73101000006
73101000006
    HARTING(浩亭)
    10+接地 电缆和面板连接器组件 侧防护罩,底部基座 M25 螺钉
73101000006 数据手册
Han® Kits Technical Characteristics Part Number Han 10B Rear-Mount Kit Hood Housing Material IP / NEMA Temp Rating Cable Gland Cable Diameter Insert Screw Terminals Wire Strip Length Mating Cycles Flammability Side Entry Double Lever Bulkhead Die Cast Aluminum IP66 / 4, 4x, 12 -40 to +125C M25 Metal 9-16mm / 13-18mm Han 10E, 10+GND 18-14AWG 7.5mm >500 V-0 73 10 100 0006 Electrical Characteristics Rated Current Rated Voltage Rated Impulse Voltage 16amps 600V 6kV Drawings and Assembly Information Dimensions in mm Tooling and Torque Values Type Terminal Screws (M3) Fixing Screw (M3) Tool Torque (Nm) PH1 or Slotted 0.50 0.6 x 3.5 PH2 or Slotted 0.50 0.6 x 3.5 Mounting Screws (M4 recommended) - 0.8…1.0 Cable Gland (M25) SW 30 12 Kit Contents For further information, please reach out to techsupportUS@HARTING.com Male Insert 09 33 010 2601 Female insert 09 33 010 2701 Housing 09 30 010 0391 Hood 19 30 010 0526 Cable Gland 19 00 000 5091
73101000006 价格&库存
很抱歉,暂时无法提供与“73101000006”相匹配的价格&库存,您可以联系我们找货
