M12 System Cables, A-Coding, 3 poles
Male 3-pole
Technical Characteristic(s)
Coding
Rated voltage
Rated current / contact
Locking type
Contact nut
material/plating
Shielding
Number of contacts
Contact material/plating
Mating cycles
Temperature range
(working and storage)
Conductor insulation
Number of wires / wire
gauge
Conductor cross-section
(mm²)
(AWG)
Cable outer diameter
(metric)
(inches)
Recommended torque
Wrench size (knurled
screw / knurled nut)
Degree of protection
Jacket material
Jacket color
Molding material
Molding material color
Cable Length
Configuration Type
Part Number
PVC
A-coding
250 V
4 A
M12x1
3 poles
PUR
A-coding
250 V
4 A
M12x1
TPE
A-coding
250 V
4 A
M12x1
Brass/Nickel
Brass/Nickel
Brass/Nickel
Unshielded
3
Brass/Gold
≥100
Unshielded
3
Brass/Gold
≥100
Unshielded
3
Brass/Gold
≥100
-25 ... +80 °C
-25 ... +80 °C
-40 ... +80 °C
PVC (bn, bk, bu)
PP (bn, bk, bu)
PP (bn, bk, bu)
3 x 0.34 mm²
3 x 0.34 mm²
3 x 0.33 mm²
0.34 mm²
0.34 mm²
0.33 mm²
AWG 22
AWG 22
AWG 22
4.50 mm ± 0.10 mm
3.85 mm ± 0.15 mm
4.75 mm ± 0.25 mm
0.177 in. ± 0.004 in.
0.152 in. ± 0.006 in.
0.187 in. ± 0.010 in.
0.6 Nm
0.6 Nm
0.6 Nm
15
15
15
IP65 / IP67 when mated
PVC (UL 758/1581)
Yellow
TPU
Black
10.00 m
Straight male to blunt cut
21350100315100
PUR (UL 758/1581)
Yellow
TPU
Black
10.00 m
21350100305100
TPE (UL 758)
Yellow
TPU
Black
10.00 m
21350100325100
很抱歉,暂时无法提供与“21350100305100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+223.3471810+29.02454
