HV-32223/260/UYOSYGMX-U1930 数据手册
3.0mm Round LED LAMP with Holder
Harvatek 3.0mm Round LED LAMP with Holder
Official Product
Customer Part No.
Data Sheet No.
Specifications are subject to change without notice. Data
and drawings herein are copyrighted.
Aug.23. 2021 Version of 1.0
Page 1/14
DISCLAIMER
HARVATEK reserves the right to make changes without further notice to any products
herein to improve reliability, function or design. HARVATEK does not assume any
liability arising out of the application or use of any product or circuit described herein;
neither does it convey any license under its patent rights, nor the rights of others.
LIFE SUPPORT POLICY
HARVATEK’s products are not authorized for use as critical components in life support
devices or systems without the express written approval of the President of HARVATEK
or HARVATEK INTERNATIONAL. As used herein:
1.Life support devices or systems are devices or systems which, (a) are intended for
surgical implant into the body, or (b) support or sustain life, and (c) whose failure to
perform when properly used in accordance with instructions for use provided in the
labeling, can be reasonably expected to result in a significant injury of the user.
2.A critical component in any component of a life support device or system whose
failure to perform can be reasonably expected to cause the failure of the life support
device or system, or to affect its safety or effectiveness.
Official Product
Customer Part No.
Data Sheet No.
Page 2/14
Compliance and Certification
ISO9002, QS9000 and ISO14001 Certified
RoHS Compliant
Orderable Information
H V - 32223 / 260 / UYOSYGM X - U1930
Color
Series Name
Code
HV :
32223:Array 2 Lamp
HARVATEK 260:
3.0mm Round LED LAMP.
UYOSYG:
GaP 605nm Orange Chip.
GaP 570nm Green Chip.
M: White Diffused.
X: HARVATEK Part No.
Remark
U1930:
Code
Customer Product
Features:
Stable Color
Popular 3.0mm through hole package.
White diffused lens.
Official Product
Customer Part No.
Data Sheet No.
Page 3/14
Package Dimensions:
Notes:
1.All dimensions are millimeters.
2.Tolerance is +/-0.25mm unless otherwise noted.
3.Specifications are subject to change without notice.
Official Product
Customer Part No.
Data Sheet No.
Page 4/14
Absolute Maximum Ratings at Ta=25℃
Parameter
Symbol
Rating
Unit
Forward Current
IF
30
mA
Operating Temperature
Topr
-40to+85
Storage Temperature
Tstg
-40to+85
Soldering Temperature*1
Tsol
260±5
Power Dissipation
Pd
75
mW
Reverse Voltage
VR
1.1
V
Peak Forward Current*2
IFP
75
mA
*1:Soldering time ≦ 5 seconds. *2:Pulse Width≦ 100μs and Duty≦1%
Official Product
Customer Part No.
Data Sheet No.
Page 5/14
Electrical and Optical Characteristic
Parameter
Symbol
Condition
Min.
Typ.
Max.
Unit
Forward Voltage
VF
IF=10 mA
2.0
2.4
V
Reverse Current
IR
VR=1.1V
Luminous Intensity
IV
O
2
10
G
2
10
Viewing Angle
2θ1/2
120
Dominant Wavelength
λd
IF=10 mA
O
605
G
570
Peak Wavelength
λρ
IF=10 mA
O
610
G
575
O
G
18
Spectrum Radiation Bandwidth
Δλ
IF=10 mA
IF=10 mA
IF=10 mA
10
μA
mcd
Deg
nm
nm
nm
Notes:
θ1/2 is the angle from optical centerline where the luminous intensity is 1/2 the optical centerline
value.
Official Product
Customer Part No.
Data Sheet No.
Page 6/14
Specifications for Bin Grading:(O)
Iv(mcd)IF=10 mA
Grade
Min.
Max.
H
J
K
L
M
N
2
5
4
8
6.3
12.5
10
32
25
50
λd(nm)IF=10 mA
Grade
Min.
Max.
1
598
601
2
600
603
3
602
605
4
604
607
5
606
609
6
608
611
Notes:
1.Luminous intensity:+/-15%.
2.Wavelength: +/-1nm.
Official Product
Customer Part No.
