5101429
5101429
    HAPCO
    HEATER TYPE S-36, 230V/2300W, FO
5101429 数据手册
Data sheet HERZ Air heater type S36 from 1,8 to 3,3 KW Air heater with external air supply by means of fan or compressed air. CAUTION !!! Device is not pressure-resistant !!! Function: Configuration: Default: Temperature control with potentiometer (1 – 8) - alternatively with external potentiometer (cable length 5 meter) or - external control by control unit or SPS (cable length 5 meter) The device is equipped with a reliable heating element protection. The integrated device protection turns off the device when tripped and resets automatically after cooling down. A reset is not required. Special design with internal thermocouple (cable length 1 or 5 meter): - for devices with electronic equipment max. supply air temperature 50°C122°F - the unit is available without electronics (without heating element protection) - for devices without electronic equipment max. supply air temperature 80°C/176°F Features: Power: Voltage: 1,8 KW - 3,3 KW 120VAC, 230 VAC Technical data: Item number / Basic versions Voltage Frequency Power Current Max. temperature Min. air volume Weight Air intake Air outlet Heater tube Dimensions Potentiometer external control without electronic VAC Hz KW A °C/°F l/min kg Ø mm Ø mm Ø mm mm (L x W x H) 5700122 on request on request 5101436 on request on request 5101428 5101429 5101410 120 1,8 15,0 5101426 5101382 5101434 230 50 / 60 2,2 18,3 2,3 10,0 14,3 on request on request 5101440 400 (2Ph) on request on request 5101439 480 (2Ph) 3,3 8,3 6,9 650/1202 230 280 420 0,47 19 22 36 / 43 241 x 70 x 59 Conformity mark Protection class II DB S36 V20 R18 02_2021 GB.docx Technical changes reserved 1 Data sheet HERZ Air heater type S36 from 1,8 to 3,3 KW Product description: Connection scheme: 6 Default with potentiometer External control N, L1 = Main connection according to data plate N, L1 = Main connection according to data plate 5 7 1 2 3 +/control cable 4 1. Cable fitting mains supply 2. Potentiometer 0-8 (control cable for ext. control); (no Potentiometer for devices without electronic) 3. Mounting on bottom of housing M 4 (screw depth 7 mm) 4. Heating element pipe Ø36mm 5. Cover 6. Data plate 7. Air intake Ø19mm DB S36 V20 R18 02_2021 GB.docx Digital signal (PWM max. 0,5Hz) 10-24VDC + = brown - = white Version without electronics N, L1 = Main connection according to data plate Technical changes reserved 2 Data sheet HERZ Air heater type S36 from 1,8 to 3,3 KW Avaiable Versions: Item no. 5700122 5101436 5101428 5101429 5101410 5101426 5101382 5101434 5101440 5101439 Description Air heater type S36 120 VAC 1,8 KW with potentiometer Air heater type S36 120 VAC 2,2 KW with potentiometer Air heater type S36 230 VAC 2,3 KW with potentiometer Air heater type S36 230 VAC 2,3 KW externally controllable (PWM 12-24 VDC, 1 Hz) with 5.0m control cable (2-pin) Air heater type S36 230 VAC 2,3 KW without electronics Air heater type S36 230 VAC 3,3 KW with potentiometer Air heater type S36 230 VAC 3,3 KW externally controllable (PWM 12-24 VDC, 1 Hz) with 5.0m control cable (2-pin) Air heater type S36 230 VAC 3,3 KW without electronics Air heater type S36 400 VAC (2Ph) 3,3 KW without electronics Air heater type S36 480 VAC (2Ph) 3,3 KW without electronics Available modifications: Artikelnummer Typ 5005005.1 S02 5005021.3 5005010.3 5005007 S05 S06 S12 5005019 S13 5005036.2 5700141 S23 S31 DB S36 V20 R18 02_2021 GB.docx Modifikation The basic device for this modification is External potentiometer for heating including 