73101000011
73101000011
    HARTING(浩亭)
    HAN-KIT - K6/6, METAL, DOUBLE LE
73101000011 数据手册
Han® Kits Technical Characteristics Part Number Han K6/6 Power Kit Hood Top Entry Housing Double Lever Bulkhead Material Die Cast Aluminum IP / NEMA IP67 / 4, 4x, 12 Temp Rating -40 to +125C Cable Gland M40 Metal Cable Diameter 20-26mm / 22-32mm Insert 6(power)+6(signal) +GND Screw Terminals 5-2AWG / 24-13AWG 13-14mm (power) Wire Strip Length 7.5mm (signal) Mating Cycles >500 Flammability V-0 73 10 100 0011 Electrical Characteristics Rated Current Rated Voltage Rated Impulse Voltage 100A / 16A 600V 8kV Drawings and Assembly Information Dimensions in mm Tooling and Torque Values Type Tool Torque (Nm) Terminal Screws See HARTING E-Catalogue (M3) Fixing Screw PH2 or Slotted 0.50 (M3) 0.6 x 3.5 Mounting Screws 0.8…1.0 (M4 recommended) Cable Gland (M40) SW 50 15 Kit Contents For further information, please reach out to techsupportUS@HARTING.com Male Insert 09 38 012 2651 Female insert 09 38 012 2751 Housing 09 30 024 1301 Hood 19 30 024 0428 Cable Gland 19 00 000 5099 NOTE: Fine stranded wire required for axial screw termination
73101000011 价格&库存
很抱歉,暂时无法提供与“73101000011”相匹配的价格&库存,您可以联系我们找货
  • 1+3804.292021+492.78887
  • 10+3234.3346210+418.95945
  • 25+3085.2779925+399.65141
库存:23
