5103510
5103510
    HAPCO
    BLOWER TYPE MD10, 1X230
5103510 数据手册
Data sheet HERZ Medium pressure blower type MD10 Type: Radial fan Configuration: In the standard version, the fan on the intake side has a stainless steel filter that can be used after cleaning with compressed air. When using a fine filter, the stainless steel filter be removed. Features: The device is suitable for operation with frequency inverters for speed control. If desired, the device can be equipped with a thermistor (PTC), the signal can be evaluated with an optional trip device. The tech. Data remains unchanged. Operating temperature: The operating temperature of the radial pressure may NOT exceed 60°C/140°F. Optionally, the inlet air temperature of the fan can be raised by a single temperature lock onto a maximum of 180°C/356°F and with a double temperature lock onto a maximum of 230°C/446°F. Ambient temperature: -20°C to +60 C / -4°F to +140°F. Voltage: Optional 1 x 230VAC with Capacitor 8/450µF/V (Item no.: 5110887) Technical data Type: Item no.: Voltage Frequency Motor power Efficiency Current Volume flow Total pressure difference Speed Sound pressure level Weight Air intake Air outlet Dimensions Protection type Conformity VAC Hz KW cos φ A (Δ/Y) m³ / min Pa rpm LpA (db) kg mm mm mm (LxBxH) 5103507 (Δ/Y) 230/400 50 0,08 0,67 0,55 / 0,32 4,9 1‘000 2‘750 73 8,5 Centrifugal fan 5103509 on request (Δ/Y) 277/480 230 60 50 0,12 0,08 0,87 0,67 0,61 / 0,35 0,65 5,9 4,8 1‘300 1‘000 3‘380 2‘700 76 73 8,6 Ø 70 Ø 60 (outside) 356,5 x 238 x 344,5 IP 54 CE on request (Δ) 500 60 0,11 (0,15HP) 0,75 Δ 0,34 5,2 1‘200 3‘210 76 8,5 UL Protection class I DB MD10 V20 R20 07_2021 GB.docx Technical changes reserved 1 Data sheet HERZ Medium pressure blower type MD10 Fan characteristics (Y/Δ) 230 - 400VAC, 50Hz (Y/Δ) 277 - 480VAC, 60Hz Permissible vibration values according to ISO 14694 Fan application category [ah] BV-3 DB MD10 V20 R20 07_2021 GB.docx Rigidly mounted [mm/s²] Peak r.m.s. 3,8 2,8 Technical changes reserved Flexibly mounted [mm/s²] Peak r.m.s. 5,1 3,5 2 Data sheet HERZ Medium pressure blower type MD10 Accessories: Item no. Description 5110887 Motor capacitor 230 V~ with clamp and cable 5107278 Hose connection adaptor 1 x 60mm inside / 2 x 60mm outside 5107291 Hose connection adaptor 1 x 60mm inside / 1 x 38mm outside 5107293 Hose connection adaptor 1 x 38mm inside / 2 x 38mm outside 5207293 Hose connection adaptor 1 x 38mm / 2 x 38mm – with thread outside 5107281 Hose connection adaptor 1 x 38mm inside / 3 x 14mm outside 5107298 Hose connection adaptor 1 x 38mm inside / 2 x 19mm outside 5107288 PVC air hose– Ø 60mm inside 5107286 PVC air hose – Ø 38mm inside 5107285 Hose clamp for hose Ø 60mm 5107287 Hose clamp for hose Ø 38mm 5107240 Cap for hose connection adaptor Ø 60mm 5107241 Cap for hose connection adaptor Ø 38mm DB MD10 V20 R20 07_2021 GB.docx Technical changes reserved 3 Data sheet HERZ Medium pressure blower type MD10 Accessories: Item no. Description 5107350 PVC air hose – Ø 19mm inside 5107290 Hose clamp for hose Ø 19mm 5107242 Cap for hose connection adaptor Ø 19mm 5107356 Stainless steel filter for MD10 5013402 Intake for MD10 5100620 Paper filter for MD10 DB MD10 V20 R20 07_2021 GB.docx Technical changes reserved 4 Data sheet HERZ Medium pressure blower type MD10 DB MD10 V20 R20 07_2021 GB.docx Technical changes reserved 5 Data sheet HERZ Medium pressure blower type MD10 HERZ GmbH HERZ GmbH Kunststoff- & Wärmetechnologie Biberweg 1 DE – 56566 Neuwied Tel.: +49 (0)2622-8855-0 Fax: +49 (0)2622-8855-135 Fax: +49 (0)2622-8855-136 www.herz-gmbh.com info@herz-gmbh.com Kunststoff- & Wärmetechnologie Am Arenberg 26A DE – 86456 Gablingen Tel.: +49 (0)8230-85085 Fax: +49 (0)8230-85087 www.herz-gmbh.com robert.einberger@herz-gmbh.com HERZ Austria GmbH HERZ Austria GmbH Kunststoff- & Wärmetechnologie Gleinser Weg 27 AT – 6141 Schönberg / Tirol Tel.: +43 (0)5225-63113 Fax: +43 (0)5225-6311385 www.herz-austria.at herz.schoenberg@herz-gmbh.com Kunststoff- & Wärmetechnologie Johann-Galler-Str. 20 IZ – NÖ – Nord AT – 2120 Wolkersdorf i. Weinviertel Tel.: +43 (0)2245-82494-0 Fax: +43 (0)2245-82494-9 www.herz-austria.at herz.wolkersdorf@herz-gmbh.com HERZ Hungária Kft. HERZ Polska Sp.z o. o. Technologie obróbki tworzyw sztucznych Ul. Kostrzyńska 30 PL – 02-979 Warzawa Tel.: +48 (0)22-8428583 Fax: +48 (0)22-8429700 www.herz-polska.pl herz@herz-polska.pl Műanyag- es hőlégtechnika Pesti út 284 HU – 2225 Üllö Tel.: +36 (06)29-522400 Fax: +36 (06)29-522 410 www.herz-hungaria.hu herz@herz-hungaria.hu HERZ Bulgaria OOD Boul. Assen Yordanov 10 BG – 1592 Sofia Tel.: +359 (0)2-9790351 www.herz-bulgaria.com office@herz-bulgaria.com © by HERZ GmbH DB MD10 V20 R20 07_2021 GB.docx Technical changes reserved 6
5103510 价格&库存
很抱歉,暂时无法提供与“5103510”相匹配的价格&库存,您可以联系我们找货
