B15P1PD--H9B000113U1930 数据手册
SMD Type Photo Diode
Harvatek Surface Mount Photo Diode Data Sheet
Official Product
HT Part No. B15P1PD--H9B000113U1930 Customer Part No.
Tentative Product
Specifications are subject to changes for improvement without
advance notice. Proprietary data, drawings, company confidential
all rights reserved.
Data Sheet No.
12/17/2020
Version 1.6
Page 1/14
DISCLAIMER............................................................................................................................ 3
LIFE SUPPORT POLICY ............................................................................................................. 3
PRODUCT SPECIFICATIONS ................................................................................................. 4
ATTENTION: ELECTROSTATIC DISCHARGE (ESD) PROTECTION ................................................ 4
LABEL SPECIFICATIONS ....................................................................................................... 5
ELECTRO-OPTICAL CHARACTERISTICS ............................................................................. 6
PACKAGE OUTLINE DIMENSION AND RECOMMENDED SOLDERING PATTERN FOR REFLOW
SOLDERING ............................................................................................................................. 7
CHARACTERISTICS OF B15P1PD ............................................................................................. 8
PACKAGING .......................................................................................................................... 10
TAPE DIMENSION ................................................................................................................... 10
REEL DIMENSION ................................................................................................................... 11
PACKING ............................................................................................................................... 11
DRY PACK ............................................................................................................................. 12
BAKING................................................................................................................................. 12
PRECAUTIONS ....................................................................................................................... 12
REFLOW SOLDERING .......................................................................................................... 13
REWORKING .......................................................................................................................... 13
CLEANING ............................................................................................................................. 13
CAUTIONS OF PICK AND PLACE .............................................................................................. 14
REVISE HISTORY.................................................................................................................... 14
Official Product
Tentative Product
Data Sheet No.
12/17/2020
Version 1.6
Page 2/14
DISCLAIMER
HARVATEK reserves the right to make changes without further notice to any products herein to
improve reliability, function or design. HARVATEK does not assume any liability arising out of
the application or use of any product or circuit described herein; neither does it convey any
license under its patent rights, nor the rights of others.
Life Support Policy
HARVATEK’s products are not authorized for use as critical components in life support devices
or systems without the express written approval of the President of HARVATEK or HARVATEK
INTERNATIONAL. As used herein:
1. Life support devices or systems are devices or systems which, (a) are intended for surgical
implant into the body, or (b) support or sustain life, and (c) whose failure to perform when
properly used in accordance with instructions for use provided in the labeling, can be
reasonably expected to result in a significant injury of the user.
2. A critical component in any component of a life support device or system whose failure to
perform can be reasonably expected to cause the failure of the life support device or system, or
to affect its safety or effectiveness.
Official Product
Tentative Product
Data Sheet No.
12/17/2020
Version 1.6
Page 3/14
Product Specifications
Item
Specification
Material
Spectral Bandwidth
700nm~1100nm
λD
@ VR =5V ;TS = 25℃
Peak Sensitivity
940nm
λP
@VR =5V;TS=25℃
Reverse Light Current
5.7uA~16uA
IL
@ VR=5V ;Ee = 1mW/cm ;λP=940nm
Resin
Black
Epoxy
Carrier tape
EIA 481-1A specs
Conductive black tape
Reel
EIA 481-1A specs
Conductive black
Label
HT standard
Paper
Packing bag
220x240mm
Aluminum laminated bag/
Quantity
2
One reel per bag
no-zipper
Carton
HT standard
Paper
Non-specified
Others:
Each immediate box consists of 5 reels. The 5 reels may not necessarily have the same lot number or the same bin
combinations of Iv, CIE and Vf. Each reel has a label identifying its specification; the immediate box consists of a product
label as well.
Note :This is shipped test conditions
※Remarks: This product should be operated in forward bias. If a reverse voltage is continuously applied to the product,
such operation can cause migration resulting in LED damage.
ATTENTION: Electrostatic Discharge (ESD) protection
The symbol to the left denotes that ESD precaution is needed. ESD protection for GaP and AlGaAs based
chips and Silicon semiconductor is necessary even though they are relatively safe in the presence of low
static-electric discharge. Parts built with AlInGaP, GaN, or/and InGaN based chips are STATIC SENSITIVE
devices. ESD precaution must be taken during design and assembly.
If manual work or processing is needed, please ensure the device is adequately protected from ESD during the process.
Official Product
Tentative Product
Data Sheet No.
12/17/2020
Version 1.6
Page 4/14
Label Specifications
■Harvatek P/N:
B 15P
Product
1
PD--
Dice Q’ty
H9B
0001
13
Current
Taping
1.
PCB
1:Single
U1930
5V
2.
Package
Color
Series Number
3.2(L)x2.7(W)x1.1(H) mm
PD: Photo Diode
X001~XZZZ
Customer Code
Taping
Customer
style
Product Code
Q’ty
■ Lot No.:
Official Product
Tentative Product
Data Sheet No.
