RFPC-SMA17-FN
RFPC-SMA17-FN
    GRADCONN
    RP SMA PCB MOUNT STRAIGHT BULKHE
RFPC-SMA17-FN 数据手册
  °   ° Test Type Test Standard Methodology Electrical Performance GradConn Standard Electrical Performance Specification Implement 2-port full calibration of the device under test (DUT) with a Vector Network Analyser (VNA), firmly locking the SMA connectors into both sides of the DUT. Activate measurement function and select response menu for all S-Parameters. Salt Spray Thermal Shock IPX7 BS EN 60068-211-1999 BS EN 60068-214-2009 IEC 60529:2013 Device under test consisting of a mounted connector on an enclosure is placed within a salt spray chamber. Test conditions as follows: 1) Temperature of the chamber 35°C 2) Temperature of the saturation 47°C 3) Salt Solution: 5%NaCl (by weight) 4) Volume of salt solution collected 1~2ml/h*80cm2 5) Test duration: 100 hours Example Device Under Test/Equipment Images Parameters & Results from Cycle 5 (Full test reports available on requests) Parameters 1GHz 2GHz 3GHz Requirements Insertion Loss (dB) 0.385 0.392 0.478
RFPC-SMA17-FN 价格&库存
很抱歉,暂时无法提供与“RFPC-SMA17-FN”相匹配的价格&库存,您可以联系我们找货
