HV-32312/260/XSUB-U1930 数据手册
3.0mm Round LED LAMP with Holder
Harvatek 3.0mm Round LED LAMP with Holder
Official Product
Specifications are subject to change without notice. Data and
drawings herein are copyrighted.
Customer Part No.
Data Sheet No.
Sep.14. 2022
Version of 1.1
Page 1/12
DISCLAIMER
HARVATEK reserves the right to make changes without further notice to any products herein to
improve reliability, function or design. HARVATEK does not assume any liability arising out of the
application or use of any product or circuit described herein; neither does it convey any license
under its patent rights, nor the rights of others.
LIFE SUPPORT POLICY
HARVATEK’s products are not authorized for use as critical components in life support devices or
systems without the express written approval of the President of HARVATEK or HARVATEK
INTERNATIONAL. As used herein:
1. Life support devices or systems are devices or systems which, (a) are intended for surgical
implant into the body, or (b) support or sustain life, and (c) whose failure to perform when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to
result in a significant injury of the user.
2. A critical component in any component of a life support device or system whose failure to perform
can be reasonably expected to cause the failure of the life support device or system, or to affect its
safety or effectiveness.
Official Product
Customer Part No.
Data Sheet No.
Sep.14. 2022
Version of 1.1
Page 2/12
Compliance and Certification
ISO9002, QS9000 and ISO14001 Certified
RoHS Compliant
Orderable Information
H V - 32312 / 260 / XSUB - U1930
Series Name
HV :
HARVATEK
Remark
Color Code
32312: Array 2 Lamp.
260:
3.0mm Round LED LAMP.
XSUB :
InGaN 470nm Blue Chip.
U1930:
Customer Product
Code
Features:
Stable Color.
Popular 3.0mm through hole package.
Blue diffused lens.
Official Product
Customer Part No.
Data Sheet No.
Sep.14. 2022
Version of 1.1
Page 3/12
Package Dimensions:
Notes:
1.All dimensions are millimeters.
2.Tolerance is +/-0.25mm unless otherwise noted.
3.Specifications are subject to change without notice.
Official Product
Customer Part No.
Data Sheet No.
Sep.14. 2022
Version of 1.1
Page 4/12
Absolute Maximum Ratings at Ta=25℃
Parameter
Symbol
Rating
Unit
Forward Current
IF
30
mA
Operating Temperature
Topr
-40to+85
Storage Temperature
Tstg
-40to+85
Soldering Temperature*1
Tsol
260
Power Dissipation
Pd
100
mW
Reverse Voltage
VR
5
V
Peak Forward Current*2
IFP
100
A
*1:Soldering time ≦ 5 seconds. *2:Pulse Width≦ 100μs and Duty≦ 1%.
Official Product
Customer Part No.
Data Sheet No.
Sep.14. 2022
Version of 1.1
Page 5/12
Electrical and Optical Characteristic
Parameter
Symbol
Condition
Min.
Typ.
Max.
Unit
Forward Voltage
VF
IF=10 mA
3.0
3.4
V
Reverse Current
IR
V R= 5 V
10
μA
Luminous Intensity
IV
IF=10 mA
400
1200
mcd
Viewing Angle
2θ1/2
IF=10 mA
60
deg
Dominant Wavelength
λd
IF=10 mA
470
nm
Peak Wavelength
λρ
IF=10 mA
465
nm
Spectrum Radiation
Bandwidth
Δλ
IF=10 mA
nm
Notes:
θ1/2 is the angle from optical centerline where the luminous intensity is 1/2 the optical centerline
value.
Official Product
Customer Part No.
Data Sheet No.
Sep.14. 2022
Version of 1.1
Page 6/12
Specifications for Bin Grading:
Iv(mcd)
Grade
Min.
Max.
U
400
800
V
630
1250
W
1000
2000
X
1600
3200
λd(nm)
Grade
Min.
Max.
2
463.5
466.5
3
465.5
468.5
4
467.5
470.5
5
469.5
472.5
6
471.5
474.5
7
473.5
476.5
Notes:
1.Luminous intensity:+/-15%.
2.Wavelength: +/-1nm.
Official Product
Customer Part No.
