32645S
32645S
    HITECCOMMERCIALSOLUTIONS
    HS-645MG HIGH TORQUE METAL GEAR
32645S 数据手册
HS-645MG General Specification. STANDARD DELUXE HIGH TORQUE SERVO Control system Position sensor type PWM - Contact Analog Potentiometer - 4.8 ~ 6.0 V - Operating voltage range Motor type Cored Metal Brush Voltage 4.8V No load speed - 6.0V - 0.24sec/60˚ 0.2 sec/60˚ - 7.7 kgf·cm(106.93oz·in) 9.6 kgf·cm(133.32oz·in) - At 25°C, 45% (±10%) Standing current 8.8mA 9.1mA - measurement environment No load running current 350mA 450mA - - - - 8usec 8usec - Stall torque Stall current Dead band width Operating travel Operating temperature range 45˚/One side pulse traveling 400usec - -20˚C ~ +60˚C (-4˚F ~+140˚F) - - - -30˚C ~ +80˚C (-31˚F ~+176˚F) - Vibrations at no load Storage temperature range Connector wire length 300mm(11.81inch) Connector wire gauge 22AWG Dimensions 40.6 mm x 19.8 mm x 37.8 mm ( 1.6 inch x 0.78inch x 1.49inch ) - 55.2 g( 1.95oz) - Dual Ball Bearing - Case material Engineering Plastic - Gear material 1 Metal + Plastic & 3 Metal - Gear train backlash Max 0.5˚ - Horn gear spline 24T(Ø6) - - - Weight Ball bearing IP rate Servo Amplifier type Analog Contorller - Features - Applications - ] 0 1 , 2 [ 4 , 3 5 ] 0 4 , 0 [ 2 , 0 1 ] 6 5 , 0 [ 2 , 4 1 ] 5 3 , 1 [ 2 , 4 3 3 4 1 2 ] 0 8 , 0 [ 8 , 9 1 ] 8 6 , 0 [ 3 , 7 1 ] 9 4 , 1 [ 8 , 7 3 ] 6 0 , 1 [ 7 2 ] 1 8 , 1 1 [ 0 0 3 ] 0 6 , 1 [ 6 , 0 4 1:1 scale (unit : mm) https://hitecnology.com
32645S 价格&库存
很抱歉,暂时无法提供与“32645S”相匹配的价格&库存,您可以联系我们找货
