SD33OT261-003
SD33OT261-003
    GOERTEK(歌尔)
    100 Hz ~ 8 kHz 麦克风 MEMS(硅) 1.62 V ~ 3.6 V 全向 (-26dB ±1dB @ 94dB SPL) 焊盘
SD33OT261-003 数据手册
Confidential Degree : Confidential Specification of MEMS Microphone (RoHS Compliance & Halogen Free) Customer Name : Customer Model : Goermicro Model: SD33OT261-003 Goermicro CUSTOMER APPROVAL DESIGN Aaron.Xie 2021.06.30 CHKD Samual.Wang 2021.06.30 STANDARD Angela.Kong 2021.06.30 APVD Roy.Wang 2021.06.30 Tel : + 86 536 3051234 E- Mail : goermicro@goermicro.com Website: http://www.goermicro.com Address: No.268 Dongfang Road, High-Tech Industry Development District, Weifang, Shandong, P.R.C. Version:3.0 Confidential in Goermicro, shall not be spread if not be privileged. page 1/16 Confidential Degree : Confidential Restricted 1 Security Warning The information contained in this document is the exclusive property of Goermicro Inc. and should not be disclosed to any third party without the written consent of Goermicro Inc. 2 Publication History Version Description Date Author Approved 1.0 New Design 2021.01.29 Ford Roy 2.0 Change package method 2021.04.11 Aaron Roy 3.0 Change General Microphone Specifications 2021.06.30 Aaron Roy Version:3.0 Confidential in Goermicro, shall not be spread if not be privileged. page 2/16 Confidential Degree : Confidential Contents 1 Introduction 2 Test Condition 3 Acoustical and Electrical Characteristics 4 4 4 3.1 Standard Performance Mode 4 3.2 Frequency Response Curve and Limits 4 3.3 Low Power Mode 5 3.4 General Microphone Specification 5 3.5 Micronphone Interface Specifications 6 4 Measurement Circuit 5 Test Setup Drawing 6 Mechanical Characteristics 7 7 8 6.1 Appearance Drawing 8 6.2 Weight 8 7 Reliability Test 9 7.1 Vibration Test 9 7.2 Drop Test 9 7.3 Temperature Test 9 7.4 Humidity Test 9 7.5 Mechanical Shock Test 9 7.6 Thermal Shock Test 9 7.7 Reflow Test 9 7.8 ESD Shock Test 9 8 Package 10 8.1 Tape Specification 10 8.2 Reel Dimension 11 8.3 The Content of Box 11 8.4 Packing Explain 12 9 Storage and Transportation 10 Land Pattern Recommendation 12 13 10.1 The Pattern of MIC Pad 13 10.2 Recommended Soldering Surface Land Pattern 13 11 Soldering Recommendation 14 11.1 Soldering Machine Condition 14 11.2 The Drawing and Dimension of Nozzle 14 11.3 Reflow Profile 15 16 12 Cautions When Using MEMS MIC 12.1 Board Wash Restrictions 16 12.2 Sound Hole Productions 16 12.3 Wire Width Adaption 16 12.4 Ultrasonic Restrictions 16 13 Output Inspection Standard 16 Version:3.0 Confidential in Goermicro, shall not be spread if not be privileged. page 3/16 Confidential Degree : Confidential 1 Introduction: MEMS MIC which is able to endure reflow temperature up to 260℃ for 50 seconds can be used in SMT process. It is widely used in telecommunication and electronics device such as mobile phone, laptop computers, and other portable electronic devices etc. 2 Test Condition (L=50 cm) StandardConditions (As IEC 60268-4) Air pressure Humidity Temperature Environment Conditions +15℃~+35℃ 25%RH~75%RH 86kPa~106kPa Basic Test Conditions +20℃±2℃ 60%RH~70%RH 86kPa~106kPa 3 Acoustical and Electrical Characteristics 3.1 Standard Performance Mode (Test Condition: VDD=1.8V, fCLK =2.4MHz) Symbol Test Conditions Min Typ Max Unit Sensitivity S f=1kHz, Pin=1Pa -27 -26 -25 dBFS (Note 1) Current Consumption (Note 2) I fclk=2.4MHz - 750 - μA S/N Ratio SNR f=1kHz, Pin=1Pa A-Weighted Curve - 64 - dB Distortion THD 94dB SPL@ 1kHz - 0.2 0.5 Acoustic Overload Point AOP 10% THD @1 kHz - 118 - dB SPL Power Supply Rejection PSR 100mVpp squarewave@217Hz - -80 - dBFS Power Supply Rejection Ratio PSRR - 60 - dBFS Item 100mVpp squarewave@217Hz % Relative Response (dB) 3.2 Frequency Response Curve and Limits +10 +5 +7 +3 +3 +3 +3 +3 +3 +1 0 -5 -10 -3 50 -3 100 200 -3 500 -3 -3 -3 1K 3K 5K 8K 10K