5101352
5101352
    HAPCO
    HEATER TYPE S-21, 230V/800W WITH
5101352 数据手册
Data sheet HERZ Air heater type S21 to 800W Function: Air heater with external air supply by means of fan or compressed air. CAUTION !!! Device is not pressure-resistant !!! Configuration: Default: Temperature control with potentiometer (1 – 8) - alternatively with external potentiometer (cable length 5 meter) or - external control by control unit or SPS (cable length 5 meter) Device is equipped with a reliable heating element protection. The integrated device protection turns off the device when tripped and resets automatically after cooling down. A reset is not required. Features: Power: Voltage: Special designs: - for devices with electronic equipment max. supply air temperature 50°C/122°F - the unit is available without electronics (without heating element protection) - for devices without electronic equipment max. supply air temperature 80°C/176°F 550 Watt, 435 - 800 Watt 120 VAC, 230 VAC Technical data: Item number / Basic versions Voltage Frequency Power Current Max. temperature Min. air volume Weight Air intake Air outlet Heater tube Dimensions Potentiometer external control without electronic VAC Hz KW A °C°F l/min kg Ø mm Ø mm Ø mm mm (L x W x H) 5101354 5101343 on request 120 0,55 4,6 150 5101349 5700043 on request 5101351 5110304 5101352 230 50 / 60 0,435 1,9 600/1112 110 0,3 19 13 21 194 x 70 x 59 0,8 3,5 210 Conformity mark Protection class II DB S21 V20 R18 03_2021 GB.docx Technical changes reserved 1 Data sheet HERZ Air heater type S21 to 800W Product description: Connection scheme: 6 4 Default with potentiometer External control N, L1 = Main connection according to data plate N, L1 = Main connection according to data plate 1 5 Digital signal (PWM max. 0,5Hz) 10-24VDC + = brown - = white 7 3 2 +/control cable 1. Cable fitting mains supply 2. Potentiometer 0-8 (control cable für ext. control); (no Potentiometer for devices without electronic) 3. Mounting on bottom of housing M 4 (screw depth 7 mm) 4. Heating element pipe Ø21mm 5. Cover 6. Data plate 7. Air intake Ø19mm DB S21 V20 R18 03_2021 GB.docx Version without electronics N, L1 = Main connection according to data plate Technical changes reserved 2 Data sheet HERZ Air heater type S21 to 800W Avaiable versions: Item no. 5101354 5101343 5101349 5700043 5101351 5110304 5101352 Description Air heater S21 120 VAC 550 Watt with potentiometer Air heater S21 120 VAC 550 Watt externally controllable (PWM 12-24 VDC, 1 Hz) with 5.0m control cable (2-pin) Air heater S21 120 VAC 435 Watt with potentiometer Air heater S21 120 VAC 435 Watt externally controllable (PWM 12-24 VDC, 1 Hz) with 5.0m control cable (2-pin) Air heater S21 230 VAC 800 Watt with potentiometer Air heater S21 230 VAC 800 Watt externally controllable (PWM 12-24 VDC, 1 Hz) with 5.0m control cable (2-pin) Air heater S21 230 VAC 800 Watt without electronic Available modifications: Item number Type 5005005.1 S02 5005021.1 5005010.1 5005007 S05 S06 S12 5005019 S13 5700141 S31 Modification External potentiometer for heating including 5m control line; 3 pole; The basic device for this modification is Potentiometer is soldered to the end of the cable; including potentiometer knob always standard with a potentiometer red; Internal PID control via internal