E1221NG--20DT00614U1930
    HARVATEK(宏齐)
    绿色 529nm LED 指示 - 分立 3.3V 0603(1608 公制)
E1221NG--20DT00614U1930 数据手册
Top view Chip LED E1221NG--20DT00614U1930 Harvatek Surface Mount CHIP LED Data Sheet E1221NG--20DT00614U1930 Official Product HT Part No. E1221NG--20DT00614U1930 Tentative Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. **************** 02/15/2023 Version 1.0 Page 1/15 Top view Chip LED E1221NG--20DT00614U1930 DISCLAIMER............................................................................................................................ 3 PRODUCT SPECIFICATIONS ................................................................................................. 4 ATTENTION: ELECTROSTATIC DISCHARGE (ESD) PROTECTION ................................................ 4 LABEL SPECIFICATIONS ....................................................................................................... 5 PRODUCT SPECIFICATIONS ................................................................................................. 6 PRODUCT FEATURES ............................................................................................................ 8 ELECTRO-OPTICAL CHARACTERISTICS ...................................................................................... 8 PACKAGE OUTLINE DIMENSION AND RECOMMENDED SOLDERING PATTERN FOR REFLOW SOLDERING ............................................................................................................................. 8 ABSOLUTE MAXIMUM RATINGS ................................................................................................. 8 CHARACTERISTICS OF E1221NG ............................................................................................. 9 PRECAUTION FOR USE ....................................................................................................... 10 PACKAGING .......................................................................................................................... 11 TAPE DIMENSION ................................................................................................................... 11 REEL DIMENSION ................................................................................................................... 12 PACKING ............................................................................................................................... 12 DRY PACK.............................................................................................................................. 13 BAKING ................................................................................................................................ 13 PRECAUTIONS ....................................................................................................................... 13 REFLOW SOLDERING .......................................................................................................... 14 REWORKING .......................................................................................................................... 14 CLEANING ............................................................................................................................. 14 REVISE HISTORY.................................................................................................................... 15 Official Product HT Part No. E1221NG--20DT00614U1930 Tentative Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. **************** 02/15/2023 Version 1.0 Page 2/15 Top view Chip LED E1221NG--20DT00614U1930 DISCLAIMER HARVATEK reserves the right to make changes without further notice to any products herein to improve reliability, function or design. HARVATEK does not assume any liability arising out of the application or use of any product or circuit described herein; neither does it convey any license under its patent rights, nor the rights of others. LIFE SUPPORT POLICY HARVATEK’s products are not authorized for use as critical components in life support devices or systems without the express written approval of the President of HARVATEK or HARVATEK INTERNATIONAL. As used herein: 1. Life support devices or systems are devices or systems which, (a) are intended for surgical implant into the body, or (b) support or sustain life, and (c) whose failure to perform when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in a significant injury of the user. 2. A critical component in any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. Official Product HT Part No. E1221NG--20DT00614U1930 Tentative Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. **************** 02/15/2023 Version 1.0 Page 3/15 Top view Chip LED E1221NG--20DT00614U1930 Product Specifications Specification Luminous NG:207-360 mcd Intensity(Iv) @20mA/ TS = 25℃;Tolerance:±10% Wavelength NG:520-535 nm Material Quantity @20mA/ TS = 25℃;Tolerance:±0.5nm Vf NG:2.7-3.9V @20mA/ TS = 25℃;Tolerance:±0.05V Vr 2~8V@10mA ESD 8KV Resin Diffused Epoxy resin Carrier tape EIA 481-1A specs Conductive black tape Reel EIA 481-1A specs Conductive black Label HT standard Paper Packing bag 250x230mm Aluminum laminated bag/ no-zipper One reel per bag Carton HT standard Paper Non-specified Others: Each immediate box consists of 5 reels. The 5 reels may not necessarily have the same lot number or the same bin combinations of Iv, λD and Vf. Each reel has a label identifying its specification; the immediate box consists of a product label as well. Note :This is shipped test conditions ※Remarks: This product should be operated in forward bias. If a reverse voltage is continuously applied to the product, such operation can cause migration resulting in LED damage. ATTENTION: Electrostatic Discharge (ESD) protection The symbol to the left denotes that ESD precaution is needed. ESD protection for GaP and AlGaAs based chips is necessary even though they are relatively safe in the presence of low static-electric discharge. Parts built with AlGaInP, GaN, or/and InGaN based chips are STATIC SENSITIVE devices. ESD precaution must be taken during design and assembly. If manual work or processing