73101000034
73101000034
    HARTING(浩亭)
    72+接地 电缆和面板连接器组件 侧防护罩,底部基座 M40 压接
73101000034 数据手册
Han® Kits Technical Characteristics Part Number Han 72DD Signal Kit Hood Side Entry Housing Double Lever Bulkhead Material Die Cast Aluminum IP / NEMA IP67 / 4, 4x, 12 Temp Rating -40 to +125C Cable Gland M40 Metal Cable Diameter 20-26mm / 22-32mm Insert Han 72DD, 72+GND Sold separately Han D Contacts >500 Crimp Terminals Mating Cycles Flammability 73 10 100 0034 V-0 Electrical Characteristics Rated Current 10A Rated Voltage 600V Rated Impulse Voltage 4kV Drawings and Assembly Information Dimensions in mm Tooling and Torque Values Type Tool Torque (Nm) Fixing Screw PH2 or Slotted 0.50 (M3) 0.6 x 3.5 Mounting Screws 0.8…1.0 (M4 recommended) SW 50 AWG Male Female 26-22 20 18 16 14 09 15 000 6107 09 15 000 6103 09 15 000 6102 09 15 000 6101 09 15 000 6106 09 15 000 6207 09 15 000 6203 09 15 000 6202 09 15 000 6201 09 15 000 6206 Tooling Crimp Removal Tool Tool 09 99 000 0012 Crimp Contacts 15 09 99 000 0888* Cable Gland (M40) *Alternative tooling options available Kit Contents Male Insert Female insert Housing Hood Cable Gland For further information, please reach out to techsupportUS@HARTING.com 09 16 072 09 16 072 09 30 016 19 30 016 19 00 000 3001 3101 1301 0528 5099 Guide pins and bushings recommended 09 33 000 9908 & 09 33 000 9909
73101000034 价格&库存
很抱歉,暂时无法提供与“73101000034”相匹配的价格&库存,您可以联系我们找货
  • 1+1651.037321+211.76327
  • 10+1403.4981810+180.01372
  • 25+1315.7220925+168.75549
  • 50+1253.0219550+160.71353
库存:7
