73101000010
73101000010
    HARTING(浩亭)
    6+接地 电缆和面板连接器组件 侧防护罩,底部基座 M32 螺钉
73101000010 数据手册
Han® Kits Technical Characteristics Part Number Han HsB Power Kit Hood Housing Material IP / NEMA Temp Rating Cable Gland Cable Diameter Insert Screw Terminals Wire Strip Length Mating Cycles Flammability Side Entry Double Lever Bulkhead Die Cast Aluminum IP66 / 4, 4x, 12 -40 to +125C M32 Metal 13-18mm / 18-25mm 6 +GND 16–10AWG 11.5mm >500 V-0 73 10 100 0010 Electrical Characteristics Rated Current Rated Voltage Rated Impulse Voltage 35A 600V 6kV Drawings and Assembly Information Dimensions in mm Tooling and Torque Values Type Terminal Screws (M3) Fixing Screw (M3) Tool Torque (Nm) PH1 or Slotted 1.20 0.6 x 3.5 PH2 or Slotted 0.50 0.6 x 3.5 Mounting Screws (M4 recommended) - 0.8…1.0 Cable Gland (M32) SW 40 15 Kit Contents For further information, please reach out to techsupportUS@HARTING.com Male Insert 09 31 006 2601 Female insert 09 31 006 2701 Housing 09 30 016 0391 Hood 19 30 016 0527 Cable Gland 19 00 000 5095
73101000010 价格&库存
很抱歉,暂时无法提供与“73101000010”相匹配的价格&库存,您可以联系我们找货
  • 1+2473.243681+317.22007
  • 10+2102.5953010+269.68044
  • 25+1971.1348225+252.81922
库存:7
