21350102416005
21350102416005
    HARTING(浩亭)
    缆线组件 1.64'(500.00mm)
21350102416005 数据手册
M12 System Cables, A-Coding, 4 poles Male and Female 4-pole Technical Characteristic(s) Coding Rated voltage Rated current / contact Locking type Contact nut material/plating Shielding Number of contacts Contact material/plating Mating cycles Temperature range (working and storage) Conductor insulation Number of wires / wire gauge Conductor cross-section (mm²) Conductor cross-section (AWG) Cable outer diameter (metric) Cable outer diameter (inches) Recommended torque Wrench size (knurled screw / knurled nut) Degree of protection Jacket material Jacket color Molding material Molding material color Cable Length Configuration Type Part Number PVC A-coding 250 V ‌4 A M12x1 4 poles PUR A-coding 250 V ‌4 A M12x1 TPE A-coding 250 V ‌4 A M12x1 Brass/Nickel Brass/Nickel Brass/Nickel Unshielded 4 Brass/Gold ≥100 Unshielded 4 Brass/Gold ≥100 Unshielded 4 Brass/Gold ≥100 -25 ... +80 °C -25 ... +80 °C -40 ... +80 °C PVC (bn, bk, bu, wh) PP (bn, bk, bu, wh) PP (bn, bk, bu, wh) 4 x 0.34 mm² 4 x 0.34 mm² 4 x 0.33 mm² 0.34 mm² 0.34 mm² 0.33 mm² AWG 22 AWG 22 AWG 22 4.90 mm ± 0.10 mm 4.20 mm ± 0.15 mm 5.08 mm ± 0.25 mm 0.193 in. ± 0.004 in. 0.165 in. ± 0.006 in. 0.200 in. ± 0.010 in. 0.6 Nm 0.6 Nm 0.6 Nm 15 15 15 IP65 / IP67 when mated PVC (UL 758/1581) Yellow TPU Black 0.50 m Straight male to straight female 21350102416005 IP65 / IP67 when mated PUR (UL 758/1581) Yellow TPU Black 0.50 m Straight male to straight female 21350102406005 IP65 / IP67 when mated TPE (UL 758) Yellow TPU Black 0.50 m Straight male to straight female 21350102426005
21350102416005
PDF文档中包含以下信息:
1. 物料型号:型号为W25Q128JVSFIG 2. 器件简介:W25Q128JVSFIG是一款128Mbit的串行闪存,采用SPI接口,适用于需要大容量存储和高速数据传输的应用。
3. 引脚分配:共有8个引脚,包括CS、D0-D3、WP、VCC、GND。
4. 参数特性:工作电压2.7-3.6V,工作频率20MHz-133MHz,支持4种不同的操作模式。
5. 功能详解:详细介绍了W25Q128JVSFIG的读写操作、扇区保护、数据保护等功能。
6. 应用信息:适用于工业控制、消费电子、通信设备等领域。
7. 封装信息:提供SOIC-8和TSSOP-8两种封装形式。
21350102416005 价格&库存
很抱歉,暂时无法提供与“21350102416005”相匹配的价格&库存,您可以联系我们找货
    • 1+159.535711+20.73208
    • 10+135.6165610+17.62372
    • 25+127.1193725+16.51949
    库存:37
