73101000002
73101000002
    HARTING(浩亭)
    10+接地 电缆和面板连接器组件 侧防护罩,底部基座 M25 螺钉
73101000002 数据手册
Han® Kits Technical Characteristics Part Number Han 10B Rear-Mount ECO Kit Hood Housing Material IP / NEMA Temp Rating Cable Gland Cable Diameter Insert Screw Terminals Wire Strip Length Mating Cycles Flammability Angled Entry Double Lever Bulkhead Polyamide Plastic IP65 / 4, 4x, 12 -40 to +125C M25 Plastic 9 -17mm Han 10E, 10+GND 18-14AWG 7.5mm >500 V-0 73 10 100 0002 Electrical Characteristics Rated Current Rated Voltage Rated Impulse Voltage 16amps 600V 6kV Drawings and Assembly Information Dimensions in mm Tooling and Torque Values Type Terminal Screws (M3) Fixing Screw (M3) Tool Torque (Nm) PH1 or Slotted 0.50 0.6 x 3.5 PH2 or Slotted 0.50 0.6 x 3.5 Mounting Screws (M4 recommended) - 0.8…1.0 Cable Gland (M25) SW29 10 Kit Contents For further information, please reach out to techsupportUS@HARTING.com Male Insert 09 33 010 2601 Female insert 09 33 010 2701 Housing 19 43 010 0320 Hood & Gland 19 43 110 0526
73101000002 价格&库存
很抱歉,暂时无法提供与“73101000002”相匹配的价格&库存,您可以联系我们找货
