SWDC SERIES
SWDC-F060DNN-U1930
Ultraviolet (UV) sterilization technology is a technology that
inactivates bacterial virus microorganisms by using
ultraviolet radiation energy. Instantaneous high-energy
ultraviolet radiation is applied to the surface of bacterial
microorganisms. Ultraviolet radiation sterilization has the
characteristics of high efficiency sterilization, no resurrection
and no side effects.
Specifications are subject to change without notice.
© 2020-2023 Harvatek Corporation. All rights reserved.
SWDC-F060-DNN-U1930
Rev 3.0
SWDC-F060-DNN-U1930
SWDC-F060-DNN-U1930
SWDC-F060-DNN-U1930 series are
ultraviolet LED modules with high-power
ultraviolet ray emissions of 265-280 nm
which purifies water through destroying
micro-organisms. When the water flows
through the module, the ultraviolet rays
with high intensity sterilization kill the
bacteria microorganisms in the water to achieve the purpose of purification. This
module completely solves the problems of microbial contamination and bacteria
levels in drinking water exceeding standards, especially killing microorganisms such as
bacteria the flowing water and achieving instant effect during usage. It has vastly
improved the quality of daily life and has made the public’s drinking experience
convenient.
Product Feature:
1.
1
Sterilization efficiency up to 99.99%○
2.
Aesthetic module structure and appearance, quality material, and sterilization
effect certified by a number of third-party entities.
Module structure with multiple design aspects optimized, simple installation and
usage, safe and easy to manage
Fast sterilization, good performance, no heat, pure physical sterilization,
unaltered physical and chemical characteristics of water after sterilization,
colorless and odorless, and no by-products produced
The module housing is made of food-grade 304 stainless steel. It is light in weight,
very pressure resistant, has long life cycle and no pollution of heavy metal ions.
3.
4.
5.
1 The standard Escherichia coli ATCC25922 were used in a ISO100-grade laboratory to calculate the sterilization
rate by measuring the number of colonies before and after irradiation. Please contact us for detailed test methods
and bacteria strains used.
1
SWDC-F060-DNN-U1930
Rev 3.0
Product specification:
Module Spec:
Spec
Water Flow Rate
Symbol
SWDC-F060-DNN-U1930
L/min
6.0 (If water flow rate exceeds this, the
sterilization effect would decrease.)
Wavelength
Radiation
Typ.
Voltage
Min.
Power
2
Consumption○
Max
nm
265-280
mW
200
VCC
24
18
W
23
Connector Type
XH2.5 3Pin
Signal Detection
Either LED board open or short circuit
Series
SWDC-F060-DNN-U1930
Radiant Power
Max Flow rate
(mW)
(L/min)
180~210
6
Voltage (V)
Recommend Current (A)
24
1.17
DC Input: UL 24AWG
LED Driver
XH2.5 3Pin Connector
Red: 24V DC INPUT
Black: GND
Yellow: 5V DC OUTPUT
Fig .1 Wire Schematic
2
SWDC-F060-DNN-U1930
Rev 3.0
1.
Module dimension: Ø 63.5mm x (6L- 164.8)mm
6L 164.8mm
63.5
Ø 6.35 quick-connect connector
Fig.2 Outline Dimensions
2.
Water diverter: 304 Stainless Steel (can customize to medical grade 316
Stainless Steel)
3.
Outlet/Inlet diameter: Ø 9.5 quick-connect connector
4.
Depending on the flow rate, multiple high power LEDs will sterilize
micro-organisms at the same time (Please contact us for more details)
5.
Maximum influent water pressure: 1 MPa. It is strictly prohibited to exceed the
operating pressure
6.
Maximum design flow rate: As shown in the table below. Life cycle: can be lit
3
continuously for 3,000 hours or more○
7.
The module can be assembled either horizontally or vertically. If needed to
assemble in other ways, then please ask us prior to installing.
2 Power capacity above 55W
3 IESNA(Illuminating Engineering Society of North America) LM80 experimental method, 70%
Lumens depreciation evaluation standard
3
SWDC-F060-DNN-U1930
Rev 3.0
1.
2.
3.
Installation instructions:
It is recommended to fix the module vertically on a support. Connect to the
water network through the quick-connect connector provided along with the
module. Pay attention to the inlet and outlet port locations as shown in Figure 3.
Turn on the power and the LEDs will start by themselves while the system will
enter sterilization mode. By using external water flow to trigger the control
switch, LED sterilization will work in pulse modes of “water flows and the module
switches on” and “water stops and module switches off”. This will help extend
the life cycle of the module.
Module SWDC-F060-DNN-U1930 Series with two warning functions, provide
instant feedback of High (5V) module working status
4.
I.
LED short circuit
II.
LED open circuit
Installation is complete if the hydraulic pressure test can be carried out without
water leakage at 4 Kg/cm2. This module is designed to be splash proof, thus the
module can withstand ordinary water spray and still be in working order.
Fig. 3 Schematic diagram
4
SWDC-F060-DNN-U1930
Rev 3.0
Note:
Each type of microbial killing requires specific ultraviolet radiation energy. The
radiation of SWDC-F060-DNN-U1930 ultraviolet sterilization module, in strict
accordance with national standards, is 30mJ/cm2, which can kill more than 99.99% of
bacteria and viruses. When the to-be sterilized water is turbid, high in water hardness,
calcium, or magnesium, bacteria extermination may be weakened. Therefore, it is
recommended to set a filter device at the front end of the module inlet to reduce the
influence of water quality on bacteria eradication.
Ultraviolet rays also cause damages to the human body. For safety reasons, this
module is designed for all components to be assembled within an enclosed case
without any exchangeable repair parts inside. Therefore, it is not recommended to
disassemble the module by oneself unless necessary. Please be sure to open the
module under the professional guidance of our company.
History of Version
Revision
Date
Contents of Revision Change
Preliminary
Feb 1, 2019
New Establishment
Rev 1.0
Apr 29, 2019
Add SWDC-F060-DNN-U1930 specifications
Rev 2.0
Nov. 11. 2020
Add heat sink dimension information
Rev 3.0
Dec. 24. 2020
Modify power consumption
Remark
5
SWDC-F060-DNN-U1930 价格&库存
很抱歉,暂时无法提供与“SWDC-F060-DNN-U1930”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+5069.508211+656.67862