Data Sheet No.
Page 7/14
Specifications for Bin Grading:(G)
Iv(mcd)IF=10 mA
Grade
Min.
Max.
H
2
5
J
4
8
K
6.3
12.5
L
10
M
16
32
N
25
50
λd(nm)IF=10 mA
Grade
Min.
Max.
4
564
567
5
566
569
6
568
571
7
570
573
8
572
575
Notes:
Official Product
Customer Part No.
Data Sheet No.
Page 8/14
Typical Electrical / Optical Characteristics Curves(O)
Official Product
Customer Part No.
Data Sheet No.
Page 9/14
Typical Electrical / Optical Characteristics Curves(G)
Official Product
Customer Part No.
Data Sheet No.
Page 10/14
Soldering condition
1.
Careful attention should be paid during soldering. When soldering, leave more then 2mm from
solder joint to Led, and soldering beyond the base of the tie bar is recommended.
2.
Avoiding applying any stress to the lead frame while the LED are at high temperature
particularly when soldering.
3.
Dip and hand soldering should not be done more than one time.
4.
After soldering the LED, the epoxy bulb should be protected from mechanical shock or
vibration until the LED return to room temperature.
5.
A rapid-rate process is not recommended for cooling the LED down from the peak
temperature.
6.
Although the recommended soldering conditions are specified in the above table, dip or hand
soldering at the lowest possible temperature is desirable for the LED.
7.
Wave soldering parameter must be set and maintain according to recommended temperature
and dwell time in the solder wave.
Recommended soldering conditions
Hand Soldering
Wave Soldering
Temp. at tip of iron
300℃ Max. (30W Max.)
Preheat temp.
160℃ Max. (120 sec Max.)
Soldering time
3 sec Max.
Bath temp. & time
260 Max., 5 sec Max
Distance
2mm Min.(From solder joint
to Led)
Distance
2mm Min. (From solder
joint to Led)
Official Product
Customer Part No.
Data Sheet No.
Page 11/14
Reliability test items and conditions:
The reliability of products shall be satisfied with items listed below.
Confidence level:97%
LTPD:3%
No
Item
1
Solder
Temperature Cycle
6
7
TEMP:260℃±5
5min
L:-40℃ 15min
H:+100℃ 5min
3
5
Heat
H:+100℃ 15min
2
4
Test Conditions
Thermal
Shock
High Temperature
Storage
Low Temperature
Storage
DC Operating Life
High Temperature /
High Humidity
10sec
Failure
Judgment
Test
Hours/Cycle
Sample
Size
10 SEC
76 PCS
0/1
76 PCS
0/1
300
CYCLES
Criteria
Ac/Er
Iv≦Ivt*0.5
300
or
Vf≧U
0/1
CYCLES
76 PCS
TEMP:100℃
1000 HRS
76 PCS
TEMP:-40℃
1000 HRS
76 PCS
0/1
1000 HRS
76 PCS
0/1
1000 HRS
76 PCS
0/1
L:-10℃ 5min
TEMP:25℃
IF=20mA
85℃/85%RH
or
Vf≦L
0/1
Note:Ivt:To test Iv value of the chip before the reliability test.
Iv:The test value of the chip that has completed the reliability
test U:Upper Specification Limit
L:Lower Specification Limit
Official Product
Customer Part No.
Data Sheet No.
Page 12/14
Packing Specification:
250PCS/Bag
1000PCS/In-Carton
10000PCS/Out-Carton
Official Product
Customer Part No.
Data Sheet No.
Page 13/14
Revision History
Revision
Page
Version No.
Revision Date
1.0
08-23-2021
Initial Release
Official Product
Customer Part No.
Data Sheet No.
Page 14/14
HV-32223/260/UYOSYGMX-U1930 价格&库存
很抱歉,暂时无法提供与“HV-32223/260/UYOSYGMX-U1930”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+6.776321+0.88060
- 10+4.7327910+0.61504
- 100+3.45018100+0.44836
- 500+2.87733500+0.37392
- 1000+2.689431000+0.34950
- 2000+2.529722000+0.32875
- 5000+2.355155000+0.30606
- 10000+2.2463110000+0.29192
- 25000+2.1276425000+0.27650
