73101000032
73101000032
    HARTING(浩亭)
    24+接地 电缆和面板连接器组件 侧防护罩,底部基座 M32 压接
73101000032 数据手册
Han® Kits Technical Characteristics Part Number Han 24DD Signal Kit Hood Housing Material Side Entry Single Lever Bulkhead Die Cast Aluminum IP / NEMA IP67 / 4, 4x, 12 Temp Rating -40 to +125C Cable Gland M32 Metal Cable Diameter 13-20mm / 18-25mm Insert Han 24DD, 24+GND Sold separately Han D Contacts >500 Crimp Terminals Mating Cycles Flammability 73 10 100 0032 V-0 Electrical Characteristics Rated Voltage Rated Impulse Voltage 10A 600V 4kV Drawings and Assembly Information Dimensions in mm Tooling and Torque Values Type Tool Fixing Screw PH2 or Slotted (M3) 0.6 x 3.5 Mounting Screws (M4 recommended) Cable Gland (M32) SW 40 Torque (Nm) 0.50 0.8…1.0 15 Crimp Contacts Tooling Male Female 26-22 09 15 000 6107 09 15 000 6207 20 09 15 000 6103 09 15 000 6203 18 09 15 000 6102 09 15 000 6202 16 09 15 000 6101 09 15 000 6201 14 09 15 000 6106 09 15 000 6206 Crimp Removal Tool Tool 09 99 000 0888* AWG 09 99 000 0012 Rated Current *Alternative tooling options available Kit Contents Male Insert Female insert Housing Hood Cable Gland For further information, please reach out to techsupportUS@HARTING.com 09 16 024 09 16 024 09 30 006 19 30 006 19 00 000 3001 3101 1301 0547 5095 Guide pins and bushings recommended 09 33 000 9908 & 09 33 000 9909
73101000032 价格&库存
很抱歉,暂时无法提供与“73101000032”相匹配的价格&库存,您可以联系我们找货
