T3A53RGB-12C610111U1930
    HARVATEK(宏齐)
    4-SMD,J形引线
    红色,绿色,蓝色(RGB) 623nm 红色,525nm 绿色,465nm 蓝色 LED 指示 - 分立 4-SMD,J 形引线
T3A53RGB-12C610111U1930 数据手册
Top View Chip IC+RGB LED T3A53RGB-12C610111U1930 Harvatek Surface Mount CHIP LEDs Data Sheet T3A53RGB-12C610111U1930 (Preliminary) 7 Official Product HT Part No.T3A53RGB-12C610111U1930 Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. **************** 03/29/2023 Preliminary Page 1/16 Top View Chip IC+RGB LED T3A53RGB-12C610111U1930 DISCLAIMER ......................................................................................................................................... 3 LIFE SUPPORT POLICY ............................................................................................................. 3 PRODUCT SPECIFICATIONS............................................................................................................. 4 ATTENTION: ELECTROSTATIC DISCHARGE (ESD) PROTECTION ............................................... 4 LABEL SPECIFICATIONS ................................................................................................................... 5 PACKAGE OUTLINE DIMENSION AND RECOMMENDED SOLDERING PATTERN FOR REFLOW SOLDERING ............................................................................................................................. 5 ELECTRICAL CHARACTERISTICS ................................................................................................. 7 PRECAUTION FOR USE .................................................................................................................... 12 PACKAGING ........................................................................................................................................ 13 TAPE DIMENSION ................................................................................................................... 13 REEL .................................................................................................................................... 14 DIMENSION ............................................................................................................................ 14 PACKING ............................................................................................................................... 14 DRY PACK ............................................................................................................................ 15 BAKING................................................................................................................................. 15 PRECAUTIONS ....................................................................................................................... 15 HANDLING OF SILICONE RESIN LEDS ....................................................................................... 16 REFLOW SOLDERING ...................................................................................................................... 17 REWORKING .......................................................................................................................... 17 CLEANING ............................................................................................................................. 17 CAUTIONS OF PICK AND PLACE .............................................................................................. 17 REVISE HISTORY ................................................................................................................... 18 7 Official Product HT Part No.T3A53RGB-12C610111U1930 Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. **************** 03/29/2023 Preliminary Page 2/16 Top View Chip IC+RGB LED T3A53RGB-12C610111U1930 DISCLAIMER HARVATEK reserves the right to make changes without further notice to any products herein to improve reliability, function or design. HARVATEK does not assume any liability arising out of the application or use of any product or circuit described herein; neither does it convey any license under its patent rights, nor the rights of others. Life Support Policy HARVATEK’s products are not authorized for use as critical components in life support devices or systems without the express written approval of the President of HARVATEK or HARVATEK INTERNATIONAL. As used herein: 1. Life support devices or systems are devices or systems which, (a) are intended for surgical implant into the body, or (b) support or sustain life, and (c) whose failure to perform when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in a significant injury of the user. 2. A critical component in any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. 