19397240546
19397240546
    HARTING(浩亭)
    CONN HOOD SIDE ENTRY SZ24B M25
19397240546 数据手册
Han® HP Direct M Sizes 6 B, 10 B, 16 B, 24 B Features Technical characteristics •  Housings systen without using a bulkheasd mounting housing on the device side • Hoods in size 6 B, 10 B, 16 B and 24 B •  Suitable for all contact inserts Han® B •  Top and side entry from M20 to M40 all sizes •  Optional coding by two coding elements • Panel cut-outs compatible with standard Han® B panel cut-outs • Suitable for extreme environmental conditions Specifications DIN EN 61 984 DIN EN 60 664-1 Hoods Material Colour Surface - top coat aluminium die-cast RAL 9005 (black) powder coated Locking element Screw locking Marerial M6 stainless steel Tightening torque 4 Nm Housing seal FPM Mounting Flange Material Colour zinc die-cast unpainted Surface electrically conductive Coding element Material Color polycarbonat red -40 °C ... +125 °C ASTM B117-09 (500 h) Limit temperature corrosion resistance Protection degree acc. to DIN EN 60 529 in locked position IP66 / IP68 / IP69K HARTING Electric GmbH & Co. KG | Wilhelm-Harting-Straße 1 | D-32339 Espelkamp Tel.: +49 5772 47-97100 | Fax: +49 5772 47-495 www.HARTING.com | electric@HARTING.com Han® 2016-08-17 Data Sheet 1161 Han® HP Direct M Sizes 6 B, 10 B, 16 B, 24 B Cable Identification Part number entry Drawing Han® 6 HP Direct M Hood top entry 19 39 706 0445 19 39 706 0446 19 39 706 0447 19 39 706 0448 M20 M25 M32 M40 Panel cut out Han® 6 HP Direct M Hood side entry 19 39 706 0545 19 39 706 0546 19 39 706 0547 19 39 706 0548 M20 M25 M32 M40 Panel cut out Han® 10 HP Direct M Hood top entry 19 39 710 0445 19 39 710 0446 19 39 710 0447 19 39 710 0448 M20 M25 M32 M40 Panel cut out Han® 10 HP Direct M Hood side entry 19 39 710 0545 19 39 710 0546 19 39 710 0547 19 39 710 0548 M20 M25 M32 M40 Panel cut out Dimensions in mm Han® HP Direct M Sizes 6 B, 10 B, 16 B, 24 B Cable Identification Part number entry Drawing Han® 16 HP Direct M Hood top entry 19 39 716 0445 19 39 716 0446 19 39 716 0447 19 39 716 0448 M20 M25 M32 M40 Panel cut out Han® 16 HP Direct M Hood side entry 19 39 716 0545 19 39 716 0546 19 39 716 0547 19 39 716 0548 M20 M25 M32 M40 Panel cut out Han® 24 HP Direct M Hood top entry 19 39 724 0445 19 39 724 0446 19 39 724 0447 19 39 724 0448 M20 M25 M32 M40 Panel cut out Han® 24 HP Direct M Hood side entry 19 39 724 0545 19 39 724 0546 19 39 724 0547 19 39 724 0548 M20 M25 M32 M40 Panel cut out Dimensions in mm Han® HP Direct M Sizes 6 B, 10 B, 16 B, 24 B Cable Identification Part number entry Mounting Flange Set 2 pieces 09 39 000 9902 Coding element Set 4 pieces 09 39 000 9903 Drawing Dimensions in mm
19397240546 价格&库存
很抱歉,暂时无法提供与“19397240546”相匹配的价格&库存,您可以联系我们找货
