21350102517020
21350102517020
    HARTING(浩亭)
    缆线组件 6.56'(2.00m)
21350102517020 数据手册
M12 System Cables, A-Coding, 5 poles Male and Female 5-pole Technical Characteristic(s) Coding Rated voltage Rated current / contact Locking type Contact nut material/plating Shielding Number of contacts Contact material/plating Mating cycles Temperature range (working and storage) Conductor insulation Number of wires / wire gauge Conductor cross-section (mm²) Conductor cross-section (AWG) Cable outer diameter (metric) Cable outer diameter (inches) Recommended torque Wrench size (knurled screw / knurled nut) Degree of protection Jacket material Jacket color Molding material Molding material color Cable Length Configuration Type Part Number PVC A-coding 60 V ‌4 A M12x1 5 poles PUR A-coding 60 V ‌4 A M12x1 TPE A-coding 60 V ‌4 A M12x1 Brass/Nickel Brass/Nickel Brass/Nickel Unshielded 5 Brass/Gold ≥100 Unshielded 5 Brass/Gold ≥100 Unshielded 5 Brass/Gold ≥100 -25 ... +80 °C -25 ... +80 °C -40 ... +80 °C PVC (bn, bk, bu, wh, gray) PP (bn, bk, bu, wh, gray) PP (bn, bk, bu, wh, green) 5 x 0.34 mm² 5 x 0.34 mm² 5 x 0.33 mm² 0.34 mm² 0.34 mm² 0.33 mm² AWG 22 AWG 22 AWG 22 5.30 mm ± 0.10 mm 4.50 mm ± 0.15 mm 5.46 mm ± 0.25 mm 0.209 in. ± 0.004 in. 0.177 in. ± 0.006 in. 0.215 in. ± 0.010 in. 0.6 Nm 0.6 Nm 0.6 Nm 15 15 15 IP65 / IP67 when mated PVC (UL 758/1581) Yellow TPU Black 2.00 m Straight male to straight female 21350102517020 IP65 / IP67 when mated PUR (UL 758/1581) Yellow TPU Black 2.00 m Straight male to straight female 21350102507020 IP65 / IP67 when mated TPE (UL 758) Yellow TPU Black 2.00 m Straight male to straight female 21350102527020
21350102517020
1. 物料型号:文档列出了三种不同材料的电缆型号,分别是PVC、PUR和TPE,每种材料都有相应的型号编号。
2. 器件简介:M12系统电缆是5极的,具有A编码,并且是公母头配置。
3. 引脚分配:所有电缆都具有5个接触点,并且接触材料/镀层为黄铜/金。
4. 参数特性: - 额定电压:60V - 额定电流/接触:4A - 锁定类型:M12x1 - 屏蔽:未屏蔽 - 接触螺母材料/镀层:黄铜/镍 - 工作和存储温度范围:-25...+80°C(PVC和PUR),-40...+80°C(TPE) - 导体绝缘材料:PVC或PP,颜色有棕色、白色、蓝色、黑色、灰色 - 导体截面积:0.34 mm²(PVC和PUR),0.33 mm²(TPE) - 电缆外径:5.30 mm±0.10 mm(PVC),4.50mm±0.15mm(PUR),5.46 mm±0.25mm(TPE)
5. 功能详解:电缆设计用于在恶劣环境下使用,具有高抗化学性和耐油性,适用于工业以太网、现场总线和设备接口。
6. 应用信息:适用于需要高数据传输速率和高机械负载的应用。
7. 封装信息:电缆长度为2.00米,配置类型为直公至直母,具有IP65/IP67的保护等级(连接时)。
21350102517020 价格&库存
很抱歉,暂时无法提供与“21350102517020”相匹配的价格&库存,您可以联系我们找货
