B2632USNB20C000323U1930
    HARVATEK(宏齐)
    蓝色,红色 470nm 蓝色,624nm 红色 LED 指示 - 分立 3.3V 蓝色,2V 红色 1205(3212 公制)
B2632USNB20C000323U1930 数据手册
Reverse Mountable Chip LED B2632USNB20C000323U1930 Harvatek Surface Mount LED Data Sheet B2632USNB20C000323U1930 Official Product HT Part No. B2632USNB20C000323U1930 Customer Part No. Tentative Product **************** **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. 03/11/2021 Version 1.3 Page 1/14 Reverse Mountable Chip LED B2632USNB20C000323U1930 DISCLAIMER ........................................................................................................................... 3 PRODUCT SPECIFICATIONS ................................................................................................. 4 ATTENTION: ELECTROSTATIC DISCHARGE (ESD) PROTECTION ................................................ 4 LABEL SPEC.: ......................................................................................................................... 5 PRODUCT SPECIFICATIONS ................................................................................................. 6 PRODUCT FEATURES ............................................................................................................ 7 ELECTRO-OPTICAL CHARACTERISTICS ...................................................................................... 7 PACKAGE OUTLINE DIMENSION RECOMMENDED SOLDERING PATTERN FOR REFLOW SOLDERING .. 7 ABSOLUTE MAXIMUM RATINGS ................................................................................................. 7 PRECAUTION FOR USE ............................................................................................................. 8 CHARACTERISTICS OF B2632USNB ...................................................................................... 9 PACKAGING .......................................................................................................................... 10 TAPE DIMENSION ................................................................................................................. 10 REEL DIMENSION ................................................................................................................... 11 PACKING ............................................................................................................................... 11 DRY PACK ............................................................................................................................. 12 BAKING ................................................................................................................................ 12 PRECAUTIONS ...................................................................................................................... 12 REFLOW SOLDERING .......................................................................................................... 13 REWORKING .......................................................................................................................... 13 CLEANING ............................................................................................................................. 13 REVISE HISTORY.................................................................................................................... 14 ADD BAKING ......................................................................................................................... 14 Official Product HT Part No. B2632USNB20C000323U1930 Customer Part No. Tentative Product **************** **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. 03/11/2021 Version 1.3 Page 2/14 Reverse Mountable Chip LED B2632USNB20C000323U1930 DISCLAIMER HARVATEK reserves the right to make changes without further notice to any products herein to improve reliability, function or design. HARVATEK does not assume any liability arising out of the application or use of any product or circuit described herein; neither does it convey any license under its patent rights, nor the rights of others. LIFE SUPPORT POLICY HARVATEK’s products are not authorized for use as critical components in life support devices or systems without the express written approval of the President of HARVATEK or HARVATEK INTERNATIONAL. As used herein: 1. Life support devices or systems are devices or systems which, (a) are intended for surgical implant into the body, or (b) support or sustain life, and (c) whose failure to perform when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in a significant injury of the user. 2. A critical component in any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. Official Product HT Part No. B2632USNB20C000323U1930 Customer Part No. Tentative Product **************** **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. 03/11/2021 Version 1.3 Page 3/14 Reverse Mountable Chip LED B2632USNB20C000323U1930 Product Specifications Specification Luminous USD: 28.5-112.5 mcd Intensity(Iv) NB: 45.0-180.0 mcd Material Quantity @20mA/ Ts= 25℃;Tolerance: + 10% USD: 615-630 nm Wavelength NB: 460.0-476.0 nm @20mA/ TS= 25℃;Tolerance: + 0.5nm Vf USD: 1.6-2.4 V NB: 2.7-3.9V/0.2V @20mA/ TS= 25℃ ;Tolerance: + 0.05V Ir < 10 µA @ VR = 5 V Resin clear Epoxy resin Carrier tape Per EIA 481-1A specs Conductive black tape Reel Per EIA 481-1A specs Conductive black Label HT standard Paper Packing bag 220x240mm Aluminum laminated bag/ no-zipper Carton HT standard Paper One reel per bag Others: Each immediate box consists of 5 reels. The 5 reels may not necessarily have the same lot number or the same bin combinations of Iv, λD and Vf. Each reel has a label identifying its specification; the immediate box consists of a product label as well. Note :This is shipped test conditions ※Remarks: This product should be operated in forward bias. If a reverse voltage is continuously applied to the product, such operation can cause migration resulting in LED damage. ATTENTION: Electrostatic Discharge (ESD) protection The symbol to the left denotes that ESD precaution is needed. ESD protection for GaP and AlGaAs based chips is necessary even though they are relatively safe in the presence of low static-electric discharge. Parts built with AlInGaP, GaN, or/and InGaN based chips are STATIC SENSITIVE devices. ESD precaution must be taken during design and assembly. If manual work or processing is needed, please ensure the device is adequately protected from ESD during the process. Official Product HT Part No. B2632USNB20C000323U1930 Customer Part No. Tentative Product **************** **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. 