potentiometer without digital display; Internal thermocouple including 2m compensation cable with open ends green (+) white (-); A push-in nipple for air hose 8/6mm is mounted on the air connection Instead of the potentiometer for devices WITHOUT electronics, a 1/4 "compressed air hose connection 6/4mm is installed; This is used to monitor the pressure in the housing; 100% heating output with heating element protection for type S/M (for basic device without electronics); Accessories: Item no. Description 5107282 Flange connector 5107144 Tubular nozzle Ø 5mm 5107145 Tubular nozzle Ø 10mm 5107324 Spoon-reflector Ø 10 mm for soldering of solder-shrinkage connections and for shrinkage of PVC, PTFE, FEP shrink hose. Push-fit for nozzle Ø 5mm DB S21 V20 R18 03_2021 GB.docx Technical changes reserved 3 Data sheet HERZ Air heater type S21 to 800W Combination possibilities for devices WITH electronic *: Measuring point: Hose length: Air supply: Air flow: 3.0 mm after the air outlet pipe adapter – without nozzle, measured at the hottest point 1,0 mr Blower 400 Volt, 50 Hz (HD = High pressure blower, MD = Medium pressure blower) Nl / min = standard liters per minute according to DIN 1343 CAUTION: Air flow and temperature are indicative which can change due to external influences and changes air hose diameter and length! Blower type HD140 Quantity, air heater type, voltage, power 1 x S21; 230VAC; 435W 2 x S21; 230VAC; 435W 4 x S21; 230VAC; 435W 1 x S21; 230VAC; 0,8KW 2 x S21; 230VAC; 0,8KW 4 x S21; 230VAC; 0,8KW Air flow at 50 Hz with heating [Nl / min.] 230 2 x 200 4 x 160 330 2 x 240 4 x 190 Maximum temperature at 50 Hz [°C/°F] 290/554 300/572 310/590 320/608 380/716 430/806 *Data without guarantee DB S21 V20 R18 03_2021 GB.docx Technical changes reserved 4 Data sheet HERZ Air heater type S21 to 800W DB S21 V20 R18 03_2021 GB.docx Technical changes reserved 5 Data sheet HERZ Air heater type S21 to 800W HERZ GmbH HERZ GmbH Kunststoff- & Wärmetechnologie Biberweg 1 DE – 56566 Neuwied Tel.: +49 (0)2622-8855-0 Fax: +49 (0)2622-8855-135 Fax: +49 (0)2622-8855-136 www.herz-gmbh.com info@herz-gmbh.com Kunststoff- & Wärmetechnologie Am Arenberg 26A DE – 86456 Gablingen Tel.: +49 (0)8230-85085 Fax: +49 (0)8230-85087 www.herz-gmbh.com robert.einberger@herz-gmbh.com HERZ Austria GmbH HERZ Austria GmbH Kunststoff- & Wärmetechnologie Gleinser Weg 27 AT – 6141 Schönberg / Tirol Tel.: +43 (0)5225-63113 Fax: +43 (0)5225-6311385 www.herz-austria.at herz.schoenberg@herz-gmbh.com Kunststoff- & Wärmetechnologie Johann-Galler-Str. 20 IZ – NÖ – Nord AT – 2120 Wolkersdorf i. Weinviertel Tel.: +43 (0)2245-82494-0 Fax: +43 (0)2245-82494-9 www.herz-austria.at herz.wolkersdorf@herz-gmbh.com HERZ Hungária Kft. HERZ Polska Sp.z o. o. Technologie obróbki tworzyw sztucznych Ul. Kostrzyńska 30 PL – 02-979 Warzawa Tel.: +48 (0)22-8428583 Fax: +48 (0)22-8429700 www.herz-polska.pl herz@herz-polska.pl Műanyag- es hőlégtechnika Pesti út 284 HU – 2225 Üllö Tel.: +36 (06)29-522400 Fax: +36 (06)29-522410 www.herz-hungaria.hu herz@herz-hungaria.hu HERZ Bulgaria OOD Boul. Assen Yordanov 10 BG – 1592 Sofia Tel.: +359 (0)2-9790351 www.herz-bulgaria.com office@herz-bulgaria.com © by HERZ GmbH DB S21 V20 R18 03_2021 GB.docx Technical changes reserved 6
5101352 价格&库存
很抱歉,暂时无法提供与“5101352”相匹配的价格&库存,您可以联系我们找货
