SWDC-T103-DNN-U1930
SWDC-T103-DNN-U1930
    HARVATEK(宏齐)
    模块
    紫外线(UV) 发射器 265nm ~ 285nm 3mW 模块
SWDC-T103-DNN-U1930 数据手册
SWDC SERIES Ultraviolet (UV) sterilization technology destroys micro-organisms with instantaneous high-power ultraviolet ray emissions, featuring high efficiency sterilization, no resurrecting micro-organisms and no side effects. Specifications are subject to change without notice. © 2020-2023 Harvatek Corporation. All rights reserved. SWDC-T103DNN-U1930 SWDC-T103-DNN-U1930 Rev 1.0 SWDC-T103-DNN-U1930 SWDC-T103-DNN-U1930 are UVC LED based modules using high-power ultraviolet light emission between 265nm and 280 nm (UVC region). UV emission is an invisible light source subdivided in 3 regions: UVA, UVB and UVC (see graph below). A Wavelength between 230 & 285nm (UVC & UVB) is recommended for maximum efficiency of sterilization and disinfection. UVC & UVB are absorbed by the DNA and RNA of bacterial microorganisms, which can effectively sterilize our environment (water, air, surfaces). UVC sterilization has the highest efficiency in sterilization with no resurrection and no side effects. The SWDC modules totally solve the problems of bacterial contamination levels in drinking water, exceeding standards, achieving instant effect during usage. It has and will continue to vastly improve the quality of everyone’s daily life and has made the public’s drinking experience safer. SWDC-T103-DNN-U1930 use a deep ultraviolet LED as the UV-C light source combine which allow to sterilize instantly water in a water tank. The irradiance of UVC LED can reach 0.8 mW/ cm2. For any 4 liters water tank (170mmx300mm), measured sterilization rate in the water tank can reach over 99% after 30 ~40 mins irradiation. Specifications are subject to change without notice. © 2020-2023 Harvatek Corporation. All rights reserved. 1 SWDC-T103-DNN-U1930 Rev 1.0  Product Features: 1. 1 Sterilization efficiency over 99% ○ 2. Mercury free 3. Working life of 10,000 hours or more 4. Low standby operating current:< 0.1 uA 5. Lead-free environmentally friendly RoHS compatible 6. 2 Waterproof level up to IP68○ 1 In the laboratory working environment, using the standard E. coli method to count ○ the difference before and after sterilization; 2 Please refer to the test standard of IEC60529/GB4208 ○  Product Specification: 1. Module Spec: Spec Wavelength Min Radiant Typ. Voltage Symbol SWDC-T103-DNN-U1930 nm 265-285 mW V Min. Power 3 Consumption○ Max W Housing Type 2.5 3.0 24 0.2 0.4 Pitch 2.5/ 3Pin Signal Detection Life Cycle Weight LED board open circuit hrs 4 10,000○ g 13±10% 3 Power capacity above 5W ○ 4 IESNA (Illuminating Engineering Society of North America) LM80 experimental method, 70% ○ Lumens depreciation evaluation standard Specifications are subject to change without notice. © 2020-2023 Harvatek Corporation. All rights reserved. 2 SWDC-T103-DNN-U1930 Rev 1.0  SWDC-T103-DNN-U1930, Mechanical Specifications: LED Driver Circuit DC Input: 220mm UL 24AWG Pitch 2.5 / 3Pin Connector Red: 24V DC INPUT Black: GND Yellow: 5V DC OUTPUT Fig. 1 Wire Schematic Unit: mm Tolerance: ±0.2mm Fig. 2 Module Dimensions Specifications are subject to change without notice. © 2020-2023 Harvatek Corporation. All rights reserved. 3 SWDC-T103-DNN-U1930 Rev 1.0  Recommended installation Method Our sterilization module should be placed against the water tank wall, with the UV-C LED located in the center of the upper water tank, allowing the UVC light to diverge along the cross section of the water tank. The LED beam divergence of 125°, will allow the light to reach the top and bottom of the water tank with a conical area of 35mm (10 mm axial distance) of its irradiance. This will meet the National Standard regulation requirement of 30mJ/cm2, in about 10 minutes. The penetration depth of 265-285nm ultraviolet radiation is about 100mm in water. The LED module is controlled by an external circuit. This solution is specially designed for high-power UV LEDs. This can ensure the long-term stable operation of the LED, and will not affect the lifetime of the LED due to overheating. The main body consists of three parts: 1. Quartz glass waterproof and dust proof casing 2. UV-C LED mounted on aluminum substrate 3. Base platform. The UV-C LED on aluminum substrate is encapsulated in a quartz glass sealed to isolate water and other pollution, and the base is used to fix the integral module on the upper cover of the water tank. Note: If there is air between the UVC LED module and the water, the sterilization efficiency will be reduced. Fig. 3 4L cylindrical water tank installation diagram Specifications are subject to change without notice. © 2020-2023 Harvatek Corporation. All rights reserved. 4 SWDC-T103-DNN-U1930 Rev 1.0  Packing: 1. Protective Foam Dimension: 629 x310 x40 mm Quantity: 30 pieces/ layer Section A -A 2. Outer Carton Box Dimension: 630 x310 x440 mm Quantity: 10 layers/ box *Unit: mm *Tolerance: +/- 10mm Specifications are subject to change without notice. © 2020-2023 Harvatek Corporation. All rights reserved. 5 SWDC-T103-DNN-U1930 Rev 1.0  History of Version: Revision Date Contents of Revision Change Rev 1.0 Jan 14, 2020 New Establishment Remark Specifications are subject to change without notice. © 2020-2023 Harvatek Corporation. All rights reserved. 6
SWDC-T103-DNN-U1930
物料型号:SWDC-T103-DNN-U1930
器件简介:该模块基于UVC LED,使用265nm至280nm之间的高功率紫外线光发射,用于消毒和杀菌。
引脚分配:LED驱动电路的DC输入为220mm UL 24AWG,Pitch 2.5 / 3Pin连接器,红色线为24V DC输入,黑色线为GND,黄色线为5V DC输出。
参数特性: - 波长:265-285nm - 辐射强度:最小2.5mW,典型3.0mW - 工作电压:24V - 功率消耗:最大0.4W - 信号检测:LED板开路 - 工作寿命:超过10,000小时 - 重量:13±10%克
功能详解:模块使用深紫外线LED作为UVC光源,可以瞬间消毒水箱中的水。UVC LED的辐射强度可达0.8 mW/cm²。对于任何4升水箱,经过30至40分钟的照射,水中的消毒率可超过99%。
应用信息:模块解决了饮用水中细菌污染超标的问题,使用时可立即见效,显著提高了人们日常生活的质量,并使公众的饮水体验更安全。
封装信息:模块主体由三部分组成:石英玻璃防水防尘外壳、安装在铝基板上的UV-C LED、用于固定整体模块在水箱上盖的基座平台。
SWDC-T103-DNN-U1930 价格&库存
很抱歉,暂时无法提供与“SWDC-T103-DNN-U1930”相匹配的价格&库存,您可以联系我们找货
