HV-331390/230/SYGXX-U1930
    HARVATEK(宏齐)
    LED 电路板指示器 LED Circuit Board Indicator 3 高 绿色(x 3) 散射,绿色 2V 20mA 圆形,带圆顶 3.00mm 直径 通孔,直角
HV-331390/230/SYGXX-U1930 数据手册
HV-331390/230/SYGXX-U1930 3.0mm Round LED LAMP with Holder Harvatek 3.0mm Round LED LAMP with Holder HV-331390/230/SYGXX-U1930 Official Product HV-331390/230/SYGXX-U1930 **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** HV-331390/230/SYGXX-U1930 Aug.16. 2021 Version of 1.0 Page 1/12 HV-331390/230/SYGXX-U1930 3.0mm Round LED LAMP with Holder DISCLAIMER HARVATEK reserves the right to make changes without further notice to any products herein to improve reliability, function or design. HARVATEK does not assume any liability arising out of the application or use of any product or circuit described herein; neither does it convey any license under its patent rights, nor the rights of others. LIFE SUPPORT POLICY HARVATEK’s products are not authorized for use as critical components in life support devices or systems without the express written approval of the President of HARVATEK or HARVATEK INTERNATIONAL. As used herein: 1. Life support devices or systems are devices or systems which, (a) are intended for surgical implant into the body, or (b) support or sustain life, and (c) whose failure to perform when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in a significant injury of the user. 2. A critical component in any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. Official Product HV-331390/230/SYGXX-U1930 **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** HV-331390/230/SYGXX-U1930 Aug.16. 2021 Version of 1.0 Page 2/12 HV-331390/230/SYGXX-U1930 3.0mm Round LED LAMP with Holder Compliance and Certification ISO9002, QS9000 and ISO14001 Certified RoHS Compliant Orderable Information H V - 331390 / 230 / SYGXX - U1930 Series Name HV : HARVATEK Color Code Remark 331390: Array 3 Lamp 230 : 3.0mm Round LED Lamp SYGXX: GaP 570nm Green Chip. U1930: Customer Product Code Features:    Stable Color Popular 3.0mm through hole package. Green Diffused lens. Official Product HV-331390/230/SYGXX-U1930 **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** HV-331390/230/SYGXX-U1930 Aug.16. 2021 Version of 1.0 Page 3/12 HV-331390/230/SYGXX-U1930 3.0mm Round LED LAMP with Holder Package Dimensions Notes: 1.All dimensions are millimeters. 2.Tolerance is +/-0.25mm unless otherwise noted. 3.Specifications are subject to change without notice. Official Product HV-331390/230/SYGXX-U1930 **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** HV-331390/230/SYGXX-U1930 Aug.16. 2021 Version of 1.0 Page 4/12 HV-331390/230/SYGXX-U1930 3.0mm Round LED LAMP with Holder Absolute Maximum Ratings at Ta=25℃ Parameter Symbol Rating Unit Forward Current IF 30 mA Operating Temperature Topr -40to+85 ℃ Storage Temperature Tstg -40to+85 ℃ Soldering Temperature*1 Tsol 260±5 ℃ Power Dissipation Pd 75 mW Reverse Voltage VR 5 V Peak Forward Current*2 IFP 75 mA *1: Soldering time ≦ 5 seconds. Official Product *2: Pulse Width≦ 100μs and Duty≦ 1% . HV-331390/230/SYGXX-U1930 **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** HV-331390/230/SYGXX-U1930 Aug.16. 2021 Version of 1.0 Page 5/12 HV-331390/230/SYGXX-U1930 3.0mm Round LED LAMP with Holder Electrical and Optical Characteristic Parameter Symbo l Condition Min. Typ. Max. Unit Forward Voltage VF IF=20 mA ∕ 2.0 2.5 V Reverse Current IR VR= 5 V ∕ ∕ 10 μA Luminous Intensity IV IF=20 mA 10 30 ∕ mcd Viewing Angle 2θ1/2 IF=20 mA ∕ 60 ∕ deg Peak Wavelength λρ IF=20 mA ∕ 575 ∕ nm Dominant Wavelength λd IF=20 mA ∕ 570 ∕ nm Spectrum Radiation Bandwidth Δλ IF=20 mA ∕ 20 ∕ nm Notes: θ1/2 is the angle from optical centerline where the luminous intensity is 1/2 the optical centerline value. Official Product HV-331390/230/SYGXX-U1930 **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** HV-331390/230/SYGXX-U1930 Aug.16. 2021 Version of 1.0 Page 6/12 HV-331390/230/SYGXX-U1930 3.0mm Round LED LAMP with Holder Specifications for Bin Grading: Iv(mcd) Grade Min. Max. L 10 20 M 16 32 N 25 50 P 40 80 Q 63 125 λd(nm) Grade Min. Max. 5 566 569 6 568 571 7 570 573 8 572 575 9 574 577 Notes: 1.Luminous intensity:+/-15%. 