B1701URO-20D000114U1930
    HARVATEK(宏齐)
    红色 631nm LED 指示 - 分立 2V 0805(2012 公制)
B1701URO-20D000114U1930 数据手册
Top Mount Chip LED B1701URO-20D000114U1930 Harvatek Surface Mount CHIP LED Data Sheet B1701URO-20D000114U1930 Official Product HT Part No. B1701URO-20D000114U1930 Tentative Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. **************** 01/13/2021 Version 1.5 Page 1/14 Top Mount Chip LED B1701URO-20D000114U1930 DISCLAIMER ......................................................................................................................................... 3 PRODUCT SPECIFICATIONS............................................................................................................. 4 ATTENTION: ELECTROSTATIC DISCHARGE (ESD) PROTECTION ................................................ 4 LABEL SPECIFICATIONS ................................................................................................................... 5 PRODUCT SPECIFICATIONS............................................................................................................. 6 PRODUCT FEATURES ......................................................................................................................... 7 ELECTRO-OPTICAL CHARACTERISTICS ...................................................................................... 7 PACKAGE OUTLINE DIMENSION AND RECOMMENDED SOLDERING PATTERN FOR REFLOW SOLDERING ............................................................................................................................. 7 ABSOLUTE MAXIMUM RATINGS ................................................................................................. 7 CHARACTERISTICS OF B1701URO ........................................................................................... 8 PRECAUTION FOR USE ...................................................................................................................... 9 PACKAGING ........................................................................................................................................ 10 TAPE DIMENSION ................................................................................................................... 10 REEL DIMENSION ................................................................................................................... 11 PACKING ............................................................................................................................... 11 DRY PACK............................................................................................................................................. 12 BAKING ................................................................................................................................ 12 PRECAUTIONS ....................................................................................................................... 12 REFLOW SOLDERING ...................................................................................................................... 13 REWORKING .......................................................................................................................... 13 CLEANING ............................................................................................................................. 13 REVISE HISTORY.................................................................................................................... 14 Official Product HT Part No. B1701URO-20D000114U1930 Tentative Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. **************** 01/13/2021 Version 1.5 Page 2/14 Top Mount Chip LED B1701URO-20D000114U1930 DISCLAIMER HARVATEK reserves the right to make changes without further notice to any products herein to improve reliability, function or design. HARVATEK does not assume any liability arising out of the application or use of any product or circuit described herein; neither does it convey any license under its patent rights, nor the rights of others. LIFE SUPPORT POLICY HARVATEK’s products are not authorized for use as critical components in life support devices or systems without the express written approval of the President of HARVATEK or HARVATEK INTERNATIONAL. As used herein: 1. Life support devices or systems are devices or systems which, (a) are intended for surgical implant into the body, or (b) support or sustain life, and (c) whose failure to perform when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in a significant injury of the user. 2. A critical component in any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. Official Product HT Part No. B1701URO-20D000114U1930 Tentative Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. **************** 01/13/2021 Version 1.5 Page 3/14 Top Mount Chip LED B1701URO-20D000114U1930 Product Specifications Specification Material Luminous URO:45.0-180.0 mcd Intensity(Iv) @20mA/ Ts= 25 ;Tolerance: + 10% Wavelength URO:625.0-650.0 nm Quantity O O @20mA/ Ts= 25 C;Tolerance: + 0.5nm Vf URO:1.6-2.4V O @20mA/ Ts= 25 C ;Tolerance: + 0.05V Ir < 10 µA @ VR = 5 V Resin Diffused Epoxy resin Carrier tape EIA 481-1A specs Conductive black tape Reel EIA 481-1A specs Conductive black Label HT standard Paper Packing bag 250x230mm Aluminum laminated bag/ no-zipper One reel per bag Carton HT standard Paper Non-specified 4000pcs per reel Others: Each immediate box consists of 5 reels. The 5 reels may not necessarily have the same lot number or the same bin combinations of Iv, λD and Vf. Each reel has a label identifying its specification; the immediate box consists of a product label as well. Note :This is shipped test conditions ※Remarks: This product should be operated in forward bias. If a reverse voltage is continuously applied to the product, such operation can cause migration resulting in LED damage. ATTENTION: Electrostatic Discharge (ESD) protection The symbol to the left denotes that ESD precaution is needed. ESD protection for GaP and AlGaAs based chips is necessary even though they are relatively safe in the presence of low static-electric discharge. Parts built with AlGaInP, GaN, or/and InGaN based chips are STATIC SENSITIVE devices. ESD precaution must be taken during design and assembly. If manual work or processing is needed, please ensure the device is adequately protected from ESD during the process. Official Product HT Part No. B1701URO-20D000114U1930 Tentative Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. **************** 01/13/2021 Version 1.5 Page 4/14 Top Mount Chip LED B1701URO-20D000114U1930 Label Specifications ▓Harvatek P/N: B 170 1 URO- 20D- 0001 14 Product Package Dice Qty Color Current Series Number Taping B:PCB 2.0(L)x1.3(W)x0.8(H) mm 1:Single Ultra Bright Super 20mA X001~XZZZ 1.Taping style Red 2. Qty ▓ Lot No.: Official Product HT Part No. B1701URO-20D000114U1930 Tentative Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. **************** 01/13/2021 Version 1.5 Page 5/14 Top Mount Chip LED B1701URO-20D000114U1930 Product specifications ■Luminous Intensity (Iv) Bin: Color URO Bin Code Spec. Range P 45.0-71.5 mcd Q 71.5-112.5 mcd R 112.5-180.0 mcd Note: It maintains a tolerance of ±10% on Luminous Intensity ■Wavelength Bin: Color Bin Code Spec. Range URO CH 625.0-650.0 nm Color Bin Code Spec. Range URO E18 1.6-2.4 V Note: It maintains a tolerance of ±0.5nm on Wavelength Bin ■Forward Voltage (Vf) Bin: Note: It maintains a tolerance of ±0.05V on forward voltage measurements Official Product HT Part No. B1701URO-20D000114U1930 Tentative Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. **************** 01/13/2021 Version 1.5 Page 6/14 Top Mount Chip LED B1701URO-20D000114U1930 Product Features Electro-Optical Characteristics (TSoldering , 25 ℃) VF(V) Series Emitting Color B1701URO-20 Material AlInGaP URO Wavelength λ(nm) IV(mcd) typ max λD λP △λ Typical 2.0 2.4 631 639 20 71.5 Viewing Angle 2 130 Package Outline Dimension and Recommended Soldering Pattern for Reflow Soldering Unit: mm Tolerance: +/-0.1 Outline Dim. Soldering Pattern Soldering terminals may shift in the x, y direction. Absolute Maximum Ratings (TSoldering 25 ℃) Series PD (mW) IF (mA) IFP (mA)* TOP (℃) TST (℃) Power Forward Pulse Forward Operating Storage Dissipation Current Temperature Temperature 48 20 -40~+85 -40~+100 Color URO Current 100 *Condition for IFP is pulse of 1/10 duty and 0.1msec width Official Product HT Part No. B1701URO-20D000114U1930 Tentative Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. **************** 01/13/2021 Version 1.5 Page 7/14 1 2 Top Mount Chip LED B1701URO-20D000114U1930 Characteristics of B1701URO Directive Characteristics Directive Characteristics Official Product HT Part No. B1701URO-20D000114U1930 Tentative Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. **************** 01/13/2021 Version 1.5 Page 8/14 Top Mount Chip LED B1701URO-20D000114U1930 Precaution for Use 1. The chips should not be used directly in any type of fluid such as water, oil, organic solvent, etc. 2. When the LEDs are illuminating, the maximum ambient temperature should be first considered before operation. 3. LEDs must be stored in a clean environment. A sealed container with a nitrogen atmosphere is necessary if the storage period is over 3 months after shipping. 4. 5. 6. The LEDs must be used within 4 weeks after unpacked. Unused products must be repacked in an anti-electrostatic package, folded to close any opening and then stored in a dry and cool space. The appearance and specifications of the products may be modified for improvement without further notice. The LEDs are sensitive to the static electricity and surge. It is strongly recommended to use a grounded wrist band and anti-electrostatic glove when handling the LEDs.If a voltage over the absolute maximum rating is applied to LEDs, it will damage LEDs.Damaged LEDs will show some abnormal characteristics such as remarkable increase of leak current, lower turn-on voltage and getting unlit at low current. Official Product HT Part No. B1701URO-20D000114U1930 Tentative Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. **************** 01/13/2021 Version 1.5 Page 9/14 Top Mount Chip LED B1701URO-20D000114U1930 Packaging Tape Dimension Dim. A Dim. B Dim. C Qty/Reel 2.20±0.05 1.42±0.05 0.88±0.05 4K Unit: mm Official Product HT Part No. B1701URO-20D000114U1930 Tentative Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. **************** 01/13/2021 Version 1.5 Page 10/14 Top Mount Chip LED B1701URO-20D000114U1930 Reel Dimension Packing 5 or 10 boxes per carton is available depending on shipment quantity. Official Product HT Part No. B1701URO-20D000114U1930 Tentative Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. **************** 01/13/2021 Version 1.5 Page 11/14 Top Mount Chip LED B1701URO-20D000114U1930 Dry Pack All SMD optical devices are MOISTURE SENSITIVE. Avoid exposure to moisture at all times during transportation or storage. Every reel is packaged in a moisture protected anti-static bag. Each bag is properly sealed prior to shipment. A humidity indicator will be included in the moisture protected anti-static bag prior to shipment. The packaging sequence is as follows: Baking Baking before soldering is recommended when the package has been unsealed for 4 weeks. The conditions are as followings: 1. 60±3℃×(12~24hrs)and
B1701URO-20D000114U1930 价格&库存
很抱歉,暂时无法提供与“B1701URO-20D000114U1930”相匹配的价格&库存,您可以联系我们找货
  • 4000+1.070914000+0.13881
  • 8000+1.009458000+0.13085
  • 12000+0.9779212000+0.12676
  • 20000+0.9423020000+0.12214
  • 28000+0.9211228000+0.11940
  • 40000+0.9004540000+0.11672
库存:3007
  • 1+3.344891+0.43357
  • 10+2.2988210+0.29797
  • 100+1.63144100+0.21147
  • 500+1.32844500+0.17219
  • 1000+1.228441000+0.15923
  • 2000+1.143312000+0.14820
库存:3007
