09390009902
09390009902
    HARTING(浩亭)
    连接器 安装法兰
09390009902 数据手册
Han ® HP Direct EMC Sizes 6 B, 10 B, 16 B, 24 B Features Technical characteristics • System of hoods without using a bulkhead mounted housing on the device side • Hoods in sizes 6 B, 10 B, 16 B and 24 B • Suitable for all inserts Han ® B • Top and side entry ranging from M20 to M40 for all sizes • Optional coding by means of two coding elements • Panel cut-outs compatible with standard Han ® B panel cut-outs • High EMC resistance Specifications DIN EN 61984 DIN EN 60664-1 Hoods Material Colour Surface aluminium die-cast unpainted - top coat electrically conductive Locking element Screw locking Material M6 stainless steel Tightening torque 4 Nm Hoods seal NBR (conductive) Mounting flange Material Colour zinc die-cast unpainted Surface electrically conductive Coding element 01 Material Color polycarbonate red -40 °C ... +125 °C Limiting temperatures Protection degree acc. to DIN EN 60529 in locked position IP66 / IP68 / IP69K HARTING Electric GmbH & Co. KG | Wilhelm-Harting-Straße 1 | D-32339 Espelkamp Tel.: +49 5772 47-97100 | Fax: +49 5772 47-495 www.HARTING.com | electric@HARTING.com 2017-03-08 Han® Data Sheet 1163 Han ® HP Direct EMC Sizes 6 B, 10 B, 16 B, 24 B Cable Identification Part number entry Drawing Dimensions in mm Han ® 6 HP Direct EMC Hoods top entry 19 39 806 0445 19 39 806 0446 19 39 806 0447 19 39 806 0448 M20 M25 M32 M40 Panel cut out Han ® 6 HP Direct EMC Hoods side entry 19 39 806 0545 19 39 806 0546 19 39 806 0547 19 39 806 0548 M20 M25 M32 M40 Panel cut out Han ® 10 HP Direct EMC Hoods top entry 19 39 810 0445 19 39 810 0446 19 39 810 0447 19 39 810 0448 M20 M25 M32 M40 Panel cut out Han ® 10 HP Direct EMC Hoods side entry 19 39 810 0545 19 39 810 0546 19 39 810 0547 19 39 810 0548 M20 M25 M32 M40 Panel cut out 02 Han ® HP Direct EMC Sizes 6 B, 10 B, 16 B, 24 B Cable Identification Part number entry Drawing Han ® 16 HP Direct M EMC Hoods top entry 19 39 816 0445 19 39 816 0446 19 39 816 0447 19 39 816 0448 M20 M25 M32 M40 Panel cut out Han ® 16 HP Direct MEMC Hoods side entry 19 39 816 0545 19 39 816 0546 19 39 816 0547 19 39 816 0548 M20 M25 M32 M40 Panel cut out Han ® 24 HP Direct EMC Hoods top entry 19 39 824 0445 19 39 824 0446 19 39 824 0447 19 39 824 0448 M20 M25 M32 M40 Panel cut out Han ® 24 HP Direct EMC Hoods side entry 03 19 39 824 0545 19 39 824 0546 19 39 824 0547 19 39 824 0548 M20 M25 M32 M40 Panel cut out Dimensions in mm Han ® HP Direct EMC Identification Part number Drawing Dimensions in mm Mounting flanges Set of 2 pieces 09 39 000 9902 Coding elements Set of 4 pieces 09 39 000 9903 04
09390009902 价格&库存
很抱歉,暂时无法提供与“09390009902”相匹配的价格&库存,您可以联系我们找货
