5103432
5103432
    HAPCO
    BLOWER TYPE HD140, 1X230V
5103432 数据手册
Data sheet HERZ High pressure blower type HD140 Type: Side channel blower Configuration: In the standard version, the fan on the intake side has a stainless steel filter that can be used after cleaning with compressed air. When using a fine filter, the stainless steel filter be removed. Features: The device is suitable for operation with frequency inverters for speed control. If desired, the device can be equipped with a thermistor (PTC), the signal can be evaluated with an optional trip device. The tech. Data remains unchanged. Operating temperature: The operating temperature of the radial pressure may NOT exceed 60 ° C. Ambient temperature: -20 ° C to +60 ° C; Voltage: Optional 1 x 230VAC/50Hz, Capacitor 16/450uF/V (Item-no.: 5108623) Technical data Type: Item no.: Voltage Frequency Motor power Current Volume flow Total pressure difference Speed Sound pressure level Weight Air intake Air outlet Dimensions Protection type Conformity VAC (Y/Δ) Hz KW A (Y/Δ) m³ / min Pa rpm LpA (db) kg mm mm mm (LxWxH) Side channel blower 5103429 on request 200 – 255 / 346 - 440 200 – 247 / 346 – 480 50 60 0,42 0,52 1,73 – 2,10 / 1,00 – 1,20 2,00 – 2,50 / 1,15 – 1,45 1,50 1,60 14‘000 2‘845 3‘435 64 – 73 69 – 76 11,3 Ø 38 (aussen) Ø 38 (aussen) 283 x 244 x 266,5 IP 54 CE Protection class I DB HD140 V20 R18 07_2021 GB.docx technical changes reserved 1 Data sheet HERZ High pressure blower type HD140 Fan characteristics (Y/Δ) 200–255/346–440VAC, 50Hz (Y/Δ) 200–277/346–480VAC, 60Hz Permissible vibration values according to ISO 14694 Fan application category [ah] BV-3 DB HD140 V20 R18 07_2021 GB.docx Rigidly mounted [mm/s²] Peak r.m.s. 3,8 2,8 technical changes reserved Flexibly mounted [mm/s²] Peak r.m.s. 5,1 3,5 2 Data sheet HERZ High pressure blower type HD140 Accessories Item-No. Description 5108623 Motor capacitor 230 V ~ with clamp and cable 5107293 Hose connection adaptor 1 x 38mm inside / 2 x 38mm outside 5207293 Hose connection adaptor 1 x 38mm / 2 x 38mm – with thread outside 5107281 Hose connection adaptor 1 x 38mm inside / 3 x 14mm outside 5107298 Hose connection adaptor 1 x 38mm inside / 2 x 19mm outside 5107286 PVC air hose – Ø 38mm inside 5107287 Hose clip for hose Ø 38mm 5107241 Closure Cap for hose connection adaptor Ø 38mm 5107350 PVC air hose aus PVC – Ø 19mm inside 5107290 Hose clip for hose Ø 19mm 5107242 Closure Cap for hose connection adaptor Ø 19mm 5107354 Stainless steel filter for HD140 DB HD140 V20 R18 07_2021 GB.docx technical changes reserved 3 Data sheet HERZ High pressure blower type HD140 DB HD140 V20 R18 07_2021 GB.docx technical changes reserved 4 Data sheet HERZ High pressure blower type HD140 HERZ GmbH HERZ GmbH Kunststoff- & Wärmetechnologie Biberweg 1 DE – 56566 Neuwied Tel.: +49 (0)2622-8855-0 Fax: +49 (0)2622-8855-135 Fax: +49 (0)2622-8855-136 www.herz-gmbh.com info@herz-gmbh.com Kunststoff- & Wärmetechnologie Am Arenberg 26A DE – 86456 Gablingen Tel.: +49 (0)8230-85085 Fax: +49 (0)8230-85087 www.herz-gmbh.com robert.einberger@herz-gmbh.com HERZ Austria GmbH HERZ Austria GmbH Kunststoff- & Wärmetechnologie Gleinser Weg 27 AT – 6141 Schönberg / Tirol Tel.: +43 (0)5225-63113 Fax: +43 (0)5225-6311385 www.herz-austria.at herz.schoenberg@herz-gmbh.com Kunststoff- & Wärmetechnologie Johann-Galler-Str. 20 IZ – NÖ – Nord AT – 2120 Wolkersdorf i. Weinviertel Tel.: +43 (0)2245-82494-0 Fax: +43 (0)2245-82494-9 www.herz-austria.at herz.wolkersdorf@herz-gmbh.com HERZ Hungária Kft. HERZ Polska Sp.z o. o. Technologie obróbki tworzyw sztucznych Ul. Kostrzyńska 30 PL – 02-979 Warzawa Tel.: +48 (0)22-8428583 Fax: +48 (0)22-8429700 www.herz-polska.pl herz@herz-polska.pl Műanyag- es hőlégtechnika Pesti út 284 HU – 2225 Üllö Tel.: +36 (06)29-522400 Fax: +36 (06)29-522410 www.herz-hungaria.hu herz@herz-hungaria.hu HERZ Bulgaria OOD Boul. Assen Yordanov 10 BG – 1592 Sofia Tel.: +359 (0)2-9790351 www.herz-bulgaria.com office@herz-bulgaria.com © by HERZ GmbH DB HD140 V20 R18 07_2021 GB.docx technical changes reserved 5
5103432 价格&库存
很抱歉,暂时无法提供与“5103432”相匹配的价格&库存,您可以联系我们找货
