HK-2P-MC1-A-36IN
HK-2P-MC1-A-36IN
    HRS(广濑)
    同轴电缆组件 2.92mm 至 2.92mm 36.00"(914.40mm)
HK-2P-MC1-A-36IN 数据手册
2.92mm coaxial connectors MIL Standard Compliant 2.92mm Series Compatible with 40GHz configurations Features 1. Compliant MIL-STD-348B Standard 2. Supports up to 40GHz frequency 3. Screw mounting Mar.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ・Provides excellent high frequency performance and consistent mounting quality ・Reusable ・Reduces mounting complexity (No Soldering is required) 4. Flexible PCB thickness 5. 0.085 inch flexible cable applicable 6. RoHS2 compliant Applications Data transmission measurement, Radio communication equipment, Measuring instruments, RF module, Radio power amplifier, High speed router, High speed switch etc. Functional diagram Plug side ■Straight plug Receptacle side ■Nonreflective terminator HK-P-SF085 ■Straight receptacle HK-R201 HK-R401 HK-TMP ■Plug receptacle HK-PR201 In-line Adapter ■Straight adapter ●PlugーJack  HK-A-PJ ●JackーJack  HK-A-JJ ●PlugーPlug  HK-A-PP ■PCB vertical launch receptacle (For high-speed test board applications.) HK-R-SR2-1 Attenuator ■Plug―Jack HK-AT (**)-PJ **:0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 20dB ■PCB end launch receptacle (For high-speed test board applications.) HK-LR-SR2 In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2019.4③ 1 2.92mm Series●2.92mm coaxial connectors MIL Standard Compliant Product Specifications Nominal characteristic impedance Ratings Rated frequency Items 50ø Operating Temperature Range -55ç to +105ç (95% RH or less) 0 to 40GHz Storage Temperature Range -55ç to +50ç (95% RH or less) Specifications Conditions 2. Insulation resistance Center : Not greater than 6mø External : Not greater than 2mø 1,000Mø min. 3. Withstanding voltage No flashover or breakdown 500V AC for one minute ●HK-P-SF085, HK-R-201/401 ●HK-R-SR2-1 4. Voltage standing wave ratio V.S.W.R. : Not greater than 1.15 (0 to 18GHz) V.S.W.R. : Not greater than 1.10 (0 to 18GHz) V.S.W.R. : Not greater than 1.20 (18GHz to 26.5GHz) V.S.W.R. : Not greater than 1.15 (18GHz to 26.5GHz) V.S.W.R. : Not greater than 1.35 (26.5GHz to 40GHz) V.S.W.R. : Not greater than 1.30 (26.5GHz to 40GHz) 1. Contact resistance Measured at 100mA or below Measured at 500V DC Mar.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Contact resistance at center : Not greater than 8mø External : Not greater than 4mø No broken, cracked, or loose parts No electrical discontinuity for not less than 1µs. 6. Vibration resistance No broken, cracked, or loose parts No electrical discontinuity for not less than 1µs. 7. Shock resistance No broken, cracked, or loose parts Insulation resistance : Not less than 100Mø 8. Moisture resistance of (in a high humidity environment) temperature/humidity Insulation resistance : Not less than 1,000Mø (in a dry environment) cycle No broken, cracked or loose parts 5. Mating Cycles 9. Temperature cycle No broken, cracked or loose parts 10. Salt spray No considerable corrosion ●HK-LR-SR2 V.S.W.R. : Not greater than 1.30 (0 to 40GHz) 500 cycles Frequency : 10 to 2000Hz, half amplitude : 0.75mm, Acceleration : 196m/s2, 10 cycles in each of the 3 axis Acceleration : 1960m/s2, duration : 6ms, Wave form : half-sine wave, 3 times in each of the 3 axis Left for 10 cycles (240 hours) in an environment with the temperature ranging from -10 to 65°C and the humidity ranging from 90 to 98%. 