12/17/2020
Version 1.6
Page 5/14
Absolute Maximum Rating at 25℃
Symbol
Parameters
Ratings
Units
35
V
VR
Reverse Voltage
Topr
Operating Temperature
-40 ~ +85
Tstg
Storage Temperature
-40 ~ +100
Tsol
Soldering Temperature
260
Pto
Total Power Dissipation
150
mW
Notes
1
Notes:
1. Soldering time≦5 seconds.
Electro-Optical Characteristics
Symbol
Parameters
Test conditions
Min
Typ
Max
Units
700
1100
nm
940
nm
35
V
λ0.5
Range Of Spectral Bandwidth
λP
Wavelength Of Peak Sensitivity
--Ee=0mW/cm
Notes
2
VBR
Reverse Breakdown Voltage
VOC
Open-Circuit Voltage
Ee=1mW/cm²
0.32
V
ISC
Short-Circuit Current
λP=940nm
5.2
uA
ID
Reverse Dark Current
10
nA
IL
5.7
16
uA
2
tr
Rise Time
VR = 5V,
10
tf
RL=1kΩ
ns
3
Fall Time
10
4.76
CT
Total Capacitance
IR=100uA
Ee=0mW/cm²
VR=10V
Ee=1mW/cm²
λP=940nm, VR=5V
Ee=0mW/cm²
f=1MHz, VR=5V
pF
Notes:
2.
IL Bin Rank::
Bin Code
A
Min
5.7
Max
16
Official Product
Tentative Product
Data Sheet No.
12/17/2020
Version 1.6
Page 6/14
Notes:
3.
Test circuit:
Package Outline Dimension and Recommended Soldering Pattern for Reflow Soldering
(Unit: mm Tolerance: +/-0.1)
Outline Dim.
Soldering Pattern
Soldering terminals may shift in the x, y direction.
Official Product
Tentative Product
Data Sheet No.
12/17/2020
Version 1.6
Page 7/14
Characteristics of B15P1PD
Official Product
Tentative Product
Data Sheet No.
12/17/2020
Version 1.6
Page 8/14
Precaution for Use
1. The chips should not be used directly in any type of fluid such as water, oil, organic solvent,
etc.
2. When the LEDs are illuminating, the maximum ambient temperature should be first
considered before operation.
3. LEDs must be stored in a clean environment. A sealed container with a nitrogen
atmosphere is necessary if the storage period is over 3 months after shipping.
4. The LEDs must be used within 4 weeks after unpacked. Unused products must be
5.
6.
repacked in an anti-electrostatic package, folded to close any opening and then stored in a
dry and cool space.
The appearance and specifications of the products may be modified for improvement
without further notice.
The LEDs are sensitive to the static electricity and surge. It is strongly recommended to
use a grounded wrist band and anti-electrostatic glove when handling the LEDs.If a
voltage over the absolute maximum rating is applied to LEDs, it will damage
LEDs.Damaged LEDs will show some abnormal characteristics such as remarkable
increase of leak current, lower turn-on voltage and getting unlit at low current.
Official Product
Tentative Product
Data Sheet No.
12/17/2020
Version 1.6
Page 9/14
Packaging
Tape Dimension
Dim. A
Dim. B
Dim. C
Q’ty/Reel
3.40±0.1
2.90±0.1
1.30±0.05
3K
Unit: mm
Official Product
Tentative Product
Data Sheet No.
12/17/2020
Version 1.6
Page 10/14
Reel Dimension
Packing
5 or 10 boxes per carton is available depending on shipment quantity.
Official Product
Tentative Product
Data Sheet No.
12/17/2020
Version 1.6
Page 11/14
Dry Pack
All SMD optical devices are MOISTURE SENSITIVE. Avoid exposure to moisture at all times
during transportation or storage. Every reel is packaged in a moisture protected anti-static bag.
Each bag is properly sealed prior to shipment.
A humidity indicator will be included in the moisture protected anti-static bag prior to shipment.
The packaging sequence is as follows:
Baking
Baking before soldering is recommended when the package has been unsealed for 4 weeks.
The conditions are as followings:
1. 60±3℃×(12~24hrs)and
B15P1PD--H9B000113U1930 价格&库存
很抱歉,暂时无法提供与“B15P1PD--H9B000113U1930”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4.763721+0.61662
- 10+3.2429610+0.41977
- 100+2.33199100+0.30186
- 500+1.92039500+0.24858
- 1000+1.784931000+0.23104
- 国内价格 香港价格
- 3000+1.610553000+0.20847
- 6000+1.521676000+0.19697
- 9000+1.476079000+0.19107
- 15000+1.4246115000+0.18440
- 21000+1.3939921000+0.18044
- 30000+1.3641330000+0.17658
