73101000005
73101000005
    HARTING(浩亭)
    6+接地 电缆和面板连接器组件 侧防护罩,底部基座 M25 螺钉
73101000005 数据手册
Han® Kits Technical Characteristics Part Number Han 6B Rear-Mount Kit Hood Housing Material IP / NEMA Temp Rating Cable Gland Cable Diameter Insert Screw Terminals Wire Strip Length Mating Cycles Flammability Side Entry Single Lever Bulkhead Die Cast Aluminum IP66 / 4, 4x, 12 -40 to +125C M25 Metal 9-16mm / 13-18mm Han 6E, 6+GND 18-14AWG 7.5mm >500 V-0 73 10 100 0005 Electrical Characteristics Rated Current Rated Voltage Rated Impulse Voltage 16amps 600V 6kV Drawings and Assembly Information Dimensions in mm Tooling and Torque Values Type Terminal Screws (M3) Fixing Screw (M3) Tool Torque (Nm) PH1 or Slotted 0.50 0.6 x 3.5 PH2 or Slotted 0.50 0.6 x 3.5 Mounting Screws (M4 recommended) - 0.8…1.0 Cable Gland (M25) SW 30 12 Kit Contents For further information, please reach out to techsupportUS@HARTING.com Male Insert 09 33 006 2601 Female insert 09 33 006 2701 Housing 09 30 006 0391 Hood 19 30 006 0546 Cable Gland 19 00 000 5091
73101000005 价格&库存
很抱歉,暂时无法提供与“73101000005”相匹配的价格&库存,您可以联系我们找货