Frequency (Hz) Version:3.0 Confidential in Goermicro, shall not be spread if not be privileged. page 4/16 Confidential Degree : Confidential 3.3 Low Power Mode (Test Condition: VDD=1.8V, fCLK =768kHz) Item Sensitivity Current Consumption (Note 2) Symbol Test Conditions Min Typ Max Unit S f=1kHz, Pin=1Pa -27 -26 -25 dBFS (Note 1) I fclk=768kHz - 300 - μA S/N Ratio SNR f=1kHz, Pin=1Pa A-Weighted Curve - 64 - dB Distortion THD 94dB SPL@ 1kHz - 0.2 0.5 % Acoustic Overload Point AOP 10% THD @1 kHz - 118 - dB SPL Power Supply Rejection PSR 100mVpp squarewave@217Hz - -85 - dBFS Power Supply Rejection Ratio PSRR - 60 - dBFS 200mVpp sinewave@1KHz long term percent of full scale DC offset % 0 3.4 General Microphone Specifications Test Condition: VDD=1.8V,fCLK =2.4MHz, select pin grounded,no load. Symbol Item Test Conditions VDD Supply Voltage 1.62 Standby Mode Clock Frequency Lower Power Mode Range Normal Mode Typ Max Unit 1.8 3.6 V 250 kHz 0 Isleep Sleep Current Min 350 - 800 kHz 1.0 - 4.8 MHz Fclk=0Hz,VDD=1.8V - 3 - μA Fclk=0Hz,VDD=3.6V - 6 - μA Directivity Omnidirectional Increasing density of 1's Increasing sound pressure Polarity Data Format 1/2 cycle PDM Short Output Current ISC Output Load Cload Data Pin short to GND Fclk <250KHz 1 - 20 mA - - 140 pF - 5 - us Fall Asleep Time Tslp Wake-up Time Twk ±0.5dB sensitivity accuracy - - 20 ms Power-up Time Tup ±0.5dB sensitivity accuracy - - 20 ms Mode-Change Time Tmc ±0.5dB sensitivity accuracy - - 20 ms - 0 - %FS DC Output Version:3.0 Confidential in Goermicro, shall not be spread if not be privileged. page 5/16 Confidential Degree : Confidential 3.5 Microphone Interface Specifications Typ Max Unit 0.65 VDD - VDD+0.3 V V IL -0.3 - 0.35 VDD V Logic Output High VOH VDD-0.45 - - V Logic Output Low VOL - - 0.45 V 40 - 60 % Item Symbol Logic Input High V IH Logic Input Low Min Test Conditions Clock Duty Cycle Note 1. dBFS = 20xlog (A/B) where A is the level of the signal, B is the level that corrsponds to Full-scale level. Note 2. The current consumption depends on the applied Clock Frequency and the load on the DATA output. 1/F CLK Note 3. Timing VIH TR TF CLOCK VIL TDZ TDV DATA1 SEL=GND VOH High Z VOL TDZ TDV DATA2 SEL=VDD Symbol Item High Z VOH VOL Test Conditions Min Typ Max Unit Clock Rising Time TR RL=1MΩ,CL=12pF - - 15 ns Clock Falling Time TF RL=1MΩ,CL=12pF - - 15 ns Data into Hi Z time TDZ RL=1MΩ,CL=12pF 0 - 20 ns DataValid time TDV RL=1MΩ,CL=12pF 24 36 48 ns 0.5 ns Clock Jitter Period jitter in RMS Clock Duty Cycle 40 - 60 % Clock Frequency 350 2400 4800 KHz Version:3.0 Confidential in Goermicro, shall not be spread if not be privileged. page 6/16 Confidential Degree : Confidential 4 Measurement Circuit Term.1 Vdd + Term.6 L/R Vreg Amp ΣΔ Modulator Term.3 Data Select Term.4 CLK Charge Pump Term.2,5 GND ASIC MEMS MIC 5 Test Setup Drawing Power Amplifier Free-field 1/2" Microphone Audio Analyzer 50cm Speaker MIC Input Output Remote Control PDM Line Driver Turn Table Anechoic Room Version:3.0 Confidential in Goermicro, shall not be spread if not be privileged. page 7/16 Confidential Degree : Confidential 6 Mechanical Characteristics 6.1 Appearance Drawing (Unit: mm) H 0.792 1.8 0.6 0.57 1 5-0.638*0.57 GWWD YLLL L AP 3 4 2 5 1 6 0.638 0.3 0.3 R0.319 0.57 W Top View Pin# Bottom View Side View Function ITEM DIMENSION TOLERANCE UNITS Length(L) 4.00 ±0.10 mm Width(W) 2.00 ±0.10 mm 1 VDD 2/5 GND Height(H) 1.10 ±0.10 mm 3 Data ACOUSTIC PORT(AP) Ø0.65 ±0.05 mm 4 CLK 6 L/R Note: 1. Tolerance ±0.10mm unless otherwise specified. 