B31G3BGR-20C0001Q3U1930
    HARVATEK(宏齐)
    SIP4
    红色,绿色,蓝色(RGB) 620nm 红色,526nm 绿色,468nm 蓝色 LED 指示 - 分立 2V 红色,2.6V 绿色,2.6V 蓝色 4-SMD,无引线
B31G3BGR-20C0001Q3U1930 数据手册
Side View Chip LED B31G3BGR-20C0001Q3U1930 Harvatek Surface Mount CHIP LEDs Data Sheet B31G3BGR-20C0001Q3U1930 7 Official Product HT Part No. B31G3BGR-20C0001Q3U1930 Customer Part No. Tentative Product **************** **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. 06/23/2022 Version 1.5 Data Sheet No. Page 1/15 Side View Chip LED B31G3BGR-20C0001Q3U1930 DISCLAIMER............................................................................................................................ 3 LIFE SUPPORT POLICY ............................................................................................................. 3 PRODUCT SPECIFICATIONS ................................................................................................. 4 ATTENTION: ELECTROSTATIC DISCHARGE (ESD) PROTECTION ............................................... 4 LABEL SPECIFICATIONS ....................................................................................................... 5 SPECIFICATIONS RANGE ...................................................................................................... 6 PRODUCT FEATURES ............................................................................................................ 7 ELECTRO-OPTICAL CHARACTERISTICS ...................................................................................... 7 PACKAGE OUTLINE DIMENSION AND RECOMMENDED SOLDERING PATTERN FOR REFLOW SOLDERING ............................................................................................................................. 7 CHARACTERISTICS OF B31G3BGR -20C ............................................................................... 8 PRECAUTION FOR USE ....................................................................................................... 10 PACKAGING .......................................................................................................................... 11 TAPE DIMENSION ................................................................................................................... 11 REEL DIMENSION ................................................................................................................... 12 PACKING ............................................................................................................................... 12 DRY PACK ............................................................................................................................ 13 BAKING................................................................................................................................. 13 PRECAUTIONS ....................................................................................................................... 13 REFLOW SOLDERING .......................................................................................................... 14 REWORKING .......................................................................................................................... 14 CLEANING ............................................................................................................................. 14 CAUTIONS OF PICK AND PLACE .............................................................................................. 15 REVISE HISTORY ................................................................................................................... 15 7 Official Product HT Part No. B31G3BGR-20C0001Q3U1930 Customer Part No. Tentative Product **************** **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. 