HV-1302004C-U1930
3.0mm Round PT LED LAMP
Harvatek 3.0mm Round PT LED LAMP
HV-1302004C-U1930
Official Product
HV-1302004C-U1930
Specifications are subject to change without notice. Data and
drawings herein are copyrighted.
Customer Part No.
Jul.15 2022
Version of 1.0
Data Sheet No.
HV-1302004C-U1930
Page 1/12
HV-1302004C-U1930
DISCLAIMER
HARVATEK reserves the right to make changes without further notice to any products herein to
improve reliability, function or design. HARVATEK does not assume any liability arising out of the
application or use of any product or circuit described herein; neither does it convey any license
under its patent rights, nor the rights of others.
LIFE SUPPORT POLICY
HARVATEK’s products are not authorized for use as critical components in life support devices or
systems without the express written approval of the President of HARVATEK or HARVATEK
INTERNATIONAL. As used herein:
1. Life support devices or systems are devices or systems which, (a) are intended for surgical
implant into the body, or (b) support or sustain life, and (c) whose failure to perform when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to
result in a significant injury of the user.
2. A critical component in any component of a life support device or system whose failure to perform
can be reasonably expected to cause the failure of the life support device or system, or to affect its
safety or effectiveness.
Official Product
HV-1302004C-U1930
Customer Part No.
Jul.15 2022
Version of 1.0
Data Sheet No.
HV-1302004C-U1930
Page 2/12
HV-1302004C-U1930
Compliance and Certification
ISO9002, QS9000 and ISO14001 Certified
RoHS Compliant
Orderable Information
H V - 1 3 0 2 0 0 4 C - U1930
Series Name
HV :
Color Code
Remark
130:
HARVATEK 940nm PT Chip.
2004 :
3.0mm Round Lamp, 5.2mm Lens.
C : Water Clear.
U1930:
Customer Product
Code
Features:
Stable Color.
Popular 3.0mm through hole package, 5.2mm lens height.
Water Clear Lens.
Official Product
HV-1302004C-U1930
Customer Part No.
Jul.15 2022
Version of 1.0
Data Sheet No.
HV-1302004C-U1930
Page 3/12
HV-1302004C-U1930
Package Dimensions:
Notes:
1.All dimensions are millimeters.
2.Tolerance is +/-0.25mm unless otherwise noted.
3.Specifications are subject to change without notice.
Official Product
HV-1302004C-U1930
Customer Part No.
Jul.15 2022
Version of 1.0
Data Sheet No.
HV-1302004C-U1930
Page 4/12
HV-1302004C-U1930
Absolute Maximum Ratings at Ta=25℃
Parameter
Symbol
Rating
Unit
Collector Current
Ic
mA
Operating Temperature
Topr
-40to+85
Storage Temperature
Tstg
-40to+100
Soldering Temperature*1
Tsol
260±5
Power Dissipation
Pd
75
mW
Collector-Emitter Voltage
Vceo
30
V
Emitter-Collector Voltage
Veco
5
V
*1:Soldering time ≦ 5 seconds.
Official Product
HV-1302004C-U1930
Customer Part No.
Jul.15 2022
Version of 1.0
Data Sheet No.
HV-1302004C-U1930
Page 5/12
HV-1302004C-U1930
Electrical and Optical Characteristic
Parameter
Symbol
On State Collector
IC(on)
Current
Collector Dark Current
Collector – Emitter
Breakdown Voltage
Emitter-Collector
Breakdown Voltage
Collector-Emitter
Saturation Voltage
Peak Wavelength
Rang of Spectral
Bandwidth
Rise Time
Iceo
BVceo
B Veco
Vce(sat)
Condition
Vce=5V
Ee=1mW/cm2
Ee=0mW/cm2
Vce=20V
Ic=100uA
Ee=0mW/cm2
Ic=100uA
Ee=0mW/cm2
Ic=2mA
Ee=1mW/cm2
Min.
Typ.
Max.
Unit
0.9
2.2
mA
100
nA
30
V
5
V
0.4
V
λρ
940
nm
λ 0.5
400
1100
nm
15
μS
15
μS
tr
VCE=5V
IC=1mA
Fall Time
Official Product
tf
RL=1000Ω
HV-1302004C-U1930
Customer Part No.
Jul.15 2022
Version of 1.0
Data Sheet No.
HV-1302004C-U1930
Page 6/12
HV-1302004C-U1930
Specifications for Bin Grading:
Ic(mA)
Official Product
Grade
Min.
Max.
G
0.9
1.6
H
1.45
2.25
J
2.1
3.2
K
3.1
4.85
L
4.7
6.75
M
6.6
7.9
N
7.75
9.4
P
9.25
10.9
HV-1302004C-U1930
Customer Part No.
Jul.15 2022
Version of 1.0
Data Sheet No.
