09400229901
09400229901
    HARTING(浩亭)
    22 HPR SLIM FRAME FOR 4 HC MODUL
09400229901 数据手册
Han® 22 HPR slim Features •  Compact and flat design, thereby space-saving hood and housing • Optimised for up to 4 x Han® HC Modular 250 contacts • Proven characteristics of Han® HPR hood and housing series •  Variable installation possibilities due to separate mounting panels •  External PE termination on hood and surface mounted housing Technical characteristics Specifications DIN EN 61984 DIN EN 60664-1 Hoods Material Colour Surface - top coat Locking element - Screw locking - Material - Tightening torque aluminium die-cast RAL 9005 (black) powder coated M6 stainless steel 4 Nm Hoods/housings seal NBR Tightening torque external PE connection 15 Nm Frame Material Number of contacts stainless steel 4 pin for Han® HC Modular 250 Tightening torque fixing screw 0.5 Nm Mounting panels Material stainless steel Tightening torque fixing screw 6 Nm Limiting temperatures Protection degree acc. DIN EN 60529 in locked position Electrical data acc. to DIN EN 61984 for Han® HC Modular 250 Rated current Rated voltage Rated impulse voltage Pollution degree -40 °C ... +125 °C IP66 / IP68 / IP69K 250 A 2000 V 12 kV 3 250 A 2000 V 12 kV 3 HARTING Electric GmbH & Co. KG | Wilhelm-Harting-Straße 1 | D-32339 Espelkamp Tel.: +49 5772 47-97100 | Fax: +49 5772 47-495 www.HARTING.com | electric@HARTING.com Han® 2017-05-03 Data Sheet 1165 Han® 22 HPR slim Cable Identification Part number entry Han® 22 HPR slim Hood top entry 19 40 022 0470 4 x M20 19 40 022 0970 4 x M20 09 40 022 9901 - 09 40 022 9902 - Han® 22 HPR slim Surface mounted housing top entry Frame for male inserts Han® HC Modular 250 4 pins Frame for female inserts Han® HC Modular 250 4 pins Drawing Dimensions in mm Han® 22 HPR slim Identification Part number Drawing Dimensions in mm Mounting panels Set of 2 pieces 09 40 022 9920
09400229901 价格&库存
很抱歉,暂时无法提供与“09400229901”相匹配的价格&库存,您可以联系我们找货