7 Official Product HT Part No.T3A53RGB-12C610111U1930 Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. **************** 03/29/2023 Preliminary Page 3/16 Top View Chip IC+RGB LED T3A53RGB-12C610111U1930 Product Specifications Item Specification Material Luminous Red:320-580 mcd Intensity Green:815-1275 mcd Quantity Blue:160-320 mcd o @12mA; Ts= 25 C;Tolerance: + 10% Red:620-625 nm Wavelength Green:520-530 nm Blue:460-470 nm o @12mA; TS= 25 C;Tolerance: + 1 nm Vf Red : 2.0-2.3 V Green : 2.6-2.8 V Blue : 2.7-3.0 V o @12mA; TS= 25 C ;Tolerance: + 0.1 V Applied voltage 12mA Resin Clear Silicone Carrier tape EIA 481-1A specs Conductive black tape Reel EIA 481-1A specs Conductive black Label HT standard Paper Packing bag 250x230mm Aluminum laminated bag/ no-zipper One reel per bag Carton HT standard Paper Non-specified 1000 Others: Each immediate box consists of 5 reels. The 5 reels may not necessarily have the same lot number or the same bin combinations of Iv, λD and Vf. Each reel has a label identifying its specification; the immediate box consists of a product label as well. Note :This is shipped test conditions ※Remarks: This product should be operated in forward bias. If a reverse voltage is continuously applied to the product, such operation can cause migration resulting in LED damage. ATTENTION: Electrostatic Discharge (ESD) protection The symbol to the left denotes that ESD precaution is needed. ESD protection for GaP and AlGaAs based chips is necessary even though they are relatively safe in the presence of low static-electric discharge. Parts built with AlInGaP, GaN, or/and InGaN based chips are STATIC SENSITIVE devices. ESD precaution must be taken during design and assembly. If manual work or processing is needed, please ensure the device is adequately protected from ESD during the process. 7 Official Product HT Part No.T3A53RGB-12C610111U1930 Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. **************** 03/29/2023 Preliminary Page 4/16 Top View Chip IC+RGB LED T3A53RGB-12C610111U1930 Label Specifications ■Harvatek P/N: T 3A5 3 Product Package Dice Q’ty Color 61 01 11 Current System Series Number Taping 12mA 00~ZZ 01~ZZ RGB 5.0(L)x5.4(W)x1.6(H) LF RGB- 12C- 1.Taping style 3:Tri 2. Q’ty (Full Color) mm ■ Lot No.: Package Outline Dimension and Recommended Soldering Pattern for Reflow Soldering (Unit:mm Tolerance: +/-0.1) Outline Dim. Soldering Pattern 7 Official Product HT Part No.T3A53RGB-12C610111U1930 Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. **************** 03/29/2023 Preliminary Page 5/16 Top View Chip IC+RGB LED T3A53RGB-12C610111U1930 Soldering terminals may shift in the Wd direction. 7 Official Product HT Part No.T3A53RGB-12C610111U1930 Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. **************** 03/29/2023 Preliminary Page 6/16 Top View Chip IC+RGB LED T3A53RGB-12C610111U1930 Electrical characteristics o (Max., TA=25 C, VSS=0V) Parameter Symbol Range Unit Power supply voltage VDD +3.7~+5.5 V Logic input voltage VIN -0.5~VDD+0.5 V Reverse Voltage VR 12 V Working temperature Topt -40~+85 ℃ Storage temperature Tstg -40~+85 ℃ ESD pressure(DM) VESD 200 V ESD pressure(HBM) VESD 2K V o (TA=-20~+70 C, VDD=4.5~5.5V, VSS=0V) Parmeter Symbol Min Typical Max Unit Test conditions The chip supply voltage VDD - 5.2 - V - VIH 0.7*VDD - - V VIL - - 0.3*VDD V The frequency of PWM FPWM - 1.0 - KHZ - Static power consumption IDD - 0.5 - mA - The signal input flip threshold VDD=5.0V 7 Official Product HT Part No.T3A53RGB-12C610111U1930 Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. **************** 03/29/2023 Preliminary Page 7/16 Top View Chip IC+RGB LED T3A53RGB-12C610111U1930  Switching characteristics o (TA=25 C) Parameter The speed of data Symbol Min Typical Max Unit fDIN --- 800 --- KHZ Test conditions The duty ratio of 67% transmission (data 1) TPLH --- 67 --- ns The earth load capacitance of the DOUT transmission delay TPHL --- 82 --- dout port is 30pf, and