HV-1302004C-U1930
Page 7/12
HV-1302004C-U1930
Typical Electro-Optical Characteristics Curves
Official Product
HV-1302004C-U1930
Customer Part No.
Jul.15 2022
Version of 1.0
Data Sheet No.
HV-1302004C-U1930
Page 8/12
HV-1302004C-U1930
Soldering condition
1.
Careful attention should be paid during soldering. When soldering, leave more then 2mm from
solder joint to Led, and soldering beyond the base of the tie bar is recommended.
2.
Avoiding applying any stress to the lead frame while the LED are at high temperature
particularly when soldering.
3.
Dip and hand soldering should not be done more than one time.
4.
After soldering the LED, the epoxy bulb should be protected from mechanical shock or vibration
until the LED return to room temperature.
5.
A rapid-rate process is not recommended for cooling the LED down from the peak temperature.
6.
Although the recommended soldering conditions are specified in the above table, dip or hand
soldering at the lowest possible temperature is desirable for the LED.
7.
Wave soldering parameter must be set and maintain according to recommended temperature
and dwell time in the solder wave.
• Recommended soldering conditions
Hand Soldering
Wave Soldering
Temp. at tip of iron
300℃ Max. (30W Max.)
Preheat temp.
160℃ Max. (120 sec Max.)
Soldering time
3 sec Max.
Bath temp. & time
260 Max., 5 sec Max
Distance
Official Product
2mm Min.(From solder joint to
Led)
HV-1302004C-U1930
Distance
2mm Min. (From solder joint
Customer Part No.
Jul.15 2022
Version of 1.0
to Led)
Data Sheet No.
HV-1302004C-U1930
Page 9/12
HV-1302004C-U1930
Reliability test items and conditions:
The reliability of products shall be satisfied with items listed below.
Confidence level:97%.
LTPD:3%.
No
1
Item
Solder
Test Conditions
Heat
TEMP:260℃±5℃
Failure
Test
Sample
Hours/Cycle
Size
10 SEC
76 PCS
0/1
300 CYCLES
76 PCS
0/1
300 CYCLES
76 PCS
Judgment
Ac/Er
Criteria
H:+100℃ 15min
2
Temperature Cycle
5min
L:-40℃ 15min
H:+100℃ 5min
3
Thermal
Shock
10sec
L:-10℃ 5min
4
5
6
7
High Temperature
Storage
Low Temperature
Storage
High Humidity
or
Vf≧U
1000 HRS
76 PCS
TEMP:-40℃
1000 HRS
76 PCS
1000 HRS
76 PCS
0/1
1000 HRS
76 PCS
0/1
IF=20mA
High Temperature /
0/1
TEMP:100℃
TEMP:25℃
DC Operating Life
Ic≦Ict*0.5
85℃/85%RH
or
Vf≦L
0/1
0/1
Note:Ict:To test Ic value of the chip before the reliability test.
Ic:The test value of the chip that has completed the reliability test.
U:Upper Specification Limit.
L:Lower Specification Limit.
Official Product
HV-1302004C-U1930
Customer Part No.
Jul.15 2022
Version of 1.0
Data Sheet No.
HV-1302004C-U1930
Page 10/12
HV-1302004C-U1930
Packing Specification:
CU
1000PCS/Bag
TE
TY
DA
ER
Q'
N.
OM
P/
ST
CO
DE
PA
RT
S
/M
PC
ar
XX
Ye
NO
XX
on
th
/D
ay
4000PCS/Box
CU S TO M E R
P / N .:
Q'TY:
DATE CODE:
T O TA L :
PART NO.
XXXXPCS
Year/Month/Day
XXXX PC S
40000PCS/Carton
CUSTOMER
P/N.:
Q'TY:
DATE CODE:
TOTAL:
PART NO.
XXXXPCS
Year/Month/Day
XXXX PCS
HV-1302004C-U1930
Official Product
HV-1302004C-U1930
Customer Part No.
Jul.15 2022
Version of 1.0
Data Sheet No.
HV-1302004C-U1930
Page 11/12
HV-1302004C-U1930
Revision History
Revision
Page
Version No.
Revision Date
1.0
07-15-2022
Initial Release
Official Product
HV-1302004C-U1930
Customer Part No.
Jul.15 2022
Version of 1.0
Data Sheet No.
HV-1302004C-U1930
Page 12/12
很抱歉,暂时无法提供与“HV-1302004C-U1930”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4.752501+0.61662
- 10+3.2353110+0.41977
- 100+2.32649100+0.30186
- 500+1.91586500+0.24858
- 1000+1.780721000+0.23104
- 2000+1.665772000+0.21613
- 5000+1.540005000+0.19981
- 10000+1.4614910000+0.18962
- 25000+1.3758325000+0.17851
