7/6/2021
Type 4X Diecast Aluminum Enclosures (R100 Series) - Hammond Mfg.
Quality Products. Service Excellence.
Type 4X Diecast Aluminum Enclosures R100 Series
aluNORM - Watertight, Thick Wall
Key Features:
Material - Aluminum die-cast: G AI SI 12 / DIN 1775
Shallow lid, deep body
Captive stainless steel lid screws
Neoprene oil and petrol resistant gasket standard. (-40ºC up to +80ºC)
Degree of protection NEMA 4X, IP66, DIN 40050
Temperature Range (-40ºC up to +80ºC)
Single-channel Fastening System
Special developed external mounting feet made from zinc-die-cast. Can be turned
through 90º. The fastening holes have engagement lugs for this purpose. (See
accessories)
All sizes have inner blind holes.
An inner mounting panel - made of zinc-plated steel is also available (See accessories)
Textured polyester powder coat, beige RAL7032 or light gray RAL7035. (can be supplied
unpainted on special order)
CSA certified, UL Listed, Type 4, for use with industrial control equipment.
Features
1. Lid screws and mounting holes outside of the gasket seal.
https://www.hammfg.com/electronics/small-case/diecast/r100
1/4
7/6/2021
2. Space saving single channel mounting (ie...same hole used for mounting enclosure
through rear and also for the lid), provides larger interior space than dual channel
enclosures.
3. Captive stainless steel lid screws.
4. Enclosure holes threaded for easy installation and repetitive assembly & disassembly.
5. Internal mounting shelves placed along both sides of enclosure include blind holes and
grounding screws.
Patented Single Channel System
Provides larger interior space than dual channel enclosures.
Uses the same enclosure hole for mounting the enclosure and fastening the lid.
Accessories (see table below for compatibility)
External Mounting
Inner Panel
Hinge Kit
Feet
Shallow Lid, Deep Body (R100 Series)
Part No (RAL 7032 Beige)
Part No (RAL 7035 Light Gray)
R100-060-000
R100-060-035
65
50
40
R100-062-000
R100-062-035
65
65
40
R100-064-000
R100-064-035
65
100
40
R100-066-000
R100-066-035
65
150
40
R100-080-000
R100-080-035
80
80
60
R100-082-000
R100-082-035
80
120
60
R100-084-000
R100-084-035
80
160
60
R100-100-000
R100-100-035
100
100
80
R100-102-000
R100-102-035
100
150
80
R100-104-000
R100-104-035
100
200
80
R100-120-000
R100-120-035
120
120
100
R100-122-000
R100-122-035
120
180
100
R100-124-000
R100-124-035
120
240
100
R100-160-000
R100-160-035
160
160
100
R100-162-000
R100-162-035
160
240
100
R100-164-000
R100-164-035
160
320
100
R100-166-000
R100-166-035
160
480
100
R100-200-000
R100-200-035
200
200
120
R100-202-000
R100-202-035
200
300
120
R100-204-000
R100-204-035
200
400
120
R100-240-000
R100-240-035
240
240
120
Width Length
Depth (Including Lid)
2/4
7/6/2021
R100-242-000
R100-242-035
Width Length
240
360
120
R100-244-000
R100-244-035
240
480
120
R100-320-000
R100-320-035
320
320
120
R100-322-000
R100-322-035
320
480
120
R100-324-000
R100-324-035
320
640
120
Deep Lid, Shallow Body (R101 Series)
Part No.
Width
Length
R101-080-000¹
80
80
60
R101-082-000¹
80
120
60
R101-084-000¹
80
160
60
R101-100-000¹
100
100
80
R101-102-000¹
100
150
80
R101-104-000¹
100
200
80
R101-120-000¹
120
120
100
R101-122-000¹
120
180
100
R101-124-000¹
120
240
100
R101-160-000¹
160
160
100
R101-162-000¹
160
240
100
R101-164-000¹
160
320
100
R101-166-000¹
160
480
100
R101-200-000¹
200
200
120
R101-202-000¹
200
300
120
R101-204-000¹
200
400
120
R101-240-000¹
240
240
120
R101-242-000¹
240
360
120
R101-244-000¹
240
480
120
R101-320-000¹
320
320
120
R101-322-000¹
320
480
120
R101-324-000¹
320
640
120
¹ R101 series enclosures are not stocking items. Please contact Hammond's sales team for more information.