5m control line; 3 pole; always standard with a potentiometer Potentiometer is soldered to the end of the cable; including potentiometer knob red; Internal PID control via internal potentiometer without digital display; Internal thermocouple including 2m compensation cable with open ends green (+) white (-); A push-in nipple for air hose 8/6mm is mounted on the air connection Instead of the potentiometer for devices WITHOUT electronics, a 1/4 "compressed air hose connection 6/4mm is installed; This is used to monitor the pressure in the housing; Device with tube adapter without protective tube; Standard is with protective tube; 100% heating output with heating element protection for type S/M (for basic device without electronics); Technical changes reserved 3 Data sheet HERZ Air heater type S36 from 1,8 to 3,3 KW Accessories: Item no. Description 5107250 Flange connector, push fit on the protective tube 5107155 Tubular nozzle ø 5mm 5107003 Angle nozzle 90°, ø 12mm 5107251 Extension tube 210 x 36,5mm 5107261 Wide slot nozzle 70 x 4mm Combination possibilities for devices WITH electronic*: Measuring point: Hose length: Air supply: Air flow: 3.0 mm after the air outlet pipe adapter – without nozzle, measured at the hottest point 1,0 mr Blower 400 Volt, 50 Hz (HD = High pressure blower, MD = Medium pressure blower) Nl / min = standard liters per minute according to DIN 1343 CAUTION: Air flow and temperature are indicative which can change due to external influences and changes air hose diameter and length! Blower type HD140 HD140 HD240 Quantity, air heater type, voltage, power 1 x S36; 230VAC; 2,3KW 2 x S36; 230VAC; 2,3KW 4 x S36; 230VAC; 2,3KW 1 x S36; 230VAC; 3,3KW 2 x S36; 230VAC; 3,3KW 4 x S36; 230VAC; 3,3KW Air flow at 50 Hz with heating [Nl / min.] 680 2 x 500 4 x 310 630 2 x 480 4 x 660 Maximum temperature at 50 Hz [°C/°F] 340/644 400/752 540/104 450/842 520/968 380/716 *Data without guarantee DB S36 V20 R18 02_2021 GB.docx Technical changes reserved 4 Data sheet HERZ Air heater type S36 from 1,8 to 3,3 KW DB S36 V20 R18 02_2021 GB.docx Technical changes reserved 5 Data sheet HERZ Air heater type S36 from 1,8 to 3,3 KW HERZ GmbH HERZ GmbH Kunststoff- & Wärmetechnologie Biberweg 1 DE – 56566 Neuwied Tel.: +49 (0)2622-8855-0 Fax: +49 (0)2622-8855-135 Fax: +49 (0)2622-8855-136 www.herz-gmbh.com info@herz-gmbh.com Kunststoff- & Wärmetechnologie Am Arenberg 26A DE – 86456 Gablingen Tel.: +49 (0)8230-85085 Fax: +49 (0)8230-85087 www.herz-gmbh.com robert.einberger@herz-gmbh.com HERZ Austria GmbH HERZ Austria GmbH Kunststoff- & Wärmetechnologie Gleinser Weg 27 AT – 6141 Schönberg / Tirol Tel.: +43 (0)5225-63113 Fax: +43 (0)5225-6311385 www.herz-austria.at herz.schoenberg@herz-gmbh.com Kunststoff- & Wärmetechnologie Johann-Galler-Str. 20 IZ – NÖ – Nord AT – 2120 Wolkersdorf i. Weinviertel Tel.: +43 (0)2245-82494-0 Fax: +43 (0)2245-82494-9 www.herz-austria.at herz.wolkersdorf@herz-gmbh.com HERZ Hungária Kft. HERZ Polska Sp.z o. o. Technologie obróbki tworzyw sztucznych Ul. Kostrzyńska 30 PL – 02-979 Warzawa Tel.: +48 (0)22-8428583 Fax: +48 (0)22-8429700 www.herz-polska.pl herz@herz-polska.pl Műanyag- es hőlégtechnika Pesti út 284 HU – 2225 Üllö Tel.: +36 (06)29-522400 Fax: +36 (06)29-522410 www.herz-hungaria.hu herz@herz-hungaria.hu HERZ Bulgaria OOD Boul. Assen Yordanov 10 BG – 1592 Sofia Tel.: +359 (0)2-979035 www.herz-bulgaria.com office@herz-bulgaria.com © by HERZ GmbH DB S36 V20 R18 02_2021 GB.docx Technical changes reserved 6
5101429 价格&库存
很抱歉,暂时无法提供与“5101429”相匹配的价格&库存,您可以联系我们找货
