73101000015
73101000015
    HARTING(浩亭)
    连接器套件 Han 10B Eco
73101000015 数据手册
Han® Kits Technical Characteristics Part Number Han 10B Ethernet/Power/Signal Kit Hood Side Entry Housing Double Lever Bulkhead Material Die Cast Aluminum IP / NEMA IP67 / 4, 4x, 12 Temp Rating -40 to +125C Cable Gland M32 Metal Cable Diameter Insert Termination (Rj45 / Signal) 13-20 / 18-25mm See “Kit Contents” 73 10 100 0015 IDC/Axial Screw/Quicklock Electrical Characteristics Ethernet Cat.6 (8 wire) Power 3 x (40A / 600V) Signal 12 x (10A / 600V) Drawings and Assembly Information Dimensions in mm Kit Contents Male Rj45 Female Rj45 Male Signal Module Female Signal Module Male Power Module Female Power Module Hinged Frame 1 Hinged Frame 2 Housing Hood Cable Gland For further information, please reach out to techsupportUS@HARTING.com 09 45 400 1560 09 14 001 4623 09 14 001 4721 09 14 012 2632 09 14 012 2732 09 14 003 2601 09 14 003 2701 09 14 010 0361 09 14 010 0371 09 30 010 1301 19 30 010 0527 19 00 000 5095 NOTE: See “Kit Contents” for individual module part numbers. All part numbers are available on the HARTING B2B E-Catalogue. See website for detailed specifications and drawings. Fine stranded wire required for Quicklock and Axial screw termination
73101000015 价格&库存
很抱歉,暂时无法提供与“73101000015”相匹配的价格&库存,您可以联系我们找货