2. Identification Number Convention: Job Identification Number. Identification G W W D Number Y LLL G : Goermicro W W :Week Y :Year L L L D :Day 2D Code : Lot Number 6.2 Weight The weight of the MIC is Less than 0.05g. Version:3.0 Confidential in Goermicro, shall not be spread if not be privileged. page 8/16 Confidential Degree : Confidential 7 Reliability Test 7.1 Vibration Test 7.2 Drop Test To be no interference in operation after vibrations, 4 cycles, from 20 to 2,000Hz in each direction(X,Y,Z), 48 minutes, using peak acceleration of 20g, sensitivity should vary within ±3dBFS from initial sensitivity(IEC 60068-2-6:2007). (The measurement to be done after 2 hours of condition at 15℃-35℃, R.H. 25%~75%) To be no interference in operation after dropped to 1.0cm steel plate 12 times from 1.5 meter height in state of JIG,JIG weight of 100g, sensitivity should vary within ±3dBFS from initial sensitivity(IEC60068-2-31:2008). (The measurement to be done after 2 hours of condition at 15℃-35℃, R.H. 25%~75%) a) After exposure at +125℃ for 200 hours, sensitivity should vary within ±3dBFS from initial sensitivity(IEC 60068-2-1:2007). (The measurement to be done after 2 hours of condition at 15℃-35℃, R.H. 25%~75%) 7.3 Temperature b) After exposure at -40℃ for 200 hours, sensitivity should vary within ±3dBFS from initial Test sensitivity(IEC 60068-2-1:2007).   (The measurement to be done after 2 hours of condition at 15℃-35℃, R.H. 25%~75%) 7.4 Humidity Test After exposure at +85℃ and 85% relative humidity for 200 hours, sensitivity should vary within ±3dBFS from initial sensitivity(IEC 60068-2-67:2019). (The measurement to be done after 2 hours of condition at 15℃-35℃, R.H. 25%~75%) Then subject samples to three one-half sine shock pulses (3000 g for 0.3 milliseconds) in 7.5 each direction (for six axes in total) along each of the three mutually perpendicular axes Mechanical for a total of 18 shocks, sensitivity should vary within ±3dBFS from initial sensitivity Shock Test (IEC60068-2-27:2008). (The measurement to be done after 2 hours of condition at 15℃-35℃, R.H. 25%~75%) After exposure at -40℃ for 30 minutes, at +125℃ for 30 minutes (change time 20 seconds) 7.6 32 cycles, sensitivity should vary within ±3dBFS from initial sensitivity(IEC 60068-2-14:2009). Thermal Shock Test (The measurement to be done after 2 hours of condition at 15℃-35℃, R.H. 25%~75%) 7.7 Reflow Test Adopt the reflow curve of item 12.3, after three reflows, sensitivity should vary within ±2dBFS from initial sensitivity(Refer to customer's request). (The measurement to be done after 2 hours of condition at 15℃-35℃, R.H. 25%~75%) 7.8 Under C=150pF, R=330ohm. Electrostatic Air discharge to case with±8kV and contact discharge to I/O terminals with±2kV , 10 times, Discharge Grounding. Sensitivity should vary within ±3dBFS from initial sensitivity (IEC61000-4-2:2008). Test Version:3.0 Confidential in Goermicro, shall not be spread if not be privileged. page 9/16 Confidential Degree : Confidential 8 Package 8.1 Tape Specification P2 D0 E P0 B A GWWD YLLL GWWD YLLL F W A GWWD YLLL B C P1 Pin 1# (Vdd) A-A B-B T 10° B0 10° A0 K0 The Dimensions as Follows: W E F ∅D0 P2 P0 10P0 P1 A0 B0 ITEM K0 T DIM(mm) 1.35±0.10 ITEM DIM(mm) ITEM DIM(mm) Version:3.0 Confidential in Goermicro, shall not be spread if not be privileged. page 10/16 Confidential Degree : Confidential 8.2 Reel Dimension 7'' reel for sample stage 13'' reel will be provided for the mass production stage The following is 13'' reel dimensions (unit:mm) DETAIL "A" 12.4±0.2 inner side A 1.9±0.4 Ø21±0.4 11 12 1 10 2 7 65 3 4 Ø13±0.2 Ø330(max) 9 8 Ø100±0.5 120° 8.3 The Content of Box(13'' reel) 11121 10 2 9 87 3 6 54 Packing Bag Packing (10,000PCS) Two Inner Box(100,000PCS) Version:3.0 Inner Box(50000PCS) (340mm 135mm 355mm) (50,000PCS) Outer Box(100,000PCS) (370mm 300mm 390mm) Confidential in Goermicro, shall not be spread if not be privileged. page 11/16 Confidential Degree : Confidential 8.4 Packing Explain 8.4.1 The Label Content of the Reel 11121 10 2 9 87 3 6 54 xx xx x xx xx xxxx x xx x x xx xxx xxx x x xx xxx x xx The Content Includes: Product type, Lot, Customer P/N; and other essential information such as Quantity, Date etc. 8.4.2 The RoHS Label 11121 10 2 9 87 3 6 54 RoHS RoHS Compliance& Halogen Free Mark 9 Storage and Transportation 9.1 Keep MEMS MIC in warehouse with less than 75% humidity and without sudden temperature change, acid air, any other harmful air or strong magnetic field. Recommend storage period no more than 1 year and floor life(out of bag) at factory no more than 4 weeks. 