HV-315070/326/SYG-U1930
    HARVATEK(宏齐)
    LED 电路板指示器 LED Circuit Board Indicator 单路 绿色 散射,绿色 2V 20mA 圆形,带圆顶 3.00mm 直径 表面贴装,直角
HV-315070/326/SYG-U1930 数据手册
HV-315070/326/SYG-U1930 3.0mm Round LED LAMP with Holder Harvatek 3.0mm Round LED LAMP with Holder HV-315070/326/SYG-U1930 Official Product HV-315070/326/SYG-U1930 **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** HV-315070/326/SYG-U1930 Aug.12. 2021 Version of 1.0 Page 1/12 HV-315070/326/SYG-U1930 3.0mm Round LED LAMP with Holder DISCLAIMER HARVATEK reserves the right to make changes without further notice to any products herein to improve reliability, function or design. HARVATEK does not assume any liability arising out of the application or use of any product or circuit described herein; neither does it convey any license under its patent rights, nor the rights of others. LIFE SUPPORT POLICY HARVATEK’s products are not authorized for use as critical components in life support devices or systems without the express written approval of the President of HARVATEK or HARVATEK INTERNATIONAL. As used herein: 1. Life support devices or systems are devices or systems which, (a) are intended for surgical implant into the body, or (b) support or sustain life, and (c) whose failure to perform when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in a significant injury of the user. 2. A critical component in any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. Official Product HV-315070/326/SYG-U1930 **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** HV-315070/326/SYG-U1930 Aug.12. 2021 Version of 1.0 Page 2/12 HV-315070/326/SYG-U1930 3.0mm Round LED LAMP with Holder Compliance and Certification ISO9002, QS9000 and ISO14001 Certified RoHS Compliant Orderable Information H V - 315070 / 326 / SYG - U1930 Series Name Remark Color Code HV : 315070:Array 1 Lamp HARVATEK 326: 3.0mm Round LED LAMP. SYG: U1930: Customer Product Code AlGaInP 570nm Green Chip. Features:    Stable Color Popular 3.0mm through hole package. Green Diffused Lens. Official Product HV-315070/326/SYG-U1930 **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** HV-315070/326/SYG-U1930 Aug.12. 2021 Version of 1.0 Page 3/12 HV-315070/326/SYG-U1930 3.0mm Round LED LAMP with Holder Package Dimensions: Notes: 1.All dimensions are millimeters. 2.Tolerance is +/-0.25mm unless otherwise noted. 3.Specifications are subject to change without notice. Official Product HV-315070/326/SYG-U1930 **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** HV-315070/326/SYG-U1930 Aug.12. 2021 Version of 1.0 Page 4/12 HV-315070/326/SYG-U1930 3.0mm Round LED LAMP with Holder Absolute Maximum Ratings at Ta=25℃ Parameter Symbol Rating Unit Forward Current IF 30 mA Operating Temperature Topr -40to+85 ℃ Storage Temperature Tstg -40to+85 ℃ Soldering Temperature*1 Tsol 260±5 ℃ Power Dissipation Pd 75 mW Reverse Voltage VR 5 V Peak Forward Current*2 IFP 75 mA *1:Soldering time ≦ 5 seconds. *2:Pulse Width≦ 100μs and Duty≦ 1% Official Product HV-315070/326/SYG-U1930 **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** HV-315070/326/SYG-U1930 Aug.12. 2021 Version of 1.0 Page 5/12 HV-315070/326/SYG-U1930 3.0mm Round LED LAMP with Holder Electrical and Optical Characteristic Parameter Symbol Condition Min. Typ. Max. Unit Forward Voltage VF IF=20 mA ∕ 2.0 2.4 V Reverse Current IR VR= 5 V ∕ ∕ 10 μA Luminous Intensity IV IF=20 mA 10 40 ∕ mcd Viewing Angle 2θ1/2 IF=20 mA ∕ 60 ∕ deg Dominant Wavelength λd IF=20 mA ∕ 570 ∕ nm Peak Wavelength λρ IF=20 mA ∕ 575 ∕ nm Spectrum Radiation Bandwidth Δλ IF=20 mA ∕ 30 ∕ nm Notes: θ1/2 is the angle from optical centerline where the luminous intensity is 1/2 the optical centerline value. Official Product HV-315070/326/SYG-U1930 **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** HV-315070/326/SYG-U1930 Aug.12. 