2.Wavelength: +/-1nm. Official Product HV-331390/230/SYGXX-U1930 **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** HV-331390/230/SYGXX-U1930 Aug.16. 2021 Version of 1.0 Page 7/12 HV-331390/230/SYGXX-U1930 3.0mm Round LED LAMP with Holder Typical Electro-Optical Characteristics Curves Official Product HV-331390/230/SYGXX-U1930 **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** HV-331390/230/SYGXX-U1930 Aug.16. 2021 Version of 1.0 Page 8/12 HV-331390/230/SYGXX-U1930 3.0mm Round LED LAMP with Holder Soldering condition 1. Careful attention should be paid during soldering. When soldering, leave more then 2mm from solder joint to Led, and soldering beyond the base of the tie bar is recommended. 2. Avoiding applying any stress to the lead frame while the LED are at high temperature particularly when soldering. 3. Dip and hand soldering should not be done more than one time. 4. After soldering the LED, the epoxy bulb should be protected from mechanical shock or vibration until the LED return to room temperature. 5. A rapid-rate process is not recommended for cooling the LED down from the peak temperature. 6. Although the recommended soldering conditions are specified in the above table, dip or hand soldering at the lowest possible temperature is desirable for the LED. 7. Wave soldering parameter must be set and maintain according to recommended temperature and dwell time in the solder wave. Recommended soldering conditions Hand Soldering Wave Soldering Temp. at tip of iron 300℃ Max. (30W Max.) Preheat temp. 160℃ Max. (120 sec Max.) Soldering time 3 sec Max. Bath temp. & time 260 Max., 5 sec Max Distance Official Product 2mm Min.(From solder joint to Led) HV-331390/230/SYGXX-U1930 **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Distance 2mm Min. (From solder joint to Led) Customer Part No. Data Sheet No. **************** HV-331390/230/SYGXX-U1930 Aug.16. 2021 Version of 1.0 Page 9/12 HV-331390/230/SYGXX-U1930 3.0mm Round LED LAMP with Holder Reliability test items and conditions: The reliability of products shall be satisfied with items listed below. Confidence level:97% LTPD:3% Item Test Conditions Solder Heat TEMP:260℃±5 ℃ 10 SEC 76 PCS 0/1 Temperature Cycle H:+100℃ 15min ∫ 5min L:-40℃ 15min 300 CYCLES 76 PCS 0/1 3 Thermal H:+100℃ 5min ∫ 10sec L:-10℃ 5min 300 CYCLES 76 PCS 4 High Temperature Storage TEMP:100℃ 1000 HRS 76 PCS 5 Low Temperature Storage TEMP:-40℃ 1000 HRS 76 PCS 0/1 6 DC Operating Life TEMP:25℃ IF=20mA 1000 HRS 76 PCS 0/1 7 High Temperature / High Humidity 85℃/85%RH 1000 HRS 76 PCS 0/1 No 1 2 Shock Sample Size Failure Judgment Criteria Test Hours/Cycle Iv≦Ivt*0.5 or Vf≧U or Vf≦L Ac/Er 0/1 0/1 Note:Ivt:To test Iv value of the chip before the reliability test. Iv:The test value of the chip that has completed the reliability test U:Upper Specification Limit L:Lower Specification Limit Official Product HV-331390/230/SYGXX-U1930 **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** HV-331390/230/SYGXX-U1930 Aug.16. 2021 Version of 1.0 Page 10/12 HV-331390/230/SYGXX-U1930 3.0mm Round LED LAMP with Holder Packing Specification: 250PCS/Bag 1000PCS/In-Carton 10000PCS/Out-Carton HV-331390/230/SYGXX-U1930 Official Product HV-331390/230/SYGXX-U1930 **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** HV-331390/230/SYGXX-U1930 Aug.16. 2021 Version of 1.0 Page 11/12 HV-331390/230/SYGXX-U1930 3.0mm Round LED LAMP with Holder Revision History Revision Page Version No. Revision Date 1.0 08-16-2021 Initial Release Official Product HV-331390/230/SYGXX-U1930 **************** Specifications are subject to change without notice. Data and drawings herein are copyrighted. Customer Part No. Data Sheet No. **************** HV-331390/230/SYGXX-U1930 Aug.16. 2021 Version of 1.0 Page 12/12
HV-331390/230/SYGXX-U1930 价格&库存
很抱歉,暂时无法提供与“HV-331390/230/SYGXX-U1930”相匹配的价格&库存,您可以联系我们找货
  • 1+5.818781+0.75318
  • 10+4.0102710+0.51909
  • 100+2.90395100+0.37589
  • 500+2.40776500+0.31166
  • 1000+2.244891000+0.29058
  • 2000+2.106432000+0.27266
  • 5000+1.955095000+0.25307
  • 10000+1.8606810000+0.24085
  • 25000+1.7577025000+0.22752
库存:75
