17 page 3/17 Confidential Degree:Confidential 1 Introduction MEMS MIC which is able to endure reflow temperature up to 260℃ for 50 seconds can be used in SMT process. It is widely used in telecommunication and electronics device such as mobile phone, laptop computers, and other portable electronic devices etc. 2 Test Condition (VDD=1.8V, fCLK=2.4MHz/768kHz/1.024MHz, L=50 cm) StandardConditions (As IEC 60268-4) Air pressure Humidity Temperature Environment Conditions +15℃~+35℃ 25%RH~75%RH 86kPa~106kPa Basic Test Conditions +20℃±2℃ 60%RH~70%RH 86kPa~106kPa 3 Acoustic and Electrical Characteristics 3.1 Standard Mode (Test Condition:VDD=1.8V, fCLK=2.4MHz,Decimation=64X) Item Symbol Sensitivity S Current Consumption I (Note 2) Test Conditions 94dBSPL@1kHz Min Typ Max Unit dBFS -38 -37 -36 (Note 1) - 800 1000 μA fCLK=2.4MHz S/N Ratio SNR 94dBSPL@1kHz A-Weighting - 66 - dB Distortion THD 1%THD@1kHz - 127 - dB SPL Acoustic Overload Point AOP 10% THD@1kHz,S=Typ - 132 - dB SPL Power Supply Rejection PSR 100mVpp Squarewave @217Hz A-weighting - -101 - dBFS Low Frequency Roll-off LFRO -3dB corner refrence to 1kHz sensitivity 25 35 45 Hz Min Typ Max Unit -21 -20 dBFS (Note 1) - - 300 μA - dB 3.2 Low Power Mode (Test Condition:VDD=1.8V, fCLK=768kHz,Decimation=64X) Item Symbol Sensitivity Current Consumption (Note 2) Test Conditions S 94dBSPL@1kHz I fCLK=768kHz -22 S/N Ratio SNR 94dBSPL@1kHz A-Weighting - 66 Distortion THD 1%THD@1kHz - 112 Acoustic Overload Point AOP 10% THD@1kHz,S=Typ - 117 - dB SPL Power Supply Rejection PSR 100mVpp Squarewave @217Hz A-weighting - -83 - dBFS Version:5.0 Confidential in Goermicro, shall not be spread if not be privileged dB SPL page 4/17 Confidential Degree:Confidential (Test Condition:VDD=1.8V, fCLK=1.024MHz,Decimation=64X) Item Test Conditions Min Typ Max S 94dBSPL@1kHz -22 -21 -20 (Note 1) I fCLK=1.024MHz - - 350 μA Symbol Sensitivity Current Consumption (Note 2) Unit dBFS S/N Ratio SNR 94dBSPL@1kHz A-Weighting - 66 - dB Distortion THD 1%THD@1kHz - 112 dB SPL Acoustic Overload Point AOP 10% THD@1kHz,S=Typ - 117 - dB SPL Power Supply Rejection PSR 100mVpp Squarewave @217Hz A-weighting - -83 - dBFS 3.3 Frequency Response Curve and Limits Typical Free Field Response Normalized to 1kHz Standard Mode VDD=1.8V, fCLK =2.4MHz, Decimation Rate=64x Relative Response (dB) +15 +10 +5 +3 +3 +3 +3 -3 -3 -3 -3 0 -5 -10 -15 -20 100 300 500 900 1k 1.1k 3k Frequency (Hz) 5k 8k 10k 20k Typical Free Field Response Normalized to 1kHz Low Power Mode VDD=1.8V, fCLK =768kHz, Decimation Rate=64x Relative Response (dB) +15 +10 +5 +3 +3 +3 -3 -3 +3 0 -5 -3 -3 -10 -15 -20 100 Version:5.0 200 300 500 1k 1.1k Frequency (Hz) Confidential in Goermicro, shall not be spread if not be privileged 3k 5k 8k page 5/17 Confidential Degree:Confidential 3.4 Microphone Interface Specifications Typ Max Unit 0.65XVDD - VDD+0.3 V VIL -0.3 - 0.3XVDD V Output Logic High Level VOH 0.65XVDD - VDD+0.3 V Output Logic Low Level VOL -0.3 - 0.3XVDD V 40 - 60 % 250 nS 50 nS Item Symbol Input Logic High Level VIH Input Logic Low Level Test Conditions Clock Duty Cycle Min Clock Low Power Mode Rise/Fall Standard Mode Time tRF Delay Time for Data Driven, VDD = 1.8V tDD Delay time from CLOCK edge to DATA driven. 18 - 50 nS Delay Time for Data High-Z, VDD = 1.8V tHZ Delay time from CLOCK edge to DATA high impedance state. 