1511
1511
    HAMMONDMANUFACTURING
    4 mH 无屏蔽 鼓芯,绕线式 电感器 600 mA 11 欧姆 非标准
1511 数据手册
Miniature Inductors & R.F. 621 Series 622 Series Selection Table MINIATURE INDUCTORS • Vacuum epoxy cast for stability. • Constructed to pass MIL environmental specs. • Low profile and pin mounted for P.C. applications. • Pin diameter 0.032" Ca t . I n d u c t a n c e ( L ) No. +/- 2% mH 621G 1.0 621J 2.2 621L 4.7 621N 10.0 621Q 22.0 622S 47 622U 100 622W 220 622Y 470 622ZA 1000 Idc (mA)* f or - 2% L 51 34 23 16 11 13.7 9.3 6.4 4.3 2.9 Freq. k Hz 50 45 40 30 35 16 15 13 10 8 Nominal Q 40 40 38 38 38 65 64 60 54 45 D.C. resistance +/ - 20% 2 4.5 8.2 20 45 27 49 122 218 400 * I D.C. current (ma.) for minus 2% change of inductance (L) ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ ○ 1500 1506 1501 1508 1502 1509 1503 1510 1511 1505 1512 1515, 1518 & 1521 Selection Table R.F. CHOKES • Low loss ceramic or powdered iron forms • Tolerance +/- 10% on inductance • Catalog numbers 1515, 1518, 1521 designed for heavy duty use in linear amplifiers or other transmitter applications. Wound on 1" dia. ceramic forms with standoff insulators and 1/4-20 mounting bolt. 1504 Ca t . D. C. mA No. 1500 125 1501 75 1502 500 1503 50 1504 125 1505 250 1506 250 1508 500 1509 600 1510 400 1511 600 1512 1000 1515 500 1518 750 1521 1000 Induct. D.C. Res mH mH ohms 1.0 12.0 10 47.0 0.007 1.3 2.5 22.0 2.5 44.0 2.5 12.0 1.6 12.0 0.035 3.1 1.0 6.0 4.4 12.0 4.0 11.0 3.2 4.5 0.25 3.0 0.1 1.2 0.09 0.68 No. of Pi e s 1 2 Layer 2 4 4 4 Layer 5 5 5 5 Layer Layer Layer Fo r m Wt. Oz. Type Lengt h Powdered 0.63 0.25 Powdered 0.88 0.5 Ceramic 1.5 0.25 Powdered 0.63 0.25 Ceramic 1.5 0.5 Ceramic 1.5 0.75 Ceramic 1.5 0.5 Ceramic 3 1.3 Ceramic 3 2 Ceramic 3 3 Ceramic 3 2.5 Ceramic 3 5 Ceramic 4 8 Ceramic 4 8 Ceramic 4 8 CANADA Phone: (519) 822-2960 Fax: (519) 822-0715 © 2000 USA Phone: (716) 651-0086 Fax: (716) 651-0726 35 www.hammondmfg.com
1511
1. 物料型号:文档列出了两个系列的电感器,621系列和622系列,以及射频滤波器的型号,如1500、1501等,直至1521。
2. 器件简介:电感器采用真空环氧浇注以确保稳定性,符合MIL环境规格,低轮廓设计,适合PC应用,引脚直径为0.032英寸。
3. 引脚分配:文档没有明确提供引脚分配图,但提到了引脚直径。
4. 参数特性:提供了详细的参数表,包括电感值、直流电流、品质因数Q、频率、直流电阻等。
5. 功能详解:文档描述了电感器和射频滤波器的构造,例如使用低损耗陶瓷或粉末铁芯,以及它们的应用场景。
6. 应用信息:电感器适用于PC应用,射频滤波器设计用于线性放大器或其他发射机应用。
7. 封装信息:提供了封装的物理尺寸和重量信息。
8. 附加信息:文档末尾提供了HAMMOND MANUFACTURING公司的联系信息和网址。
很抱歉,暂时无法提供与“1511”相匹配的价格&库存,您可以联系我们找货