5 cycles of the following test series condition : Temperature : _55ç → _ → +105ç → _ Time : 30 min. → 3 min. → 30 min. → 3 min. Continuous 48 hour cycle in 5% salt water solution *Measurement of voltage standing wave ratio (V.S.W.R.) The specified values of the voltage standing wave ratio (V.S.W.R.) noted above, are taken with the test set up shown in the figure below: HK-P-SF085 measurement system HK-R-201/401 measurement system D.U.T details Network Analyzer D.U.T details HK-P-SF085 with double ended harness HK-R-SR2-1 measurement system (Back to Back) D.U.T HK-R201 Hermetic seal HK-LR-SR2 measurement system D.U.T details Test Port Cable HK-R-SR2-1 HK-PR201 D.U.T details HK-R-SR2-1 HK-LR-SR2 HK-LR-SR2 Test boards Materials / Finish Part Materials Finish Shell Stainless steel / Brass Passivated / Gold plating Insulator PPO / PTFE / PEI resin --------------- Contact Beryllium copper Gold plated Ring Stainless steel Gold plated Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. HK -「 」-「 」 ❶ ❷ ❶Series name : HK ❷Connector type P : Straight plug R : Receptacle PR : Plug receptacle A : Adapter 2 ❸ ❸Applicable cable or board mounting style SF085 : 0.085-inch, Flexible cable SR : PCB screw-mounting 2.92mm Series●2.92mm coaxial connectors MIL Standard Compliant Plug HK-P-SF085 10.8 8HEX Receptacle 5.8 9.6 12.2 Ø16 1.7 1/4-36UNS-2A 2ר2.6 Part No. HRS No. HK-R201 338-0073-1 *Compliant with hermetic seal of Ø0.3mm pin. 9.6 12.7 1.7 8.64 12.7 8.64 4ר2.6 1/4-36UNS-2A Part No. HRS No. HK-R401 338-0074-4 Plug-receptacle 6.6 13.2 12.2 1.7 1/4-36UNS-2B *Compliant with hermetic seal of Ø0.3mm pin. Ø16 Mar.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. [Please contact Hirose in case of cable assemblies.] 2ר2.6 Part No. HRS No. HK-PR201 338-0075-7 *Compliant with hermetic seal of Ø0.3mm pin. 3 2.92mm Series●2.92mm coaxial connectors MIL Standard Compliant PCB vertical mount receptacle This receptacle is designed for high speed test board applications. Not applicable to actual commercial equipments. 5.8 9.6 10 7.16 1.7 1/4-36UNS-2A 2×0-80UNF-2B Mar.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. HK-R-SR2-1 HK-R-SR2-1 (11) HK-R-SR2-1 (12) HRS No. 338-0003-0 338-0003-0 11 338-0003-0 12 Attached screw --------------0-80UNF 1/4 inch 0-80UNF 3/16 inch ◆Frequency characteristics (TYPICAL) *Signal line length between both connector ends : 25mm VSWR (S11) IL (S21) 0.0 1.9 -1.0 1.8 -2.0 1.7 -3.0 1.6 -4.0 1.5 -5.0 1.4 -6.0 1.3 -7.0 1.2 -8.0 1.1 -9.0 S[dB] VSWR 2.0 -10.0 1.0 0 5 10 15 20 25 Frequency [GHz] 30 35 40 PCB end launch receptacle Central contact solderless receptacles for high-speed test board applications. Not applicable to actual commercial equipments. 