is needed, please ensure the device is adequately protected from ESD during the process. Official Product HT Part No. E1221NG--20DT00614U1930 Tentative Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. **************** 02/15/2023 Version 1.0 Page 4/15 Top view Chip LED E1221NG--20DT00614U1930 Label Specifications ▓Harvatek P/N: E 122 1 NG- 20D- T006 14 Product Package Dice Qty Color Current Series Number Taping PCB 1.6(L)x0.8(W)x0.4(H) mm 1:Single NG: Green 20mA T :for AM (aftermarket) +Zener X001~XZZZ 1.Taping style 2. Qty ▓ Lot No.: Official Product HT Part No. E1221NG--20DT00614U1930 Tentative Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. **************** 02/15/2023 Version 1.0 Page 5/15 Top view Chip LED E1221NG--20DT00614U1930 Product specifications ▓ Luminous Intensity (Iv) Bin: Color NG Bin Code Spec. Range FR2 207.0-250.0 mcd FS1 250.0-300.0 mcd FS3 300.0-360.0 mcd Note: It maintains a tolerance of ±10% on Luminous Intensity ▓ Wavelength Bin: Color Bin Code Spec. Range B1 520.0-522.5 nm B2 522.5-525.0 nm C1 525.0-527.5 nm C2 527.5-530.0 nm D1 530.0-532.5 nm D2 532.5-535.0 nm NG Note: It maintains a tolerance of ±0.5nm on Wavelength Bin Official Product HT Part No. E1221NG--20DT00614U1930 Tentative Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. **************** 02/15/2023 Version 1.0 Page 6/15 Top view Chip LED E1221NG--20DT00614U1930 ▓ Forward Voltage (Vf) Bin: Color Bin Code Spec. Range G41 2.7-2.75 V G42 2.75-2.8 V H11 2.8-2.85 V H12 2.85-2.9 V H21 2.9-2.95 V H22 2.95-3.0 V H31 3.0-3.05 V H32 3.05-3.1 V H41 3.1-3.15 V H42 3.15-3.2 V J11 3.2-3.25 V J12 3.25-3.3 V J21 3.3-3.35 V J22 3.35-3.4 V J31 3.4-3.45 V J32 3.45-3.5 V J41 3.5-3.55 V J42 3.55-3.6 V K11 3.6-3.65 V K12 3.65-3.7 V K21 3.7-3.75V K22 3.75-3.8 V K31 3.8-3.85 V K32 3.85-3.9 V NG Note: It maintains a tolerance of ±0.05V on forward voltage measurements Official Product HT Part No. E1221NG--20DT00614U1930 Tentative Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. **************** 02/15/2023 Version 1.0 Page 7/15 Top view Chip LED E1221NG--20DT00614U1930 Product Features Electro-Optical Characteristics (TSoldering , 25 ℃) VF(V) Series Emitting Color Material Wavelength λ(nm) IV(mcd) typ max λD λP △λ Typical 3.3 3.9 529 522 40 250.0 Viewing Angle 2 X=125 E1221NG--20 NG InGaN Y=128 Package Outline Dimension and Recommended Soldering Pattern for Reflow Soldering Unit: mm Tolerance: +/-0.1 Outline Dim. Suggest Soldering Pattern Soldering terminals may shift in the x, y direction. Absolute Maximum Ratings (TSoldering 25 ℃) Series PD (mW) IF (mA) Color Power Dissipation Forward Current IFP (mA)* TOP (℃) TST (℃) Pulse Forward Operating Storage Temperature Temperature -40~+85 -40~+100 Current NG 78 20 80 *Condition for IFP is pulse of 1/10 duty and 0.1msec width Official Product HT Part No. E1221NG--20DT00614U1930 Tentative Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. **************** 02/15/2023 Version 1.0 Page 8/15 1 2 Top view Chip LED E1221NG--20DT00614U1930 Characteristics of E1221NG Official Product HT Part No. E1221NG--20DT00614U1930 Tentative Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. **************** 02/15/2023 Version 1.0 Page 9/15 Top view Chip LED E1221NG--20DT00614U1930 Precaution for Use 1. The chips should not be used directly in any type of fluid such as water, oil, organic solvent, etc. 2. When the LEDs are illuminating, the maximum ambient temperature should be first considered before operation. 3. LEDs must be stored in a clean environment. A sealed container with a nitrogen atmosphere is necessary if the storage period is over 3 months after shipping. 4. The LEDs must be used within 4 weeks after unpacked. Unused products must be 5. 6. repacked in an anti-electrostatic package, folded to close any opening and then stored in a dry and cool space. The appearance and specifications of the products may be modified for improvement without further notice. The LEDs are sensitive to the static electricity and use a grounded wrist band and anti-electrostatic voltage over the absolute maximum rating is LEDs.Damaged LEDs will show some abnormal surge. It is strongly recommended to glove when handling the LEDs.If a applied to LEDs, it will damage characteristics such as remarkable increase of leak current, lower turn-on voltage and getting unlit at low current. Official Product HT Part No. E1221NG--20DT00614U1930 Tentative Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. **************** 02/15/2023 Version 1.0 Page 10/15 Top view Chip LED E1221NG--20DT00614U1930 Packaging Tape Dimension Dim. A Dim. B Dim. C Qty/Reel 1.77±0.05 0.97±0.05 0.51±0.05 4K Official Product HT Part No. E1221NG--20DT00614U1930 Tentative Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. **************** 02/15/2023 Version 1.0 Page 11/15 Top view Chip LED E1221NG--20DT00614U1930 Reel Dimension Packing 5 or 10 boxes per carton is available depending on shipment quantity. Official Product HT Part No. E1221NG--20DT00614U1930 Tentative Product **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. **************** 02/15/2023 Version 1.0 Page 12/15 Top view Chip LED E1221NG--20DT00614U1930 Dry Pack All SMD optical devices are MOISTURE SENSITIVE. Avoid exposure to moisture at all times during transportation or storage. Every reel is packaged in a moisture protected anti-static bag. Each bag is properly sealed prior to shipment. A humidity indicator will be included in the moisture protected anti-static bag prior to shipment. The packaging sequence is as follows: Baking Baking before soldering is recommended when the package has been unsealed for 4 weeks. The conditions are as followings: 1. 60±3℃×(12~24hrs)and
E1221NG--20DT00614U1930 价格&库存
很抱歉,暂时无法提供与“E1221NG--20DT00614U1930”相匹配的价格&库存,您可以联系我们找货
  • 4000+1.213484000+0.15745
  • 8000+1.145718000+0.14865
  • 12000+1.1109412000+0.14414
  • 20000+1.0716820000+0.13905
  • 28000+1.0483328000+0.13602
  • 40000+1.0255540000+0.13306
库存:3651
  • 1+3.784991+0.49109
  • 10+2.5761310+0.33424
  • 100+1.83232100+0.23774
  • 500+1.49769500+0.19432
  • 1000+1.387261000+0.17999
  • 2000+1.293322000+0.16781
库存:3651