06/23/2022 Version 1.5 Data Sheet No. Page 2/15 Side View Chip LED B31G3BGR-20C0001Q3U1930 DISCLAIMER HARVATEK reserves the right to make changes without further notice to any products herein to improve reliability, function or design. HARVATEK does not assume any liability arising out of the application or use of any product or circuit described herein; neither does it convey any license under its patent rights, nor the rights of others. Life Support Policy HARVATEK’s products are not authorized for use as critical components in life support devices or systems without the express written approval of the President of HARVATEK or HARVATEK INTERNATIONAL. As used herein: 1. Life support devices or systems are devices or systems which, (a) are intended for surgical implant into the body, or (b) support or sustain life, and (c) whose failure to perform when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in a significant injury of the user. 2. A critical component in any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. 7 Official Product HT Part No. B31G3BGR-20C0001Q3U1930 Customer Part No. Tentative Product **************** **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. 06/23/2022 Version 1.5 Data Sheet No. Page 3/15 Side View Chip LED B31G3BGR-20C0001Q3U1930 Product Specifications Item Specification Luminous R:540-1150 mcd Intensity(Iv) G:800-1840 mcd Material Quantity B:210-550 mcd @20mA/ Ts= 25℃;Tolerance: + 10% R:620.0-630.0 nm Wavelength G:517.0-527.0 nm B:462.0-472.0 nm @20mA/ TS= 25℃;Tolerance: + 0.5nm R:1.8-2.4 V Vf G:2.6-3.4 V B:2.6-3.4 V @20mA/ TS= 25℃ ;Tolerance: + 0.05V Ir < 1 µA @ VR = 5V Resin Clear Epoxy Carrier tape EIA 481-1A specs Conductive black tape Reel EIA 481-1A specs Conductive black Label HT standard Paper Packing bag 230x250mm Aluminum laminated bag/ no-zipper One reel per bag Carton HT standard Paper Non-specified 3000ea/reel Others: Each immediate box consists of 5 reels. The 5 reels may not necessarily have the same lot number or the same bin combinations of Iv, λD and Vf. Each reel has a label identifying its specification; the immediate box consists of a product label as well. Note :This is shipped test conditions ※Remarks: This product should be operated in forward bias. If a reverse voltage is continuously applied to the product, such operation can cause migration resulting in LED damage. ATTENTION: Electrostatic Discharge (ESD) protection The symbol to the left denotes that ESD precaution is needed. ESD protection for GaP and AlGaAs based chips is necessary even though they are relatively safe in the presence of low static-electric discharge. Parts built with AIGaInP, GaN, or/and InGaN based chips are STATIC SENSITIVE devices. ESD precaution must be taken during design and assembly. If manual work or processing is needed, please ensure the device is adequately protected from ESD during the process. 7 Official Product HT Part No. B31G3BGR-20C0001Q3U1930 Customer Part No. Tentative Product **************** **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. 06/23/2022 Version 1.5 Data Sheet No. Page 4/15 Side View Chip LED B31G3BGR-20C0001Q3U1930 Label Specifications ■Harvatek P/N: B 31G 3 BGR- 20C- 0001 Q3 Product Package Dice Qty Color Current Series Number Taping PCB 3.2(L)x1.5(W)x1.0(H) mm 3:Tri BGR : RGB(Full 20mA X001~XZZZ Color) 1.Taping style 2. Qty ■ Lot No.: 7 Official Product HT Part No. B31G3BGR-20C0001Q3U1930 Customer Part No. Tentative Product **************** **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. 06/23/2022 Version 1.5 Data Sheet No. Page 5/15 Side View Chip LED B31G3BGR-20C0001Q3U1930 Specifications Range ■Luminous Intensity (Iv) Bin: Luminous Intensity (Iv) Bin:R/G/B@20mA HT-B31G3BGR Series IV Green Red KR2 540 790 KR3 790 1150 KG2 1150 Blue 1840 KB2 210 340 KB3 340 550 Note: It maintains a tolerance of ±10% on luminous intensity Dominant Wavelength (λD) Bin: HT-B31G3 BGR Series WD Green Red Blue R1 620 625 G1 517 522 B1 462 467 R2 625 630 G2 522 527 B2 467 472 Note: It maintains a tolerance of + 0.5nm on color Forward Voltage (Vf) Bin: HT-B31G3BGR Series VF Green Red F 1.8 2.4 G38 2.6 Blue 3.4 G38 2.6 3.4 Note: It maintains a tolerance of ±0.05V on forward voltage measurements 7 Official Product HT Part No. B31G3BGR-20C0001Q3U1930 Customer Part No. Tentative Product **************** **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. 06/23/2022 Version 1.5 Data Sheet No. Page 6/15 Side View Chip LED B31G3BGR-20C0001Q3U1930 Product Features Electro-Optical Characteristics o (TSoldering , 25 C) VF(V) Series Emitting Color B31G3BGR-20 Material Wavelength λ(nm) IV(mcd) typ max λD λP △λ Typical Viewing Angle Red AllnGaP 2.0 2.4 620 630 20 950 110 Green InGaN 2.6 3.4 526 518 30 1500 110 Blue InGaN 2.6 3.4 468 463 20 330 110 2 Package Outline Dimension and Recommended Soldering Pattern for Reflow Soldering (Unit:mm Tolerance: +/-0.1) Outline Dim. Suggest Soldering Pattern Soldering terminals may shift in the x, y direction. 