HV-I8NB30G-MP9AA-U1930 数据手册
4.7mm Round LED LAMP WITH HOLDER
Harvatek 4.7mm Round LED LAMP WITH HOLDER
Official Product
Specifications are subject to change without notice. Data and
drawings herein are copyrighted.
Customer Part No.
Aug.14.2021
Version of 1.0
Data Sheet No.
Page 1/12
DISCLAIMER
HARVATEK reserves the right to make changes without further notice to any products herein to
improve reliability, function or design. HARVATEK does not assume any liability arising out of the
application or use of any product or circuit described herein; neither does it convey any license
under its patent rights, nor the rights of others.
LIFE SUPPORT POLICY
HARVATEK’s products are not authorized for use as critical components in life support devices or
systems without the express written approval of the President of HARVATEK or HARVATEK
INTERNATIONAL. As used herein:
1. Life support devices or systems are devices or systems which, (a) are intended for surgical
implant into the body, or (b) support or sustain life, and (c) whose failure to perform when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to
result in a significant injury of the user.
2. A critical component in any component of a life support device or system whose failure to perform
can be reasonably expected to cause the failure of the life support device or system, or to affect its
safety or effectiveness.
Official Product
Customer Part No.
Aug.14.2021
Version of 1.0
Data Sheet No.
Page 2/12
Compliance and Certification
ISO9002, QS9000 and ISO14001 Certified
RoHS Compliant
Orderable Information
H V - I8 NB 30 G - MP9AA - U1930
Series Name
HV :
HARVATEK
Color Code
Remark
U1930:
I8NB :
4.7mm Round LED Lamp With Holder.
Customer Product
With InGaN 470nm Blue Chip.
Code
30 : Viewing angle 30 deg.
G : HARVATEK Part No.
MP9 : Square HOLDER
AA : 1 LAMP
Features:
Stable Color
Popular 4.7mm through hole package.
Blue Diffused lens
Official Product
Customer Part No.
Aug.14.2021
Version of 1.0
Data Sheet No.
Page 3/12
Package Dimensions:
Notes:
1.All dimensions are millimeters.
2.Tolerance is +/-0.25mm unless otherwise noted.
3.Specifications are subject to change without notice.
Official Product
Customer Part No.
Aug.14.2021
Version of 1.0
Data Sheet No.
Page 4/12
Absolute Maximum Ratings at Ta=25℃
Parameter
Symbol
Rating
Unit
Forward Current
IF
30
mA
Operating Temperature
Topr
-40to+85
Storage Temperature
Tstg
-40to+85
Soldering Temperature*1
Tsol
260±5
Power Dissipation
Pd
100
mW
Reverse Voltage
VR
5
V
Peak Forward Current*2
IFP
100
mA
*1:Soldering time ≦ 5 seconds.
*2:Pulse Width≦ 100μs and Duty≦ 1%
Official Product
Customer Part No.
Aug.14.2021
Version of 1.0
Data Sheet No.
Page 5/12
Electrical and Optical Characteristic
Parameter
Symbol
Min.
Typ.
Max.
Unit
Test Condition
Luminous Intensity
Iv
500
1000
mcd
If=20mA
Viewing Angle
2θ ½
30
Deg
If=20mA
Peak Emission Wavelength
λρ
466
nm
If=20mA
Dominant Wavelength
λd
470
nm
If=20mA
Spectral Line Half-Width
△λ
18
nm
If=20mA
Forward Voltage
Vf
3.0
3.6
V
If=20mA
Reverse Current
IR
10
μA
VR=5V
Notes:
1.θ1/2 is the angle from optical centerline where the luminous intensity is 1/2
the optical centerline value.
2.Luminous intensity:±15%.
3.Wavelength:±1nm.
4.VF:±0.1V
Official Product
Customer Part No.
Aug.14.2021
Version of 1.0
Data Sheet No.
Page 6/12
Specifications for Bin Grading:
Iv(mcd)
Grade
Min.
Max.
V
500
1250
W
1000
2000
X
1600
3200
λd(nm)
Grade
Min.
Max.