Data Sheet No.
Sep.14. 2022
Version of 1.1
Page 7/12
Typical Electrical / Optical Characteristics Curves
Official Product
Customer Part No.
Data Sheet No.
Sep.14. 2022
Version of 1.1
Page 8/12
Soldering condition
1.
Careful attention should be paid during soldering. When soldering, leave more then 2mm from
solder joint to Led, and soldering beyond the base of the tie bar is recommended.
2.
Avoiding applying any stress to the lead frame while the LED are at high temperature
particularly when soldering.
3.
Dip and hand soldering should not be done more than one time.
4.
After soldering the LED, the epoxy bulb should be protected from mechanical shock or vibration
until the LED return to room temperature.
5.
A rapid-rate process is not recommended for cooling the LED down from the peak temperature.
6.
Although the recommended soldering conditions are specified in the above table, dip or hand
soldering at the lowest possible temperature is desirable for the LED.
7.
Wave soldering parameter must be set and maintain according to recommended temperature
and dwell time in the solder wave.
• Recommended soldering conditions
Hand Soldering
Wave Soldering
Temp. at tip of iron
300℃ Max. (30W Max.)
Preheat temp.
160℃ Max. (120 sec Max.)
Soldering time
3 sec Max.
Bath temp. & time
260 Max., 5 sec Max
Distance
Official Product
2mm Min.(From solder joint to
Led)
Distance
2mm Min. (From solder joint
to Led)
Customer Part No.
Data Sheet No.
Sep.14. 2022
Version of 1.1
Page 9/12
Reliability test items and conditions:
The reliability of products shall be satisfied with items listed below.
Confidence level:97%.
LTPD:3%.
No
Item
1
Solder
Test Conditions
Heat
TEMP:260℃±5℃
Failure
Test
Sample
Hours/Cycle
Size
10 SEC
76 PCS
0/1
300 CYCLES
76 PCS
0/1
300 CYCLES
76 PCS
Judgment
Ac/Er
Criteria
H:+100℃ 15min
2
Temperature Cycle
5min
L:-40℃ 15min
H:+100℃ 5min
3
Thermal
Shock
10sec
L:-10℃ 5min
High Temperature
4
Storage
Low Temperature
5
Storage
6
DC Operating Life
High Temperature /
7
High Humidity
Iv≦Ivt*0.5
0/1
or
Vf≧U
TEMP:100℃
1000 HRS
76 PCS
TEMP:-40℃
1000 HRS
76 PCS
0/1
1000 HRS
76 PCS
0/1
1000 HRS
76 PCS
0/1
or
0/1
Vf≦L
TEMP:25℃
IF=20mA
85℃/85%RH
Note:Ivt:To test Iv value of the chip before the reliability test.
Iv:The test value of the chip that has completed the reliability test.
U:Upper Specification Limit.
L:Lower Specification Limit.
Official Product
Customer Part No.
Data Sheet No.
Sep.14. 2022
Version of 1.1
Page 10/12
Packing Specification:
CU
TE
TY
DA
ER
Q'
N.
OM
P/
ST
250PCS/Bag
CO
DE
PA
RT
S
/M
PC
ar
XX
Ye
NO
XX
on
th
/D
ay
1000PCS/In-Carton
CU S TO M E R
P / N .:
Q'TY:
DATE CODE:
T O TA L :
PART NO.
XXXXPCS
Year/Month/Day
XXXX PC S
10000PCS/Out-Carton
CUSTOMER
P/N.:
Q'TY:
DATE CODE:
TOTAL:
PART NO.
XXXXPCS
Year/Month/Day
XXXX PCS
Official Product
Customer Part No.
Data Sheet No.
Sep.14. 2022
Version of 1.1
Page 11/12
Revision History
Revision
Page
Version No.
Revision Date
1.0
08-24-2021
1.1
09-14-2022
Initial Release
Modify the figure size
Official Product
4
Customer Part No.
Data Sheet No.
Sep.14. 2022
Version of 1.1
Page 12/12
HV-32312/260/XSUB-U1930 价格&库存
很抱歉,暂时无法提供与“HV-32312/260/XSUB-U1930”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+5.378691+0.69622