ns the signal transmission Tr --- 22 --- delay from DIN to IOUT R / B= 12mA, out dout R / B port connected ns Out R/B conversion time with 200 Ω resistor to Tf Tr --- --- 75 18 --- --- ns VDD in series, load ns capacitance to IOUT g = 12mA, out g ground port is connected Out G conversion time with 200 Ω resistor to Tf --- VDD in series, and the 110 --- ns load capacitance to ground is 30pf 7 Official Product HT Part No.T3A53RGB-12C610111U1930 Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. **************** 03/29/2023 Preliminary Page 8/16 Top View Chip IC+RGB LED T3A53RGB-12C610111U1930 ■ ■ Application circuit No. Symbol Pin Function 1 VDD Power Power 2 DOUT Data Output Control Data Signal Output 3 VSS Ground Ground 4 DIN Data Input Control Data Signal Intput Cascading data structure (TH+TL=1.25us± 600ns) Symbol Min Typ. Max Units - µs 0.4 µs T T cycle 1.2 T0H 0, High 0.2 T0L 0, Low 0.8 T1H 1, High 0.6 0.67 1.0 µs T1L 1, Low 0.2 -- -- µs Reset Reset, Low >80 -- -- µs 0.3 ns 7 Official Product HT Part No.T3A53RGB-12C610111U1930 Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. **************** 03/29/2023 Preliminary Page 9/16 Top View Chip IC+RGB LED T3A53RGB-12C610111U1930 ■ Timing waveform(Ta=25oC) ■ Connection method ■ Data transmission method(Ta=25oC) 7 Official Product HT Part No.T3A53RGB-12C610111U1930 Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. **************** 03/29/2023 Preliminary Page 10/16 Top View Chip IC+RGB LED T3A53RGB-12C610111U1930 ■ 24 bit Data Structure Note: High order first, send data in the order of GRB (G7 → G6 →…….. →B0) ■ Typical Application Circuit 7 Official Product HT Part No.T3A53RGB-12C610111U1930 Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. **************** 03/29/2023 Preliminary Page 11/16 Top View Chip IC+RGB LED T3A53RGB-12C610111U1930 Precaution for Use 1. The chips should not be used directly in any type of fluid such as water, oil, organic solvent, etc. 2. When the LEDs are illuminating, the maximum ambient temperature should be first considered before operation. 3. LEDs must be stored in a clean environment. A sealed container with a nitrogen atmosphere is necessary if the storage period is over 3 months after shipping. 4. The LEDs must be used within 48 hrs after unpacked. Unused products must be repacked 5. 6. in an anti-electrostatic package, folded to close any opening and then stored in a dry and cool space. The appearance and specifications of the products may be modified for improvement without further notice. The LEDs are sensitive to the static electricity and surge. It is strongly recommended to use a grounded wrist band and anti-electrostatic glove when handling the LEDs.If a voltage over the absolute maximum rating is applied to LEDs, it will damage LEDs.Damaged LEDs will show some abnormal characteristics such as remarkable increase of leak current, lower turn-on voltage and getting unlit at low current. 7 Official Product HT Part No.T3A53RGB-12C610111U1930 Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. **************** 03/29/2023 Preliminary Page 12/16 Top View Chip IC+RGB LED T3A53RGB-12C610111U1930 Packaging Tape Dimension Unit : mm 7 Official Product HT Part No.T3A53RGB-12C610111U1930 Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. **************** 03/29/2023 Preliminary Page 13/16 Top View Chip IC+RGB LED T3A53RGB-12C610111U1930 Reel Dimension Unit : mm Packing 5 or 10 boxes per carton is available depending on shipment quantity. 7 Official Product HT Part No.T3A53RGB-12C610111U1930 Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. **************** 03/29/2023 Preliminary Page 14/16 Top View Chip IC+RGB LED T3A53RGB-12C610111U1930 Dry Pack All SMD optical devices are MOISTURE SENSITIVE. Avoid exposure to moisture at all times during transportation or storage. Every reel is packaged in a moisture protected anti-static bag. Each bag is properly sealed prior to shipment. Upon request, a humidity indicator will be included in the moisture protected anti-static bag prior to shipment. The packaging sequence is as follows: Baking Baking before soldering is recommended when the package has been unsealed for 48 hrs. The conditions are as followings: 1. 60±3℃×(12~24hrs)and
T3A53RGB-12C610111U1930 价格&库存
很抱歉,暂时无法提供与“T3A53RGB-12C610111U1930”相匹配的价格&库存,您可以联系我们找货
