5114354
5114354
    HAPCO
    HEATER TYPE PH92, 3X400-440-480V
5114354 数据手册
Data sheet HERZ Air heater type PH92 to 17,0 KW Function: Heater with external air supply operated by blower or compressed air. Configuration: Ready for connection with 5 meter silicone connection cable 4x2.5 mm² for maximum incoming air temperatures up to 180 C/356°F. The devices works without internal control and monitoring electronics!!! Features: Device is provided with two flanges - for mounting in a duct system. Power: Voltage: 5,9 – 17,0 KW 230VAC 3Ph/400-480VAC Technical data: Item number Voltage Frequency Power Current Max. supply air temperature Max. air outlet temperature Min. air volume Weight Air intake Air outlet Dimensions Max. operating pressure Conformity mark VAC Hz KW A °C/°F °C/°F l/min kg (inkl. Cable) Ø mm Ø mm mm (L x W x H) bar 5112722 230 (3Ph) 5114356 10,2 25,6 5,9 – 8,5 8,5 – 10,2 820 560 5114355 400 – 480 50 / 60 7,6 – 10,9 11,0 – 13,1 180/356 650/1202 680 3,5 113 90 142,5 x 164 x 122 6,0 5114354 5116134 400 11,8 – 17,1 17,0 – 20,6 17,0 24,5 950 1480 Protection class I DB PH92 V20 R18 03_2021 GB.docx techn. Änderungen vorbehalten 1 Data sheet HERZ Air heater type PH92 to 17,0 KW Accessories: Item.-No. Description 5202408 Digital controller with logic output; type ETR48-24; 240VAC 5202406 Power semiconductor relais without heat sink 230VAC 12A (Stearing 12V) 5202407 Heat sink for power semiconductor relais (5202406) DB PH92 V20 R18 03_2021 GB.docx techn. Änderungen vorbehalten 2 Data sheet HERZ Air heater type PH92 to 17,0 KW DB PH92 V20 R18 03_2021 GB.docx techn. Änderungen vorbehalten 3 Data sheet HERZ Air heater type PH92 to 17,0 KW HERZ GmbH HERZ GmbH Kunststoff- & Wärmetechnologie Biberweg 1 DE – 56566 Neuwied Tel.: +49 (0)2622-8855-0 Fax: +49 (0)2622-8855-135 Fax: +49 (0)2622-8855-136 www.herz-gmbh.com info@herz-gmbh.com Kunststoff- & Wärmetechnologie Am Arenberg 26A DE – 86456 Gablingen Tel.: +49 (0)8230-85085 Fax: +49 (0)8230-85087 www.herz-gmbh.com robert.einberger@herz-gmbh.com HERZ Austria GmbH HERZ Austria GmbH Kunststoff- & Wärmetechnologie Gleinser Weg 27 AT – 6141 Schönberg / Tirol Tel.: +43 (0)5225-63113 Fax: +43 (0)5225-6311385 www.herz-austria.at herz.schoenberg@herz-gmbh.com Kunststoff- & Wärmetechnologie Johann-Galler-Str. 20 IZ – NÖ – Nord AT – 2120 Wolkersdorf i. Weinviertel Tel.: +43 (0)2245-82494-0 Fax: +43 (0)2245-82494-9 www.herz-austria.at herz.wolkersdorf@herz-gmbh.com HERZ Hungária Kft. HERZ Polska Sp.z o. o. Technologie obróbki tworzyw sztucznych Ul. Kostrzyńska 30 PL – 02-979 Warzawa Tel.: +48 (0)22-8428583 Fax: +48 (0)22-8429700 www.herz-polska.pl herz@herz-polska.pl Műanyag- es hőlégtechnika Pesti út 284 HU – 2225 Üllö Tel.: +36 (06)29-522400 Fax: +36 (06)29-522410 www.herz-hungaria.hu herz@herz-hungaria.hu HERZ Bulgaria OOD Boul. Assen Yordanov 10 BG – 1592 Sofia Tel.: +359 (0)2-9790351 www.herz-bulgaria.com office@herz-bulgaria.com © by HERZ GmbH DB PH92 V20 R18 03_2021 GB.docx techn. Änderungen vorbehalten 4
5114354 价格&库存
很抱歉,暂时无法提供与“5114354”相匹配的价格&库存,您可以联系我们找货
