T3A33BRG-H9C0002X1U1930 数据手册
Top View PLCC IC+RGB LEDs
Harvatek Surface Mount PLCC IC+RGB LEDs Data Sheet
7
Official Product
HT Part No.T3A33BRG-H9C0002X1U1930
Tentative Product
Specifications are subject to changes for improvement without advance
notice. Proprietary data, drawings, company confidential all rights reserved.
1/14/2022
Version 1.0
Page 1/18
DISCLAIMER ......................................................................................................................................... 3
LIFE SUPPORT POLICY ............................................................................................................. 3
PRODUCT SPECIFICATIONS............................................................................................................. 4
ATTENTION: ELECTROSTATIC DISCHARGE (ESD) PROTECTION ............................................... 4
LABEL SPECIFICATIONS ................................................................................................................... 5
PRODUCT FEATURES ......................................................................................................................... 6
PACKAGE OUTLINE DIMENSION AND RECOMMENDED SOLDERING PATTERN FOR REFLOW
SOLDERING ............................................................................................................................. 6
ABSOLUTE MAXIMUM RATINGS .................................................................................................... 7
ELECTRICAL CHARACTERISTICS ................................................................................................. 7
PRECAUTION FOR USE .................................................................................................................... 12
PACKAGING ........................................................................................................................................ 13
TAPE DIMENSION ................................................................................................................... 13
REEL .................................................................................................................................... 14
DIMENSION ............................................................................................................................ 14
PACKING ............................................................................................................................... 14
DRY PACK ............................................................................................................................ 15
BAKING................................................................................................................................. 15
PRECAUTIONS ....................................................................................................................... 15
HANDLING OF SILICONE RESIN LEDS ....................................................................................... 16
REFLOW SOLDERING ...................................................................................................................... 17
REWORKING .......................................................................................................................... 17
CLEANING ............................................................................................................................. 17
CAUTIONS OF PICK AND PLACE .............................................................................................. 17
REVISE HISTORY ................................................................................................................... 18
7
Official Product
Tentative Product
1/14/2022
Version 1.0
Page 2/18
DISCLAIMER
HARVATEK reserves the right to make changes without further notice to any products herein to
improve reliability, function or design. HARVATEK does not assume any liability arising out of
the application or use of any product or circuit described herein; neither does it convey any
license under its patent rights, nor the rights of others.
Life Support Policy
HARVATEK’s products are not authorized for use as critical components in life support devices
or systems without the express written approval of the President of HARVATEK or HARVATEK
INTERNATIONAL. As used herein:
1. Life support devices or systems are devices or systems which, (a) are intended for surgical
implant into the body, or (b) support or sustain life, and (c) whose failure to perform when
properly used in accordance with instructions for use provided in the labeling, can be
reasonably expected to result in a significant injury of the user.
2. A critical component in any component of a life support device or system whose failure to
perform can be reasonably expected to cause the failure of the life support device or system, or
to affect its safety or effectiveness.
7
Official Product
Tentative Product
1/14/2022
Version 1.0
Page 3/18
Product Specifications
Item
Specification
Luminous
R:560.0-1125.0 mcd
Intensity (Iv)
G:1125.0-2850.0 mcd
Material
Quantity
B:285.0-715.0 mcd
IC@5V
o
Ts= 25 C;Tolerance: + 10%
Dominant
R:615.0-630.0 nm
Wavelength (Wd) G:515.0-535.0 nm
B:460.0-476.0 nm
IC@5V
o
TS= 25 C;Tolerance: + 1 nm
Applied voltage
5V_DC
Resin
Clear
Silicone
Carrier tape
EIA 481-1A specs
Conductive black tape
Reel
EIA 481-1A specs
Conductive black
Label
HT standard
Paper
Packing bag
220x240mm
Aluminum laminated bag/ no-zipper
One reel per bag
Carton
HT standard
Paper
Non-specified
1000
Others:
Each immediate box consists of 5 reels. The 5 reels may not necessarily have the same lot number or the same bin
combinations of Iv, λD and Vf. Each reel has a label identifying its specification; the immediate box consists of a product label
as well.
Note :This is shipped test conditions
※Remarks: This product should be operated in forward bias. If a reverse voltage is continuously applied to the product,
such operation can cause migration resulting in LED damage.
ATTENTION: Electrostatic Discharge (ESD) protection
The symbol to the left denotes that ESD precaution is needed. ESD protection for GaP and AlGaAs based
chips is necessary even though they are relatively safe in the presence of low static-electric discharge. Parts
built with AlInGaP, GaN, or/and InGaN based chips are STATIC SENSITIVE devices. ESD precaution must
be taken during design and assembly.
If manual work or processing is needed, please ensure the device is adequately protected from ESD during the process.
7
Official Product
Tentative Product
1/14/2022
Version 1.0
Page 4/18
Label Specifications
■Harvatek P/N:
T
3A3
Product
3
BRG-
Dice Q’ty
H9C-
0002
X1
Current
1.
LF
3.TRI+IC
5V
2.
Package
Color
Series Number
5.36(L)x5.0(W)x1.6(H) mm
BRG
X001~XZZZ
U1930
Taping
Customer Code
Taping
Customer
style
Product Code
Q’ty
■ Lot No.:
7
Official Product
Tentative Product
1/14/2022
Version 1.0
Page 5/18
Product Features
Electro-Optical Characteristics
o
(TSoldering , 25 C)
Wavelength λ(nm)
Series
T3A33BRG
Emitting Color
Material
IV(mcd)
λD
λP
△λ
Typical
Viewing
Angle
B
InGaN
470
465
25
400
120
R
AlInGaP
624
630
18
800
120
G
InGaN
523
518
35
1800
120
2
1
2
Package Outline Dimension and Recommended Soldering Pattern for Reflow Soldering
(Unit:mm Tolerance: +/-0.1)
Outline Dim.
Soldering Pattern
Soldering terminals may shift in the Wd direction.
7
Official Product
Tentative Product
1/14/2022
Version 1.0
Page 6/18
Absolute Maximum Ratings
o
(TA=25 C)
Symbol
Parameter
VDD
Supply Voltage
PD
Power Dissipation
ILEDOUT
Maximum Output Current
TM
Welding Temperature
Range
Units
6.5
V
T3A33BRG-H9C0002X1U1930 价格&库存
很抱歉,暂时无法提供与“T3A33BRG-H9C0002X1U1930”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+7.495021+0.97068
- 10+5.1932110+0.67258
- 100+3.80167100+0.49236
- 500+3.17981500+0.41182
- 国内价格 香港价格
- 1+7.500981+0.97146
