T4642PTIRM3B000351U1930
    HARVATEK(宏齐)
    SIP4
    光学传感器 反射 光电晶体管 4-SMD,鸥翼
T4642PTIRM3B000351U1930 数据手册
SMD Type Reflective Interrupter T4642PTIRM3B000351U1930 Harvatek Surface Mount Reflective Interrupter Data Sheet T4642PTIRM3B000351U1930 Official Product HT Part No. T4642PTIRM3B000351U1930 Customer Part No. Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. Data Sheet No. **************** 11/25/2022 1.3 Page 1/17 SMD Type Reflective Interrupter T4642PTIRM3B000351U1930 DISCLAIMER .................................................................................................................................... 3 LIFE SUPPORT POLICY ............................................................................................................. 3 PRODUCT SPECIFICATIONS ........................................................................................................ 4 ATTENTION: ELECTROSTATIC DISCHARGE (ESD) PROTECTION ................................................ 4 LABEL SPECIFICATIONS .............................................................................................................. 5 ELECTRO-OPTICAL CHARACTERISTICS ................................................................................. 7 PACKAGE OUTLINE DIMENSION AND RECOMMENDED SOLDERING PATTERN FOR REFLOW SOLDERING ............................................................................................................................. 9 CHARACTERISTICS OF T4642PTIR ............................................................................................. PACKAGING ................................................................................................................................... 13 TAPE DIMENSION ................................................................................................................... 13 REEL DIMENSION ................................................................................................................... 14 PACKING ............................................................................................................................... 14 DRY PACK ............................................................................................................................. 15 BAKING ................................................................................................................................ 15 PRECAUTIONS ....................................................................................................................... 15 REFLOW SOLDERING.................................................................................................................. 16 REWORKING .......................................................................................................................... 16 CLEANING ............................................................................................................................. 16 CAUTIONS OF PICK AND PLACE .............................................................................................. 17 REVISE HISTORY.................................................................................................................... 17 Official Product HT Part No. T4642PTIRM3B000351U1930 Customer Part No. Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. Data Sheet No. **************** 11/25/2022 1.3 Page 2/17 SMD Type Reflective Interrupter T4642PTIRM3B000351U1930 DISCLAIMER HARVATEK reserves the right to make changes without further notice to any products herein to improve reliability, function or design. HARVATEK does not assume any liability arising out of the application or use of any product or circuit described herein; neither does it convey any license under its patent rights, nor the rights of others. Life Support Policy HARVATEK’s products are not authorized for use as critical components in life support devices or systems without the express written approval of the President of HARVATEK or HARVATEK INTERNATIONAL. As used herein: 1. Life support devices or systems are devices or systems which, (a) are intended for surgical implant into the body, or (b) support or sustain life, and (c) whose failure to perform when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in a significant injury of the user. 2. A critical component in any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. Official Product HT Part No. T4642PTIRM3B000351U1930 Customer Part No. Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. Data Sheet No. **************** 11/25/2022 1.3 Page 3/17 SMD Type Reflective Interrupter T4642PTIRM3B000351U1930 Product Specifications Item Specification Material Quantity Detector Spectral Bandwidth 700nm~1100nm λD @ VCE=5V / TS = 25℃ Tolerance: ±10% Emitter Peak Wavelength Typ: 940nm λP @10 mA / TS = 25℃ Collector Light Current 0.18~0.40 mA, Tolerance: ±10% IC @ VCE=5V , IF=10mA , d=1 mm Resin Black Silicone Carrier tape EIA 481-1A specs Conductive black tape Reel EIA 481-1A specs Conductive black Label HT standard Paper Packing bag 250x230mm Aluminum laminated bag/ no-zipper One reel per bag Carton HT standard Paper Non-specified Others: Each immediate box consists of 5 reels. The 5 reels may not necessarily have the same lot number or the same bin combinations of Iv, CIE and Vf. Each reel has a label identifying its specification; the immediate box consists of a product label as well. Note :This is shipped test conditions ※Remarks: This product should be operated in forward bias. If a reverse voltage is continuously applied to the product, such operation can cause migration resulting in LED damage. ATTENTION: Electrostatic Discharge (ESD) protection The symbol to the left denotes that ESD precaution is needed. ESD protection for GaP and AlGaAs based chips and Silicon semiconductor is necessary even though they are relatively safe in the presence of low static-electric discharge. Parts built with AlGaInP, GaN, or/and InGaN based chips are STATIC SENSITIVE devices. ESD precaution must be taken during design and assembly. If manual work or processing is needed, please ensure the device is adequately protected from ESD during the process. Official Product HT Part No. T4642PTIRM3B000351U1930 Customer Part No. Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. Data Sheet No. **************** 11/25/2022 1.3 Page 4/17 SMD Type Reflective Interrupter T4642PTIRM3B000351U1930 Label Specifications ■Harvatek P/N: T 464 2 PTIR M3B- 0003 51 Product Package Dice Q’ty Type Voltage Series Number Taping PCB 4.6(L)x3.4(W)x1.62(H) mm 2:Bi PT:Phototransistor PT:5V X001~XZZZ IR:Infrared IR:10mA 1.Taping style 2. Q’ty ■ Lot No.: Official Product HT Part No. T4642PTIRM3B000351U1930 Customer Part No. Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. Data Sheet No. **************** 11/25/2022 1.3 Page 5/17 SMD Type Reflective Interrupter T4642PTIRM3B000351U1930 Absolute Maximum Rating at 25℃ Symbol Parameters Ratings Units Notes INPUT (Emitter) VR Reverse Voltage 5 V IF Forward Current 50 mA IFP Peak Forward Current 1 A Pd Total Power Dissipation 75 mW 1 OUTPUT (Detector) BVCEO Collector-Emitter Breakdown Voltage 30 V 2 BVECO Emitter-Collector Breakdown Voltage 5 V 3 IC Collector Current 20 mA Pd Total Power Dissipation 75 mW SENSOR Topr Operating Temperature -40 ~ +85 ℃ Tstg Storage Temperature -40 ~ +100 ℃ Tsol Soldering Temperature 260 ℃ 4 Notes: 1. IFP Conditions--Pulse Width≦100μs and Duty≦1%. 2. Test conditions : IC=100μA, Ee=0mW/cm2. 3. Test conditions : IE=100μA, Ee=0mW/cm2. 4. Soldering time≦5 seconds. Official Product HT Part No. T4642PTIRM3B000351U1930 Customer Part No. Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. Data Sheet No. **************** 11/25/2022 1.3 Page 6/17 SMD Type Reflective Interrupter T4642PTIRM3B000351U1930 Electro-Optical Characteristics Symbol Parameters Test conditions Min Typ Max Units IF=20mA - 1.2 1.6 V INPUT (Emitter) VF Forward Voltage λP Peak Wavelength IF=10mA - 940 - nm IR Reverse Current VR=5V - - 10 μA Collector-Emitter Saturation Voltage IC=2mA Ee=1mW/cm² - - 0.4 V Collector Dark Current VCE=10V Ee=0mW/cm² - - 100 nA 0.18 - 0.4 mA - - 1 μA - 20 - μS - 20 - μS Notes OUTPUT (Detector) VCE(sat) ICEO SENSOR VCE=5V IC(ON) ILEAK Collector Light Current IF=10mA d=1 mm VCE=5V IF=10mA Leakage Current 5 with no reflection tr Rise Time tf Fall Time VCE=2V IC=100µA RL=1KΩ d=1 mm 6 Notes: 5. Ic Bin Rank (mA): Bin Code BX3 BX4 BX5 BX6 BX7 Min 0.18 0.23 0.28 0.33 0.38 Max 0.23 0.28 0.33 0.38 0.4 Official Product HT Part No. T4642PTIRM3B000351U1930 Customer Part No. Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. Data Sheet No. **************** 11/25/2022 1.3 Page 7/17 SMD Type Reflective Interrupter T4642PTIRM3B000351U1930 Notes: 6.  Test circuit: Light Current Measurement Setup Diagram Official Product HT Part No. T4642PTIRM3B000351U1930 Customer Part No. Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. Data Sheet No. **************** 11/25/2022 1.3 Page 8/17 SMD Type Reflective Interrupter T4642PTIRM3B000351U1930 Package Outline Dimension and Recommended Soldering Pattern for Reflow Soldering (Unit: mm Tolerance: +/-0.1) Outline Dim. Soldering terminals may shift in the x, y direction. Official Product HT Part No. T4642PTIRM3B000351U1930 Customer Part No. Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. Data Sheet No. **************** 11/25/2022 1.3 Page 9/17 SMD Type Reflective Interrupter T4642PTIRM3B000351U1930 Characteristics of T4642PTIR Official Product HT Part No. T4642PTIRM3B000351U1930 Customer Part No. Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. Data Sheet No. **************** 11/25/2022 1.3 Page 10/17 SMD Type Reflective Interrupter T4642PTIRM3B000351U1930 Official Product HT Part No. T4642PTIRM3B000351U1930 Customer Part No. Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. Data Sheet No. **************** 11/25/2022 1.3 Page 11/17 SMD Type Reflective Interrupter T4642PTIRM3B000351U1930 Precaution for Use 1. The chips should not be used directly in any type of fluid such as water, oil, organic 2. 3. 4. 5. solvent, etc. When the LEDs are illuminating, the maximum ambient temperature should be first considered before operation. LEDs must be stored in a clean environment. A sealed container with a nitrogen atmosphere is necessary if the storage period is over 3 months after shipping. The LEDs must be used within 72 hours after unpacked. Unused products must be repacked in an anti-electrostatic package, folded to close any opening and then stored in a dry and cool space. The appearance and specifications of the products may be modified for improvement without further notice. 6. The LEDs are sensitive to the static electricity and use a grounded wrist band and anti-electrostatic voltage over the absolute maximum rating is LEDs.Damaged LEDs will show some abnormal surge. It is strongly recommended to glove when handling the LEDs.If a applied to LEDs, it will damage characteristics such as remarkable increase of leak current, lower turn-on voltage and getting unlit at low current. Official Product HT Part No. T4642PTIRM3B000351U1930 Customer Part No. Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. Data Sheet No. **************** 11/25/2022 1.3 Page 12/17 SMD Type Reflective Interrupter T4642PTIRM3B000351U1930 Packaging Tape Dimension Dim. A Dim. B Dim. C Q’ty/Reel 4.95±0.10 3.60±0.10 1.72±0.10 1K Unit: mm Official Product HT Part No. T4642PTIRM3B000351U1930 Customer Part No. Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. Data Sheet No. **************** 11/25/2022 1.3 Page 13/17 SMD Type Reflective Interrupter T4642PTIRM3B000351U1930 Reel Dimension Packing 5 or 10 boxes per carton is available depending on shipment quantity. Official Product HT Part No. T4642PTIRM3B000351U1930 Customer Part No. Tentative Product **************** Specifications are subject to changes for improvement without advance notice. Proprietary data, drawings, company confidential all rights reserved. Data Sheet No. **************** 11/25/2022 1.3 Page 14/17 SMD Type Reflective Interrupter T4642PTIRM3B000351U1930 Dry Pack All SMD optical devices are MOISTURE SENSITIVE. Avoid exposure to moisture at all times during transportation or storage. Every reel is packaged in a moisture protected anti-static bag. Each bag is properly sealed prior to shipment. A humidity indicator will be included in the moisture protected anti-static bag prior to shipment. The packaging sequence is as follows: Baking Baking before soldering is recommended when the package has been unsealed for 72 hours. The conditions are as followings: 1. 60±3℃×(12~24hrs)and
T4642PTIRM3B000351U1930 价格&库存
很抱歉,暂时无法提供与“T4642PTIRM3B000351U1930”相匹配的价格&库存,您可以联系我们找货
