21350300517010
21350300517010
    HARTING(浩亭)
    缆线组件 3.28'(1.00m)
21350300517010 数据手册
M12 System Cables, A-Coding, 5 poles Male 5-pole Technical Characteristic(s) Coding Rated voltage Rated current / contact Locking type Contact nut material/plating Shielding Number of contacts Contact material/plating Mating cycles Temperature range (working and storage) Conductor insulation Number of wires / wire gauge Conductor cross-section (mm²) Conductor cross-section (AWG) Cable outer diameter (metric) Cable outer diameter (inches) Recommended torque Wrench size (knurled screw / knurled nut) Degree of protection Jacket material Jacket color Molding material Molding material color Cable Length Configuration Type Part Number PVC A-coding 60 V ‌4 A M12x1 5 poles PUR A-coding 60 V ‌4 A M12x1 TPE A-coding 60 V ‌4 A M12x1 Brass/Nickel Brass/Nickel Brass/Nickel Unshielded 5 Brass/Gold ≥100 Unshielded 5 Brass/Gold ≥100 Unshielded 5 Brass/Gold ≥100 -25 ... +80 °C -25 ... +80 °C -40 ... +80 °C PVC (bn, bk, bu, wh, gray) PP (bn, bk, bu, wh, gray) PP (bn, bk, bu, wh, green) 5 x 0.34 mm² 5 x 0.34 mm² 5 x 0.33 mm² 0.34 mm² 0.34 mm² 0.33 mm² AWG 22 AWG 22 AWG 22 5.30 mm ± 0.10 mm 4.50 mm ± 0.15 mm 5.46 mm ± 0.25 mm 0.209 in. ± 0.004 in. 0.177 in. ± 0.006 in. 0.215 in. ± 0.010 in. 0.6 Nm 0.6 Nm 0.6 Nm 15 15 15 IP65 / IP67 when mated PVC (UL 758/1581) Yellow TPU Black 1.00 m Angled male to blunt cut 21350300517010 IP65 / IP67 when mated PUR (UL 758/1581) Yellow TPU Black 1.00 m Angled male to blunt cut 21350300507010 IP65 / IP67 when mated TPE (UL 758) Yellow TPU Black 1.00 m Angled male to blunt cut 21350300527010
21350300517010 价格&库存
很抱歉,暂时无法提供与“21350300517010”相匹配的价格&库存,您可以联系我们找货
    • 1+114.372811+14.77586
    • 10+97.2265010+12.56072
    • 25+91.1347325+11.77373
    • 50+86.7845150+11.21172
    • 100+82.64242100+10.67660
    • 250+77.47138250+10.00855
    • 500+73.77747500+9.53134
    • 1000+70.260901000+9.07703
    库存:3