2021 Version of 1.0 Page 6/12 HV-315070/326/SYG-U1930 3.0mm Round LED LAMP with Holder Specifications for Bin Grading: Iv(mcd) Grade Min. Max. L 10 20 M 16 32 N 25 50 P 40 80 Q 63 125 λd(nm) Grade Min. Max. 5 566 569 6 568 571 7 570 573 8 572 575 9 574 577 Notes: 1.Luminous intensity:+/-15%. 2.Wavelength: +/-1nm Official Product HV-315070/326/SYG-U1930 **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** HV-315070/326/SYG-U1930 Aug.12. 2021 Version of 1.0 Page 7/12 HV-315070/326/SYG-U1930 3.0mm Round LED LAMP with Holder Typical Electrical / Optical Characteristics Curves Official Product HV-315070/326/SYG-U1930 **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** HV-315070/326/SYG-U1930 Aug.12. 2021 Version of 1.0 Page 8/12 HV-315070/326/SYG-U1930 3.0mm Round LED LAMP with Holder Soldering condition Recommended soldering conditions Reflow Pre-heat 160~180℃ Pre-heat time 120 seconds Max. Peak temperature 240℃Max. Soldering time 10 seconds Max. Condition Refer to Temperature-profile Soldering Temperature Soldering time 260℃Max. 5 second Max. (one time only) • After reflow soldering rapid cooling should be avoided Pb-free solder temperature profile • We suggest that the reflow soldering temperature is 240 ± 5℃; • Reflow soldering should not be done more than two times; • When soldering ,do not put stress on the LEDs during heating; Soldering iron 1. When hand soldering, keep the temperature of the iron under 260℃, and at that temperature keep the time under 5 sec; 2. The hand soldering should be done only a time; 3. The basic spec is ≤ 5 sec. when the temperature of 260 ℃ , do not contact the resin whenhand soldering; Official Product HV-315070/326/SYG-U1930 **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** HV-315070/326/SYG-U1930 Aug.12. 2021 Version of 1.0 Page 9/12 HV-315070/326/SYG-U1930 3.0mm Round LED LAMP with Holder Reliability test items and conditions: The reliability of products shall be satisfied with items listed below. Confidence level:97% LTPD:3% Item Test Conditions Solder Heat TEMP:260℃±5 ℃ 10 SEC 76 PCS 0/1 Temperature Cycle H:+100℃ 15min ∫ 5min L:-40℃ 15min 300 CYCLES 76 PCS 0/1 3 Thermal H:+100℃ 5min ∫ 10sec L:-10℃ 5min 300 CYCLES 76 PCS 4 High Temperature Storage TEMP:100℃ 1000 HRS 76 PCS 5 Low Temperature Storage TEMP:-40℃ 1000 HRS 76 PCS 0/1 6 DC Operating Life TEMP:25℃ IF=20mA 1000 HRS 76 PCS 0/1 7 High Temperature / High Humidity 85℃/85%RH 1000 HRS 76 PCS 0/1 No 1 2 Shock Sample Size Failure Judgment Criteria Test Hours/Cycle Ac/Er Iv≦Ivt*0.5 or Vf≧U or Vf≦L 0/1 0/1 Note:Ivt:To test Iv value of the chip before the reliability test. Iv:The test value of the chip that has completed the reliability test U:Upper Specification Limit L:Lower Specification Limit Official Product HV-315070/326/SYG-U1930 **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** HV-315070/326/SYG-U1930 Aug.12. 2021 Version of 1.0 Page 10/12 HV-315070/326/SYG-U1930 3.0mm Round LED LAMP with Holder Packing Specification: CU : TE TY : DA ER Q' N. OM P/ ST 250PCS/Bag CO DE : PA RT . S /M PC ar XX Ye NO XX on th /D ay 1000PCS/In-Carton CU S TO M E R P / N .: Q'TY: DATE CODE: T O TA L : PART NO. XXXXPCS Year/Month/Day XXXX PC S 10000PCS/Out-Carton CUSTOMER P/N.: Q'TY: DATE CODE: TOTAL: PART NO. XXXXPCS Year/Month/Day XXXX PCS HV-315070/326/SYG-U1930 Official Product HV-315070/326/SYG-U1930 **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** HV-315070/326/SYG-U1930 Aug.12. 2021 Version of 1.0 Page 11/12 HV-315070/326/SYG-U1930 3.0mm Round LED LAMP with Holder Revision History Revision Page Version No. Revision Date 1.0 08-12-2021 Initial Release Official Product HV-315070/326/SYG-U1930 **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** HV-315070/326/SYG-U1930 Aug.12. 2021 Version of 1.0 Page 12/12
HV-315070/326/SYG-U1930 价格&库存
很抱歉,暂时无法提供与“HV-315070/326/SYG-U1930”相匹配的价格&库存,您可以联系我们找货
