H-KT-STARTER-RASP-CELL-1-0
    HELIUM
    - Helium Atom 收发器; 802.15.4(ZigBee®) 850MHz,868MHz,915MHz,1.8GHz,1.9GHz,2.1GHz,2.4GHz 评估板
H-KT-STARTER-RASP-CELL-1-0 数据手册
      Helium Starter Kit ‐ Cellular Choose your hardware adapter (Arduino/mbed, Raspberry Pi, USB) to get started.  Product Details  Helium Starter Kits include everything you need to easily give your embedded devices secure, long‐range  connectivity.   Included Hardware:   1 x Helium Element Access Point with Cellular Connectivity  1 x Helium Atom Prototyping Module (US Model)  1 x Hardware Adapter (Arduino/mbed, Raspberry Pi, or USB)  Note about US Model Hardware: Helium ships our prototyping kits worldwide, however cellular  connectivity and radio bands may not work in all countries.    About the Helium Atom Prototyping Module  The Helium Atom Prototyping Module is the prototyping version of our secure, low‐power, dual‐band  wireless module. The pin layout is compatible with many existing embedded devices, including Raspberry  Pi, Arduino, and mbed.   Atom devices connect to the nearest Element out of the box using Helium's wireless technology that  allows devices to communicate long distances with little interference and requiring no device‐level  configuration. Each element can support multiple atoms. Some embedded devices some may require an  additional adapter, contact us at human@helium.com if you have any questions before purchasing.   Technical Specifications  Networking  Standards  IEEE 802.15.4  802.15.4 IEEE Standard on dual‐band radios  Wireless  Connectivity  915 MHz & 2.4 GHz (US)  868 MHz & 2.4GHz (EU)  Security  Hardware‐based encryption, authentication, and authorization  Environmental  Range  Operating Temperature ‐40° to 185°F (‐40° to 85°C)  Atom:  Product Dimensions  Length: 1.06" (27mm)  Width: 1.1" (28mm)  Certifications  FCC ID: 2ADMK‐1 IC ID: 12590A‐1  Voltage Range  2.0 to 3.6V (3.3V typical; 2.4V recommended minimum for full TX power at  915MHz)    About the Helium Element Access Point  Atom devices connect out of the box to the nearest Element. Helium's wireless technology allows devices  to communicate long distances with little interference, requires no device‐level configuration, and each  Element can support thousands of Atom devices. This means you may only need one Element to cover an  entire office building, two for a manufacturing facility, or three for a multi‐acre farm.   The Element wirelessly connects to the Helium Routing Infrastructure anywhere there is cellular service,  allowing for zero‐configuration deployment for various applications and data is securely routed to any  cloud platform of your choice.   Technical Specifications  Networking  Standards  IEEE 802.15.4  802.15.4 IEEE Standard on dual‐band radios  Wireless  Connectivity  915 MHz & 2.4 GHz (US)  868 MHz & 2.4GHz (EU)  Security  Hardware‐based encryption, authentication, and authorization  Environmental  Range  Operating Temperature ‐40° to 185°F (‐40° to 85°C)  Element:  Product Dimensions  Length: 4.13" (105mm)  Width: 4.3" (28mm)  Height: 1.57" (40mm)  Certifications  FCC ID: 2ADMK‐1 IC ID: 12590A‐1  Voltage Range  2.0 to 3.6V (3.3V typical; 2.4V recommended minimum for full TX power at  915MHz)        https://www.helium.com/products/helium‐starter‐kit‐cell 12‐5‐17
H-KT-STARTER-RASP-CELL-1-0 价格&库存
很抱歉,暂时无法提供与“H-KT-STARTER-RASP-CELL-1-0”相匹配的价格&库存,您可以联系我们找货