2
463.5
466.5
3
465.5
468.5
4
467.5
470.5
5
469.5
472.5
6
471.5
474.5
Notes:
1.Luminous intensity:+/-15%.
2.Wavelength: +/-1nm.
Official Product
Customer Part No.
Aug.14.2021
Version of 1.0
Data Sheet No.
Page 7/12
Typical Electro-Optical Characteristics Curves
(25°C Ambient Temperature Unless Otherwise Noted)
Official Product
Customer Part No.
Aug.14.2021
Version of 1.0
Data Sheet No.
Page 8/12
Soldering condition
1.
Careful attention should be paid during soldering. When soldering, leave more then 2mm from
solder joint to Led, and soldering beyond the base of the tie bar is recommended.
2.
Avoiding applying any stress to the lead frame while the LED are at high temperature
particularly when soldering.
3.
Dip and hand soldering should not be done more than one time.
4.
After soldering the LED, the epoxy bulb should be protected from mechanical shock or vibration
until the LED return to room temperature.
5.
A rapid-rate process is not recommended for cooling the LED down from the peak temperature.
6.
Although the recommended soldering conditions are specified in the above table, dip or hand
soldering at the lowest possible temperature is desirable for the LED.
7.
Wave soldering parameter must be set and maintain according to recommended temperature
and dwell time in the solder wave.
• Recommended soldering conditions
Hand Soldering
Wave Soldering
Temp. at tip of iron
300℃ Max. (30W Max.)
Preheat temp.
160℃ Max. (120 sec Max.)
Soldering time
3 sec Max.
Bath temp. & time
260 Max., 5 sec Max
Distance
Official Product
2mm Min.(From solder joint to
Led)
Distance
2mm Min. (From solder joint
Customer Part No.
Aug.14.2021
Version of 1.0
to Led)
Data Sheet No.
Page 9/12
Reliability test items and conditions:
The reliability of products shall be satisfied with items listed below.
Confidence level:97%
LTPD:3%
Item
Test Conditions
Solder Heat
TEMP:260℃±5
10 SEC
76 PCS
0/1
Temperature Cycle
H:+100℃ 15min
∫ 5min
L:-40℃ 15min
300
CYCLES
76 PCS
0/1
3
Thermal
H:+100℃ 5min
∫ 10sec
L:-10℃ 5min
300
CYCLES
76 PCS
4
High Temperature
Storage
TEMP:100℃
1000 HRS
76 PCS
5
Low Temperature
Storage
TEMP:-40℃
1000 HRS
76 PCS
0/1
6
DC Operating Life
TEMP:25℃
IF=20mA
1000 HRS
76 PCS
0/1
7
High Temperature /
High Humidity
85℃/85%RH
1000 HRS
76 PCS
0/1
No
1
2
Shock
Sample
Size
Failure
Judgment
Criteria
Test
Hours/Cycle
Iv≦Ivt*0.5
or
Vf≧U
or
Vf≦L
Ac/Er
0/1
0/1
Note:Ivt:To test Iv value of the chip before the reliability test.
Iv:The test value of the chip that has completed the reliability test
U:Upper Specification Limit
L:Lower Specification Limit
Official Product
Customer Part No.
Aug.14.2021
Version of 1.0
Data Sheet No.
Page 10/12
Packing Specification:
500PCS/Bag
2000PCS/In-Carton
20000PCS/Out-Carton
Official Product
Customer Part No.
Aug.14.2021
Version of 1.0
Data Sheet No.
Page 11/12
Revision History
Revision
Page
Version No.
Revision Date
1.0
08-14-2021
Initial Release
Official Product
Customer Part No.
Aug.14.2021
Version of 1.0
Data Sheet No.
Page 12/12
HV-I8NB30G-MP9AA-U1930 价格&库存
很抱歉,暂时无法提供与“HV-I8NB30G-MP9AA-U1930”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+5.557481+0.72246
- 10+3.8102410+0.49532
- 100+2.75570100+0.35824
- 500+2.28113500+0.29654
- 1000+2.125261000+0.27628
- 2000+1.992772000+0.25906
- 5000+1.847825000+0.24021
- 10000+1.7573810000+0.22846
- 25000+1.6587625000+0.21564