5 - 16 nS tDV Delay time from CLOCK edge to DATA valid (0.70 x VDD) - - 100 nS Min Typ Max Unit 1.62 - 3.6 V 0 - 150 kHz 0.25 0.768 1.2 MHz 1.45 - 4.8 MHz Delay Time for Data Valid 3.5 General Microphone Specifications Item Symbol Supply Voltage Test Conditions VDD Standby Mode Clock Frequency Low Power Mode Range Standard Mode Omni-directional Directivity Increasing density of 1's Increasing Sound Polarity Data Format Short Circuit Current Output Load Capacitance on DATA Start-up Time Restart Time Mode-Switch Time Version:5.0 ½ Cycle PDM 1bit Grounded Data Pin Cload Time to start up in either modes (Low Power- and Normal Mode) after VDD and CLOCK have been applied. Time to start up in either modes (Low Power- and Normal Mode) after VDD has been off for more than 10ms, while CLOCK remained on. Time to switch between modes (Clock off- Low Power-, and Normal Mode). VDD remains on during the mode switch. - - 20 mA - - 140 pF - - 50 ms - - 50 ms - - 50 ms Confidential in Goermicro, shall not be spread if not be privileged page 6/17 Confidential Degree:Confidential Note 1. dBFS = 20xlog (A/B) where A is the level of the signal, B is the level that corresponds to Full-scale level. Note 2. The current consumption depends on the applied Clock Frequency and the load on the DATA output. Note 3. Timing tEDGE VIH MIN CLOCK VIL MAX DATA 1 L/R=GND DATA 1 VALID tHZ tDV tDD HIGH Z DATA 1 VALID tDD DATA 2 L/R=VDD Version:5.0 HIGH Z DATA 2 VALID HIGH Z HIGH Z tDV DATA 2 VALID DATA 1 VALID tHZ HIGH Z Confidential in Goermicro, shall not be spread if not be privileged page 7/17 Confidential Degree:Confidential 4 Measurement Circuit Term.5 VDD + Term.2 L/R Amp ΣΔ Modulator Term.1 DATA Select Term.4 CLK Charge Pump 1μF ASIC Term.3 GND MEMS MIC 5 Test Setup Drawing Power Amplifier Free-field 1/2" Microphone AP525 50cm Speaker MIC Input Output Remote Control PDM Line Driver Turn Table Anechoic Room Version:5.0 Confidential in Goermicro, shall not be spread if not be privileged page 8/17 Confidential Degree:Confidential 6 Mechanical Characteristics 6.1 Appearance Drawing (Unit: mm) W H Mark 0.125 4*0.725 4*0.522 0.950 L 1.040 1.513 G W W D Y L L L AP R0.28 5 1 4 2 0.300 Ø1.025 3 Ø1.625 1.325 Identification Number Side View Top View Pin Output 1 2 DATA L/R 3 4 GND CLK 5 VDD Bottom View ITEM Function Pin# AP DIMENSION TOLERANCE UNTIS LENGTH(L) 3.50 ±0.10 mm WIDTH(W) 2.65 ±0.10 mm HEIGHT(H) 0.98 ±0.10 mm ACOUSTIC PORT(AP) Ø0.325 ±0.05 mm Note: 1. Tolerance ±0.1 unless otherwise specified. 2. Identification Number Convention: Job Identification Number. Identification Number GWWD Y LLL G : Goermicro W W :Week Y :Year L L L D :Day : Serial Number 2D Code 6.2 Weight The weight of the MIC is Less than 0.05g. Version:5.0 Confidential in Goermicro, shall not be spread if not be privileged page 9/17 Confidential Degree:Confidential 7 Reliability Test 7.1 Vibration Test 7.2 Drop Test To be no interference in operation after vibrations, 4 cycles, from 20 to 2,000Hz in each direction(X,Y,Z), 48 minutes, using peak acceleration of 20g, sensitivity should vary within ±3dBFS from initial sensitivity. (The measurement to be done after 2 hours of condition at 15℃-35℃, R.H. 25%~75%) To be no interference in operation after dropped to 1.0cm steel plate 12 times from 1.5 meter height in state of JIG,JIG weight of 100g, sensitivity should vary within ±3dBFS from initial sensitivity. (The measurement to be done after 2 hours of condition at 15℃-35℃, R.H. 25%~75%) a) After exposure at +125℃ for 200 hours, sensitivity should vary within ±3dBFS from initial sensitivity. (The measurement to be done after 2 hours of condition at 15℃-35℃, R.H. 25%~75%) 7.3 Temperature b) After exposure at -40℃ for 200 hours, sensitivity should vary within ±3dBFS from initial Test sensitivity.   (The measurement to be done after 2 hours of condition at 15℃-35℃, R.H. 25%~75%) 7.4 Humidity Test After exposure at +85℃ and 85% relative humidity for 200 hours, sensitivity should vary within ±3dBFS from initial sensitivity. (The measurement to be done after 2 hours of condition at 15℃-35℃, R.H. 25%~75%) Then subject samples to three one-half sine shock pulses (3000 g for 0.3 milliseconds) in 7.5 each direction (for six axes in total) along each of the three mutually perpendicular axes Mechanical for a total of 18 shocks, sensitivity should vary within ±3dBFS from initial sensitivity. Shock Test (The measurement to be done after 2 hours of condition at 15℃-35℃, R.H. 25%~75%) After exposure at -40℃ for 30 minutes, at +125℃ for 30 minutes (change time 20 seconds) 7.6 32 cycles, sensitivity should vary within ±3dBFS from initial sensitivity. Thermal (The measurement to be done after 2 hours of condition at 15℃-35℃, R.H. 25%~75%) Shock Test 7.7 Reflow Test Adopt the reflow curve of item 12.3, after three reflows, sensitivity should vary within ±2dBFS from initial sensitivity. (The measurement to be done after 2 hours of condition at 15℃-35℃, R.H. 25%~75%) 7.8 Under C=150pF, R=330ohm. Electrostatic Air discharge to case with±8kV and contact discharge to I/O terminals with±2kV , 10 times, Discharge Grounding. Sensitivity should vary within ±3dBFS from initial sensitivity. Test Version:5.0 Confidential in Goermicro, shall not be spread if not be privileged page 10/17 Confidential Degree:Confidential 8 Package 8.1 Tape Specification P0 ØD0 E P2 A W F A B G W W D Y L L L B P1 Pin 1# (DATA) ØD1 B-B A-A T 10° 10° B0 A0 K0 The Dimensions as Follows: ITEM W E F ØD0 K0 DIM(mm) 12.0±0.30 1.75±0.10 5.5±0.05 1.50+0.10 0 1.30±0.10 ITEM P0 10P0 P1 A0 B0 DIM(mm) 4.00±0.10 40.00±0.20 8.00±0.10 2.85±0.05 3.75±0.05 ITEM P2 T DIM(mm) 2.00±0.05 0.30±0.05 Version:5.0 Confidential in Goermicro, shall not be spread if not be privileged page 11/17 Confidential Degree:Confidential 8.2 Reel Dimension 7'' reel for sample stage 13'' reel will be provided for the mass production stage The following is 13'' reel dimensions (unit:mm) 12.4±0.2 inner side DETAIL A A 1.9±0.4 Ø100±0.5 Ø330(max) Ø21±0.4 Ø13±0.2 120° 8.3 The Content of Box(13'' reel) Packing (5,000PCS) Antistatic Bag (5,000PCS) Two Inner Box(50,000PCS) Version:5.0 5 Antistatic Bags (25,000PCS) Inner Box(25,000PCS) (340mm 135mm 355mm) Outer Box(50,000PCS) (370mm 300mm 390mm) Confidential in Goermicro, shall not be spread if not be privileged page 12/17 Confidential Degree:Confidential 8.4 Packing Explain 8.4.1 The Label Content of the Reel xx xx x xx xx xxxx x xx x x xx xxx xxx x x xx xxx x xx The Content Includes: Product type, Lot, Customer P/N; and other essential information such as Quantity, Date etc. 8.4.2 The RoHS Label RoHS RoHS HF Compliance Mark 9 Storage and Transportation 9.1 Keep MEMS MIC in warehouse with less than 75% humidity and without sudden temperature change, acid air, any other harmful air or strong magnetic field. Recommend storage period no more than 1 year and floor life(out of bag) at factory no more than 4 weeks. 