Matching Lid & Body (R102 Series)
Part No.
Width
Length
R102-080-000¹
80
80
40
R102-082-000¹
80
120
40
R102-084-000¹
80
160
40
R102-100-000¹
100
100
54
R102-102-000¹
100
150
54
R102-104-000¹
100
200
54
R102-120-000¹
120
120
66
R102-122-000¹
120
180
66
R102-124-000¹
120
240
66
R102-160-000¹
160
160
66
R102-162-000¹
160
240
66
R102-164-000¹
160
320
66
R102-166-000¹
160
480
66
R102-200-000¹
200
200
80
R102-202-000¹
200
300
80
R102-204-000¹
200
400
80
R102-240-000¹
240
240
80
R102-242-000¹
240
360
80
R102-244-000¹
240
480
80
R102-320-000¹
320
320
80
R102-322-000¹
320
480
80
3/4
7/6/2021
Part No.
R102-324-000¹
Width
Length
320
640
80
¹ R102 series enclosures are not stocking items. Please contact Hammond's sales team for more information.
aluNORM Accessories
External Feet
Inner Panel 2mm,
Hinge
For Use With
(Set of 2 or 4)
Galvanized Steel
(Set of 2)
Enclosure Types
Part No.
Part No.
Part No.
R100, R101 & R102-060
N/A
N/A
N/A
R100, R101 & R102-062
N/A
R507-062-000
N/A
R100, R101 & R102-064
N/A
R507-064-000
N/A
R100, R101 & R102-066
N/A
R507-066-000
N/A
R100, R101 & R102-080
R501-002-080
R507-080-000
N/A
R100, R101 & R102-082
R501-002-080
R507-082-000
N/A
R100, R101 & R102-084
R501-002-080
R507-084-000
N/A
R100, R101 & R102-100
R501-002-100
R507-100-000
N/A
R100, R101 & R102-102
R501-002-100
R507-102-000
R510-000-000
R100, R101 & R102-104
R501-002-100
R507-104-000
R510-000-000
R100, R101 & R102-120
R501-000-011
R507-120-000
R510-000-000
R100, R101 & R102-122
R501-000-011
R507-122-000
R510-000-000
R100, R101 & R102-124
R501-000-011
R507-124-000
R510-000-000
R100, R101 & R102-160
R501-000-012
R507-160-000
R510-000-000
R100, R101 & R102-162
R501-000-012
R507-162-000
R510-000-000
R100, R101 & R102-164
R501-000-012
R507-164-000
R510-000-000
R100, R101 & R102-166
R501-000-012
R507-166-000
R510-000-000
R100, R101 & R102-200
N/A
R507-200-000
R510-000-000
R100, R101 & R102-202
N/A
R507-202-000
R510-000-000
R100, R101 & R102-204
N/A
R507-204-000
R510-000-000
R100, R101 & R102-240
N/A
R507-240-000
R510-000-000
R100, R101 & R102-242
N/A
R507-242-000
R510-000-000
R100, R101 & R102-244
N/A
R507-244-000
R510-000-000
R100, R101 & R102-320
N/A
R507-320-000
R510-000-000
R100, R101 & R102-322
N/A
R507-322-000
R510-000-000
R100, R101 & R102-324
N/A
R507-324-000
R510-000-000
Data subject to change without notice
© 2021. Hammond Manufacturing Ltd. All rights reserved.
4/4
很抱歉,暂时无法提供与“R100-160-035”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2181.851661+282.45956
- 5+1844.217665+238.74992
- 10+1793.2414610+232.15061