03/11/2021 Version 1.3 Page 4/14 Reverse Mountable Chip LED B2632USNB20C000323U1930 Label Spec.: ▓Customer P/N: To Be Defined: B 263 2 USNB 20C Product Dice Current PCB 2: Bi 20mA 0003 23 U1930 Taping 1.Taping style Package Color 3.2(L)x1.2(W)x0.8(H) mm 2. Q’ty Series Number US: Ultra Bright Red Customer Code Customer Product Code X001~XZZZ NB: Blue X0001~XZZZZ ▓Lot No.: Official Product HT Part No. B2632USNB20C000323U1930 Customer Part No. Tentative Product **************** **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. 03/11/2021 Version 1.3 Page 5/14 Reverse Mountable Chip LED B2632USNB20C000323U1930 Product specifications ▓Luminous Intensity (Iv) Bin: Color US NB Bin Code Spec. Range N 28.50-45.00 mcd P 45.00-71.50 mcd Q 71.50-112.5 mcd P 45.00-71.50 mcd Q 71.50-112.5 mcd R 112.5-180.0 mcd Note: It maintains a tolerance of ±10% on luminous intensity ▓Wavelength Bin: Color Bin Code Spec. Range US AC 615.0-630.0 nm A 460.0-464.0 nm B 464.0-468.0 nm C 468.0-472.0 nm D 472.0-476.0 nm NB Note: It maintains a tolerance of + 0.5nm on Wavelength Bin ▓ Forward Voltage (VF) Bin: Color Bin Code Spec. Range US E18 1.6-2.4V G8 2.7-2.9 V H7 2.9-3.1 V H8 3.1-3.3 V J7 3.3-3.5 V J8 3.5-3.7 V K7 3.7-3.9 V NB Note: It maintains a tolerance of ±0.05V on forward voltage measurements Official Product HT Part No. B2632USNB20C000323U1930 Customer Part No. Tentative Product **************** **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. 03/11/2021 Version 1.3 Page 6/14 Reverse Mountable Chip LED B2632USNB20C000323U1930 Product Features Electro-Optical Characteristics o (TSoldering ,Ta 25 C) Wavelength λ(nm) VF(V) Series Emitting Color Material IV(mcd) typ max λD λP △λ Typical Viewing Angle US AlGalnP 2.0 2.4 624 632 20 45.0 130 NB AllnGaP 3.3 3.9 470 468 40 71.5 130 2 1 2 B2632USNB20 Package Outline Dimension Recommended Soldering Pattern for Reflow Soldering Unit: mm Tolerance: +/-0.1 Outline Dimension Suggest Soldering Pattern Unit: mm Soldering terminals may shift in the x, y direction. Absolute Maximum Ratings ( TSoldering 25 ℃) Series PD (mW) IF (mA) IFP (mA)* TOP (℃) TST (℃) Power Forward Pulse Forward Operating Storage Dissipation Current Current Temperature Temperature US 48 20 100 -40~+85 -40~+100 NB 78 20 80 -40~+85 -40~+100 Color *Condition for IFP is pulse of 1/10 duty and 0.1msec width Official Product HT Part No. B2632USNB20C000323U1930 Customer Part No. Tentative Product **************** **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. 03/11/2021 Version 1.3 Page 7/14 Reverse Mountable Chip LED B2632USNB20C000323U1930 Precaution for Use 1. The chips should not be used directly in any type of fluid such as water, oil, organic solvent, etc. 2. When the LEDs are illuminating, the maximum ambient temperature should be first considered before operation. 3. LEDs must be stored in a clean environment. A sealed container with a nitrogen atmosphere is necessary if the storage period is over 3 months after shipping. 4. The LEDs must be used within 4 weeks after unpacked. Unused products must be repacked in an anti-electrostatic package, folded to close any opening and then stored in a dry and cool space. 5. The appearance and specifications of the products may be modified for improvement without further notice. 6. The LEDs are sensitive to the static electricity and surge. It is strongly recommended to use a grounded wrist band and anti-electrostatic glove when handling the LEDs. If a voltage over the absolute maximum rating is applied to LEDs, it will damage LEDs. Damaged LEDs will show some abnormal characteristics such as remarkable increase of leak current, lower turn-on voltage and getting unlit at low current. Official Product HT Part No. B2632USNB20C000323U1930 Customer Part No. Tentative Product **************** **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. 03/11/2021 Version 1.3 Page 8/14 Reverse Mountable Chip LED B2632USNB20C000323U1930 Characteristics of B2632USNB Directive Characteristics Directive Characteristics Official Product HT Part No. B2632USNB20C000323U1930 Customer Part No. Tentative Product **************** **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. 03/11/2021 Version 1.3 Page 9/14 Reverse Mountable Chip LED B2632USNB20C000323U1930 Packaging Tape Dimension Dim. A 3.55±0.05 Dim. B Dim. C Q’ty/Reel 1.35±0.05 0.88±0.05 3K Official Product HT Part No. B2632USNB20C000323U1930 Customer Part No. Tentative Product **************** **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. 03/11/2021 Version 1.3 Page 10/14 Reverse Mountable Chip LED B2632USNB20C000323U1930 Reel Dimension Packing 5 or 10 boxes per carton is available depending on shipment quantity. Official Product HT Part No. B2632USNB20C000323U1930 Customer Part No. Tentative Product **************** **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. 03/11/2021 Version 1.3 Page 11/14 Reverse Mountable Chip LED B2632USNB20C000323U1930 Dry Pack All SMD optical devices are MOISTURE SENSITIVE. Avoid exposure to moisture at all times during transportation or storage. Every reel is packaged in a moisture protected anti-static bag. Each bag is properly sealed prior to shipment. A humidity indicator will be included in the moisture protected anti-static bag prior to shipment. The packaging sequence is as follows: Baking Baking before soldering is recommended when the package has been unsealed for 4 weeks. The conditions are as followings: 1. 60±3℃×(12~24hrs)and
B2632USNB20C000323U1930 价格&库存
很抱歉,暂时无法提供与“B2632USNB20C000323U1930”相匹配的价格&库存,您可以联系我们找货