9.2 The MEMS MIC with normal pack can be transported by ordinary conveyances. Please protect products against moist, shock, sunburn and pressure during transportation. 9.3 Storage Temperature Range:-40℃~+70℃ 9.4 Operating Temperature Range:-40℃~+70℃ Version:5.0 Confidential in Goermicro, shall not be spread if not be privileged page 13/17 Confidential Degree:Confidential 10 Land Pattern Recommendation 10.1 Recommended Land Pattern(Unit:mm) 4-0.725 4-0.522 0.950 1.51 0.300 Ø1.025 Ø1.625 10.2 Recommended Solder Stencil Pattern(Unit:mm) 4-0.725 1.513 4-0.522 4-0.200 Version:5.0 0.950 0.300 Ø1.025 Ø1.625 Confidential in Goermicro, shall not be spread if not be privileged page 14/17 Confidential Degree:Confidential 11 Soldering Recommendation 11.1 Soldering Machine Condition 8 zones Temperature Control Heater Type Hot Air Solder Type Lead-free 11.2 The Drawing and Dimension of Nozzle Inside Diameter: Ø1.0mm; Acoustic Port:Ø0.325mm; Vacuum Degree of Nozzle:-80k~-90kPa; Please don't vacuum over the acoustic port directly. Please don't blow the acoustic port directly. 0.500(Typ) 0.500(Typ) PICK AREA Ø1.0 Version:5.0 Confidential in Goermicro, shall not be spread if not be privileged page 15/17 Confidential Degree:Confidential 11.3 Reflow Profile Temp. °C Tp Max. Ramp-up rate = 3°C/s Max. Ramp-down rate = 6°C/s TL tp tL Tsmax Preheat area Tsmin ts 25 time 25°C to peak Time. sec Key Features of The Profile: Average Ramp-up rate(Tsmax to Tp) 3°C/s max. Preheat : Temperature Min(Tsmin) Temperature Max(Tsmax) Time(Tsmin to Tsmax)(ts) 150°C 200°C 60~180s Time maintained above : Tempreature(TL) Time(tL) 217°C 60~150s Peak Temperature(Tp) 260°C Time within 5°C of actual Peak Temperature(tp) : 30~40s Ramp-down rate(Tp to Tsmax) 6°C/s max Time 25°C to Peak Temperature 8min max When MEMS MIC is soldered on PCB, the reflow profile is set according to solder paste and the thickness of PCB etc. Version:5.0 Confidential in Goermicro, shall not be spread if not be privileged page 16/17 Confidential Degree:Confidential 12 Cautions 12.1 Board Wash Restrictions It is very important not to wash this microphone, otherwise this could damage the microphone. 12.2 Ultrasonic Restrictions It is very important not to use ultrasonic process. otherwise this could damage the microphone. 12.3 Acoustic Port Protection It is very important not to operate vacuum and air blow into acoustic port(without any covering over acoustic port), otherwise this could damage the microphone. And it is necessary to be careful about foreign substances into acoustic port .Please add protection material (e.g. PET ) on the acoustic hole to protect it after SMT , refer to below pictures, take it away before test, then attach it again until the end of assembly. It is very important to keep the distance between MIC and cutting area as far as possible to avoid the cutting stive entering into MEMS, otherwise this could contaminate the microphone. Protection Material PCBA Solder MIC Acoustic Hole 13 Output Inspection Standard Output inspection standard is executed according to . Version:5.0 Confidential in Goermicro, shall not be spread if not be privileged page 17/17
SD18OB371-077 价格&库存
很抱歉,暂时无法提供与“SD18OB371-077”相匹配的价格&库存,您可以联系我们找货
