5202423
5202423
    HAPCO
    HEATER TYPE XS-20L, 460V/2000W W
5202423 数据手册
Data sheet HERZ Air heater type XS20 from 0,45 KW to 2,0 KW Function: Air heater with external air supply via compressed air Configuration: In series with thermocouple typ ‚K’ Length of connecting cable and thermocouple cable = 1,5 Meter Features: Case with high-grade steel, brass cable gland - chromed Air hose per meter available Exhaust opening M16 female thread Power: 0,45 KW, 0,8 KW, 1,0 KW, 1,5 KW, 2,0 KW Voltage: 120 VAC, 230 VAC, 460 VAC Special voltage on request Technical data: .Type Item number Voltage Frequency Performance Power Max. temperature Min. airflow Max. air pressure Thermocouple Weight Air connection Exhaust opening Dimensions VAC Hz KW A °C/°F l/min bar Typ kg Ø mm Ø mm mm(L x Ø) 5202413 120 5202412 230 XS20 5202415 5202414 120 230 0,45 3,75 0,8 1,95 30 5202417 120 7,0 5202416 230 50 / 60 5202419 120 4,4 650/1202 12,5 1,0 3,5 60 8,3 5202418 230 XS20L 5202421 120 5202420 230 5202423 460 6,5 16,7 2,0 8,8 4,4 1,5 75 100 150 6,0 ‚K’ 0,4 0,5 Push-In Clip 6mm M16 female thread; wrench size 17 286 x 30 343 x 30 Conformity mark Protection class I DB XS20 V20 R20 03_2021 GB.docx technical changes reserved 1 Data sheet HERZ Air heater type XS20 from 0,45 KW to 2,0 KW Product description: Connection scheme: 4 4 5 1 5 2 1 3 2 3 1. 2. 3. 4. 5. Electric connection cable see on label Thermocouple Air supply Push-In Clip 6mm Exhaust opening M16 IG, SW17 Label DB XS20 V20 R20 03_2021 GB.docx 1. 2. 3. 4. 5. technical changes reserved L1 Netzanschluss Electric connection cable seen on label lt. Typenschild N Earth conductor Thermocouple type „K“ (green = +) Thermocouple type “K” (white = -) 2 Data sheet HERZ Air heater type XS20 from 0,45 KW to 2,0 KW Available Versions: Item-No. 5202413 5202412 5202415 5202414 5202417 5202416 5202419 5202418 5202421 5202420 5202423 Description Air heater type XS20 120VAC 0,45KW with thermocouple Air heater type XS20 230VAC 0,45KW with thermocouple Air heater type XS20 120VAC 0,8KW with thermocouple Air heater type XS20 230VAC 0,8KW with thermocouple Air heater type XS20 120VAC 1,0KW with thermocouple Air heater type XS20 230VAC 1,0KW with thermocouple Air heater type XS20L 120VAC 1,5KW with thermocouple Air heater type XS20L 230VAC 1,5KW with thermocouple Air heater type XS20L 120VAC 2,0KW with thermocouple Air heater type XS20L 230VAC 2,0KW with thermocouple Air heater type XS20L 460VAC(2Ph) 2,0KW with thermocouple Accessories: Item.-No. Description 5800166 Tube nozzle d = 5mm with M16 thread for air heater type XS20 5202408 Digital controller with logic output; type ETR48-24; 240VAC 5202406 Power semiconductor relais without heat sink 230VAC 12A (Stearing 12V) 5202407 Heat sink for power semiconductor relais (5202406) DB XS20 V20 R20 03_2021 GB.docx technical changes reserved 3 Push in clip Data sheet HERZ Air heater type XS20 from 0,45 KW to 2,0 KW DB XS20 V20 R20 03_2021 GB.docx technical changes reserved 4 Data sheet HERZ Air heater type XS20 from 0,45 KW to 2,0 KW HERZ GmbH HERZ GmbH Kunststoff- & Wärmetechnologie Biberweg 1 DE – 56566 Neuwied Tel.: +49 (0)2622-8855-0 Fax: +49 (0)2622-8855-135 Fax: +49 (0)2622-8855-136 www.herz-gmbh.com info@herz-gmbh.com Kunststoff- & Wärmetechnologie Am Arenberg 26A DE – 86456 Gablingen Tel.: +49 (0)8230-85085 Fax: +49 (0)8230-85087 www.herz-gmbh.com robert.einberger@herz-gmbh.com HERZ Austria GmbH HERZ Austria GmbH Kunststoff- & Wärmetechnologie Gleinser Weg 27 AT – 6141 Schönberg / Tirol Tel.: +43 (0)5225-63113 Fax: +43 (0)5225-6311385 www.herz-austria.at herz.schoenberg@herz-gmbh.com Kunststoff- & Wärmetechnologie Johann-Galler-Str. 20 IZ – NÖ – Nord AT – 2120 Wolkersdorf i. Weinviertel Tel.: +43 (0)2245-82494-0 Fax: +43 (0)2245-82494-9 www.herz-austria.at herz.wolkersdorf@herz-gmbh.com HERZ Hungária Kft. HERZ Polska Sp.z o. o. Műanyag- es hőlégtechnika Pesti út 284 HU – 2225 Üllö Tel.: +36 (06)29-522400 Fax: +36 (06)29-522410 www.herz-hungaria.hu herz@herz-hungaria.hu Technologie obróbki tworzyw sztucznych Ul. Kostrzyńska 30 PL – 02-979 Warzawa Tel.: +48 (0)22-8428583 Fax: +48 (0)22-8429700 www.herz-polska.pl herz@herz-polska.pl HERZ Bulgaria OOD Boul. Assen Yordanov 10 BG – 1592 Sofia Tel.: +359 (0)2-9790351 www.herz-bulgaria.com office@herz-bulgaria.com © by HERZ GmbH DB XS20 V20 R20 03_2021 GB.docx technical changes reserved 5
5202423 价格&库存
很抱歉,暂时无法提供与“5202423”相匹配的价格&库存,您可以联系我们找货