9.2 The MEMS MIC with normal pack can be transported by ordinary conveyances. Please protect products against moist, shock, sunburn and pressure during transportation. 9.3 Storage Temperature Range:-40℃~+70℃ 9.4 Operating Temperature Range:-40℃~+100℃ Note1: MSL(moisture sensitivity level) Class 1(IPC/JEDEC-J-STD-020 Revision C) Note2: Static sensitive device Version:3.0 Confidential in Goermicro, shall not be spread if not be privileged. page 12/16 Confidential Degree : Confidential 10 Land Pattern Recommendation 10.1 The Pattern of MIC Pad(Unit:mm) 0.6 0.57 5-0.638*0.57 3 4 2 5 1 6 0.638 0.3 0.3 R0.319 0.57 10.2 Recommended Soldering Surface Land Pattern(Unit:mm) 0.57 0.6 0.3 0.3 4 1 5 2 6 3 0.638 5-0.638*0.57 R0.319 0.57 Version:3.0 Confidential in Goermicro, shall not be spread if not be privileged. page 13/16 Confidential Degree : Confidential 11 Soldering Recommendation 11.1 Soldering Machine Condition 8 zones Temperature Control Heater Type Hot Air Solder Type Lead-free 11.2 The Drawing and Dimension of Nozzle Inside Diameter: 1.0mm; Ø1 Forbidden area for vacuum application 1.93 0.3 Recommendation area for pick up 1.4 Please don't vacuum over the acoustic port directly. Please don't blow the acoustic port directly. Ø1.0 Version:3.0 Confidential in Goermicro, shall not be spread if not be privileged. page 14/16 Confidential Degree : Confidential 11.3 Reflow Profile Temp. °C Tp Max. Ramp-up rate = 3℃/s Max. Ramp-down rate = 6℃/s TL tp tL Tsmax Preheat area Tsmin ts 25 time 25℃ to peak Time. sec Key Features of The Profile: Average Ramp-up rate(Tsmax to Tp) 3℃/s max. Preheat : Temperature Min(Tsmin) Temperature Max(Tsmax) Time(Tsmin to Tsmax)(ts) 150℃ 200℃ 60~180s Time maintained above : Tempreature(TL) Time(tL) 217℃ 60~150s Peak Temperature(Tp) 260℃ Time within 5℃ of actual Peak Temperature(tp) : 30~40s Ramp-down rate(Tp to Tsmax) 6℃/s max Time 25℃ to Peak Temperature 8min max When MEMS MIC is soldered on PCB, the reflow profile is set according to solder paste and the thickness of PCB etc. Version:3.0 Confidential in Goermicro, shall not be spread if not be privileged. page 15/16 Confidential Degree : Confidential 12 Cautions When Using MEMS MIC 12.1 Board Wash Restrictions It is very important not to wash this silicon microphone, otherwise this could damage the microphone. 12.2 Sound Hole Protection It is very important not to operate vacuum and air blow into sound hole(without any covering over sound holes), otherwise this could damage the microphone. And it is necessary to be careful about foreign substances into sound hole inside silicon microphone. 12.3 Wire width Adaption It is needed to adjust the dumping resistance according to the wire length and wire tod,etc. when using. It is also necessary to insert dumping resistance in the Data line located adjacent to the microphone according to circumstances. 12.4 Ultrasonic Restrictions It is very important not to use ultrasonic process. otherwise this could damage the microphone. 13 Output Inspection Standard Output inspection standard is executed according to . Version:3.0 Confidential in Goermicro, shall not be spread if not be privileged. page 16/16
SD33OT261-003 价格&库存
很抱歉,暂时无法提供与“SD33OT261-003”相匹配的价格&库存,您可以联系我们找货
