B4252PLVP--G1B0001X3U1930
    HARVATEK(宏齐)
    光学传感器 环境 850nm
B4252PLVP--G1B0001X3U1930 数据手册
Ambient Light, Solar_UV_Index, IR and Proximity Sensor B4252PLVP--G1B0001X3U1930 Ambient Light, Solar_UV_Index, IR and Proximity Sensor Data Sheet B4252PLVP—U1930 P Official Product HT Part No. B4252PLVP--G1B0001X3U1930 Customer Part No. Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. Data Sheet No. **************** 08/03/2021 1.2 Page 1/29 Ambient Light, Solar_UV_Index, IR and Proximity Sensor B4252PLVP--G1B0001X3U1930 DISCLAIMER HARVATEK reserves the right to make changes without further notice to any products herein to improve reliability, function or design. HARVATEK does not assume any liability arising out of the application or use of any product or circuit described herein; neither does it convey any license under its patent rights, nor the rights of others. Life Support Policy HARVATEK’s products are not authorized for use as critical components in life support devices or systems without the express written approval of the President of HARVATEK or HARVATEK INTERNATIONAL. As used herein: 1. Life support devices or systems are devices or systems which, (a) are intended for surgical implant into the body, or (b) support or sustain life, and (c) whose failure to perform when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in a significant injury of the user. 2. A critical component in any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. Official Product HT Part No. B4252PLVP--G1B0001X3U1930 Customer Part No. Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. Data Sheet No. **************** 08/03/2021 1.2 Page 2/29 Ambient Light, Solar_UV_Index, IR and Proximity Sensor B4252PLVP--G1B0001X3U1930 Product Specifications Item Supply Voltage Specification Material Quantity 2.5V~3.6V VDD Operating Temperature -40~+85 ˚C Tope IR Peak Wavelength 850nm@2.5/5/10/15mA Resin Clear Epoxy Carrier tape EIA 481-1A specs Conductive black tape Reel EIA 481-1A specs Conductive black Label HT standard Paper Packing bag 220x240mm Aluminum laminated bag/ no-zipper One reel per bag Carton HT standard Paper Non-specified Others: Each immediate box consists of 5 reels. The 5 reels may not necessarily have the same lot number or the same bin combinations. Each reel has a label identifying its specification; the immediate box consists of a product label as well. Note :This is shipped test conditions ※Remarks: This product should be operated in forward bias. If a reverse voltage is continuously applied to the product, such operation can cause migration resulting in products damage. ATTENTION: Electrostatic Discharge (ESD) protection The symbol to the left denotes that ESD precaution is needed. ESD protection Silicon semiconductor is necessary even though they are relatively safe in the presence of low static-electric discharge. ESD precaution must be taken during design and assembly. If manual work or processing is needed, please ensure the device is adequately protected from ESD during the process. Official Product HT Part No. B4252PLVP--G1B0001X3U1930 Customer Part No. Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. Data Sheet No. **************** 08/03/2021 1.2 Page 3/29 Ambient Light, Solar_UV_Index, IR and Proximity Sensor B4252PLVP--G1B0001X3U1930 Label Specifications ■Harvatek P/N: B 425 2 PLVP Dice Q’ty Product G1B 0001 X3 Voltage 1. U1930 Taping Customer Code Taping Customer style Product Code 1:Single PCB 2.5V~3.6V 2: Second 2. Package Type Series Number 2.4(L)x1.3(W)x0.65(H) mm Proximity + Vcsel X001~XZZZ Q’ty ■ Lot No.: Official Product HT Part No. B4252PLVP--G1B0001X3U1930 Customer Part No. Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. Data Sheet No. **************** 08/03/2021 1.2 Page 4/29 Ambient Light, Solar_UV_Index, IR and Proximity Sensor B4252PLVP--G1B0001X3U1930 Block Diagram I/O Pins Configuration VDD 1 8 SDA GND 2 7 SCL B4252 INT 3 6 NC VDD 4 5 LDR Bottom View Pin I/O Type Pin Name 1 P VDD Power Supply 2 P GND Ground 3 O INT Interrupt pin VDD NC (Pin4 = Pin1) LDR VCSEL Cathode LDR NC 4 5 P 6 Description 7 I SCL I2C serial clock line 8 I/O SDA I2C serial data line Official Product HT Part No. B4252PLVP--G1B0001X3U1930 Customer Part No. Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. Data Sheet No. **************** 08/03/2021 1.2 Page 5/29 Ambient Light, Solar_UV_Index, IR and Proximity Sensor B4252PLVP--G1B0001X3U1930 Absolute Maximum Rating at 25℃ Parameters Supply Voltage Symbol Value Unit VDD -0.6 to 4.0 V -2.0 to 2.0 V Transient Voltage (
B4252PLVP--G1B0001X3U1930 价格&库存
很抱歉,暂时无法提供与“B4252PLVP--G1B0001X3U1930”相匹配的价格&库存,您可以联系我们找货
  • 1+10.499381+1.36489
  • 5+9.212575+1.19761
  • 10+8.7622910+1.13907
  • 25+8.2095825+1.06722
  • 50+7.8371950+1.01881
  • 100+7.49575100+0.97443
库存:140