7 Official Product HT Part No. B31G3BGR-20C0001Q3U1930 Customer Part No. Tentative Product **************** **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. 06/23/2022 Version 1.5 Data Sheet No. Page 7/15 1 2 Side View Chip LED B31G3BGR-20C0001Q3U1930 ( TSoldering 25 ℃) Absolute Maximum Ratings Series PD (mW) VR(V) Color Power Dissipation IF (mA) Reverse IFP (mA)* Top (℃) Pulse Forward Operating Current Temperature Forward Current Voltage Red 45 5 20 ≦100 Green 56 5 20 ≦80 Blue 60 5 20 ≦80 -40~85 *Condition for IFP is pulse of 1/10 duty and 0.1msec width *Remarks:This product should be operated in forward bias.If a reverse voltage is continuously applied to the product, such operation can cause migration resulting in LED damage. Characteristics of B31G3BGR -20C 7 Official Product HT Part No. B31G3BGR-20C0001Q3U1930 Customer Part No. Tentative Product **************** **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. 06/23/2022 Version 1.5 Data Sheet No. Page 8/15 Side View Chip LED B31G3BGR-20C0001Q3U1930 Directive Characteristics 7 Official Product HT Part No. B31G3BGR-20C0001Q3U1930 Customer Part No. Tentative Product **************** **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. 06/23/2022 Version 1.5 Data Sheet No. Page 9/15 Side View Chip LED B31G3BGR-20C0001Q3U1930 Precaution for Use 1. The chips should not be used directly in any type of fluid such as water, oil, organic solvent, etc. 2. When the LEDs are illuminating, the maximum ambient temperature should be first considered before operation. 3. LEDs must be stored in a clean environment. A sealed container with a nitrogen atmosphere is necessary if the storage period is over 3 months after shipping. 4. The LEDs must be used within 72 hours after unpacked. Unused products must be 5. 6. repacked in an anti-electrostatic package, folded to close any opening and then stored in a dry and cool space. The appearance and specifications of the products may be modified for improvement without further notice. The LEDs are sensitive to the static electricity and surge. It is strongly recommended to use a grounded wrist band and anti-electrostatic glove when handling the LEDs.If a voltage over the absolute maximum rating is applied to LEDs, it will damage LEDs.Damaged LEDs will show some abnormal characteristics such as remarkable increase of leak current, lower turn-on voltage and getting unlit at low current. 7 Official Product HT Part No. B31G3BGR-20C0001Q3U1930 Customer Part No. Tentative Product **************** **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. 06/23/2022 Version 1.5 Data Sheet No. Page 10/15 Side View Chip LED B31G3BGR-20C0001Q3U1930 Packaging Tape Dimension Dim. A Dim. B Dim. C Qty/Reel 3.43±0.10 1.73±0.10 1.15±0.10 3K 7 Official Product HT Part No. B31G3BGR-20C0001Q3U1930 Customer Part No. Tentative Product **************** **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. 06/23/2022 Version 1.5 Data Sheet No. Page 11/15 Side View Chip LED B31G3BGR-20C0001Q3U1930 Reel Dimension Packing 5 boxes per carton is available depending on shipment quantity. 7 Official Product HT Part No. B31G3BGR-20C0001Q3U1930 Customer Part No. Tentative Product **************** **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. 06/23/2022 Version 1.5 Data Sheet No. Page 12/15 Side View Chip LED B31G3BGR-20C0001Q3U1930 Dry Pack All SMD optical devices are MOISTURE SENSITIVE. Avoid exposure to moisture at all times during transportation or storage. Every reel is packaged in a moisture protected anti-static bag. Each bag is properly sealed prior to shipment. A humidity indicator will be included in the moisture protected anti-static bag prior to shipment. The packaging sequence is as follows: Baking Baking before soldering is recommended when the package has been unsealed for 72 hours. The conditions are as followings: 1. 60±3℃×(12~24hrs)and
B31G3BGR-20C0001Q3U1930 价格&库存
很抱歉,暂时无法提供与“B31G3BGR-20C0001Q3U1930”相匹配的价格&库存,您可以联系我们找货
