09100123100
09100123100
    HARTING(浩亭)
    母头 插件 黑色 12 位置 压接
09100123100 数据手册
Product data sheet 09 10 012 3100 Han 1A-12-c-f latch This product is not orderable anymore. Contact your local distribution partner for alternatives. Han 1A-12-c-f latch Part number 09 10 012 3100 Specification Han 1A-12-c-f latch HARTING eCatalogue https://b2b.harting.com/09100123100 Image is for illustration purposes only. Please refer to product description. Identification Category Inserts Series Han® 1A Version Termination method Crimp termination Gender Female Locking type Snap-in latches Size 1A Number of contacts 12 Details Please order crimp contacts separately. Order separately the single wire seal or the hoods/housings for an IP65 performance. Details A Han® 1A configuration that only consists of inserts (with or without strain relief, 09 10 000 5300) is an unenclosed connector. In this case protection against electric shock must be provided by the installation methods of the user. Contact inserts must not be coupled or decoupled under electrical load. Contact inserts must not be powered-up in the un-mated condition. Technical characteristics Conductor cross-section 0.09 ... 0.52 mm² Rated current 6.5 A Rated voltage 50 V Rated impulse voltage 0.8 kV Pollution degree 3 Insulation resistance >108 Ω Page 1 / 2 | Creation date 2021-05-20 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electric GmbH & Co. KG | Wilhelm-Harting-Straße 1 | 32339 Espelkamp | Germany Phone +49 5772 47-97100 | electric@HARTING.com | www.HARTING.com Product data sheet 09 10 012 3100 Han 1A-12-c-f latch This product is not orderable anymore. Contact your local distribution partner for alternatives. Technical characteristics Limiting temperature -30 ... +90 °C Mating cycles ≥100 Degree of protection acc. to IEC 60529 IP20 Material properties Material (insert) Polyamide (PA) Colour (insert) RAL 9005 (jet black) Material (seal) NBR Colour (seal) Black Material flammability class acc. to UL 94 V-0 RoHS compliant ELV status compliant China RoHS e REACH Annex XVII substances No REACH ANNEX XIV substances No REACH SVHC substances No Specifications and approvals Specifications EN 45545-2 R22: HL1, HL2, HL3 EN 45545-2 R23: HL1, HL2, HL3 EN 45545-2 R24: HL1, HL2, HL3 IEC 61373 Category 1 Class B EN 60664-1 Approvals DNV GL Commercial data Packaging size 1 Net weight 8.72 g Country of origin Germany European customs tariff number 85366990 eCl@ss 27440205 Contact insert for industrial connectors Page 2 / 2 | Creation date 2021-05-20 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electric GmbH & Co. KG | Wilhelm-Harting-Straße 1 | 32339 Espelkamp | Germany Phone +49 5772 47-97100 | electric@HARTING.com | www.HARTING.com
09100123100
物料型号:09100123100
器件简介:Han 1A系列的12针脚的Han 1A-12-c-f型卡扣式连接器,现已不可订购,可联系当地分销商寻求替代品。
引脚分配:共有12个接触点,需要单独订购压接接触件。
参数特性: - 导体截面积:0.09至52mm² - 额定电流:6.5A - 额定电压:50V - 额定脉冲电压:0.8kV - 污染等级:3 - 绝缘电阻:大于10MΩ
功能详解:Han 1A-12-c-f型卡扣式连接器采用卡扣固定方式,适用于工业连接,提供IP20防护等级,适用于多种电气特性。
应用信息:适用于工业连接器的接触插入件,需遵守相关电气安全规定和法规。
封装信息: - 材料:插入件为聚酰胺(PA),密封件为丁腈橡胶(NBR) - 颜色:插入件为RAL 9005(黑色),密封件为黑色 - 材料阻燃等级:UL 94 V-0 - 符合RoHS和ELV指令 - 符合中国RoHS要求
09100123100 价格&库存
很抱歉,暂时无法提供与“09100123100”相匹配的价格&库存,您可以联系我们找货
  • 1+44.998641+5.77156
库存:7