4 2×2.2 9.55 1/4-36UNS-2A 5 8.4 Part No. HK-LR-SR2 HK-LR-SR2 (11) HK-LR-SR2 (12) HRS No. 338-0079-0 338-0079-0 11 338-0079-0 12 Attached screw --------------0-80UNF 1/4 inch 0-80UNF 3/16 inch ◆Frequency characteristics (TYPICAL) *Coplaner line length between both connector ends : 20mm VSWR (S11) IL (S21) -1.0 1.8 -2.0 1.7 -3.0 1.6 -4.0 1.5 -5.0 1.4 -6.0 1.3 -7.0 1.2 -8.0 1.1 -9.0 -10.0 1.0 0 4 0.0 1.9 5 10 15 20 25 Frequency [GHz] 30 35 40 S[dB] VSWR 2.0 2×0-80UNF-2B 6.4 1.63 2.92mm Series●2.92mm coaxial connectors MIL Standard Compliant In-line Adapter ●Straight adapter (Plug ― Jack) 20.13 5.5HEX 8HEX Part No. HRS No. HK-A-PJ 338-0097-0 0-18GHz 1.1 V.S.W.R. (Max) 18-26.5GHz 1.15 26.5-40GHz 1.2 (Jack ― Jack) 19.36 5.5HEX 15.5 Part No. HRS No. HK-A-JJ 338-0098-0 0-18GHz 1.1 V.S.W.R. (Max) 18-26.5GHz 1.15 26.5-40GHz 1.2 (Plug ― Plug) 20.9 5.5HEX 8HEX 15.5 Part No. HRS No. HK-A-PP 338-0099-0 0-18GHz 1.1 V.S.W.R. (Max) 18-26.5GHz 1.15 26.5-40GHz 1.2 ◆Frequency characteristics (TYPICAL) 0.0 2.0 -0.1 1.9 VSWR (S11) 1.8 IL (S21) -0.2 1.7 -0.3 1.6 -0.4 1.5 -0.5 1.4 -0.6 1.3 -0.7 1.2 -0.8 1.1 -0.9 S[dB] VSWR Mar.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 15.5 -1.0 1.0 0 5 10 15 20 25 Frequency [GHz] 30 35 40 5 2.92mm Series●2.92mm coaxial connectors MIL Standard Compliant Nonreflective terminator Product Specifications Nominal characteristic impedance 50Ω Rated frequency 0 to 40GHz Power 0.5W CW (+75°C) Ratings Materials / Finish Mar.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part Shell Insulator Male contact Coupling Resistive element Operating Temperature Range Operating relative humidity -40°C to +85°C 95% RH or less Product Number Structure Materials Stainless steel PTFE Brass Stainless steel Metal film HK - TM P Finish Passivate ---Gold plated Passivate ---- ❶ ❷ ❸ ❶Series name HK ❷TM Non-reflective terminator ❸Connector type P : Plug type Part No. HRS No. HK-TMP 353-0014-0 0-10GHz 1.1 V.S.W.R. (Max) 10-20GHz 20-35GHz 1.15 1.18 Frequency characteristics (TYPICAL) 2.0 VSWR (S11) 1.9 1.8 1.7 VSWR 1.6 1.5 1.4 1.3 1.2 1.1 1.0 0 6 5 10 15 20 25 Frequency [GHz] 30 35 40 35-40GHz 1.28 6.6 5.1 8HEX 13.15 2.92mm Series●2.92mm coaxial connectors MIL Standard Compliant Attenuator Product Specifications Nominal characteristic impedance 50Ω Rated frequency 0 to 40GHz Power 1W CW (+65°C) Ratings Operating Temperature Range Operating relative humidity -10°C to +65°C 90% RH or less   Part Shell Insulator Male contact Female contact Coupling Resistive element Product Number Structure Materials Stainless steel PTFE resin Brass Beryllium coppoer Stainless steel Metal film HK - AT (ππ) - PJ Finish Passivate ---Gold plated Gold plated Passivate ---- ❶ ❷ ❸ ❶Series name ❹ HK ❷AT Attenuator (0) : 0dB (through) (例) (3) : 3dB ❸Attenuation (10) : 10dB PJ : Plug Jack ❹Connector type 24.15 8HEX Ø9 Mar.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Materials / Finish 1/4-36UNS-2A Part No. 1/4-36UNS-2B Attenuation (dB) HRS No. 0∼18GHz +0.4 0 18∼26.5GHz 0 26.5∼40GHz +0.5 0 0 +0.8 0 HK-AT(0)-PJ 354-0295-0 0 HK-AT(1)-PJ 354-0316-0 1 −+0.9 0.3 1 −+1.0 0.3 1 −+1.2 0.3 HK-AT(2)-PJ 354-0317-0 2 −+0.9 0.3 2 −+1.0 0.3 2 −+1.2 0.3 HK-AT(3)-PJ 354-0296-0 3 −+0.7 0.3 3 −+0.8 0.3 3 −+1.0 0.3 HK-AT(4)-PJ 354-0318-0 4 −+0.8 0.4 4 −+0.9 0.4 4 −+1.1 0.4 HK-AT(5)-PJ 354-0319-0 5 −+0.9 0.4 5 −+1.0 0.4 5 −+1.2 0.4 HK-AT(6)-PJ 354-0297-0 6 −+0.8 0.2 6 −+0.9 0.2 6 −+1.0 0.2 HK-AT(7)-PJ 354-0320-0 7 −+1.0 0.4 7 −+1.1 0.4 7 −+1.3 0.4 HK-AT(8)-PJ 354-0321-0 8 −+0.9 0.5 8 −+1.0 0.5 8 −+1.2 0.5 Voltage standing wave ratio (V.S.W.R.)(max) 0∼12GHz 12∼40GHz 1.35 1.4 1.3 1.35 1.45 1.4 1.3 HK-AT(9)-PJ 354-0322-0 9 −+0.9 0.5 9 −+1.0 0.5 9 −+1.2 0.5 HK-AT(10)-PJ 354-0298-0 10 −+0.9 0.5 10 −+1.0 0.5 10 −+1.2 0.5 HK-AT(20)-PJ 354-0299-0 20±1.0 20 −+1.2 1.0 20 −+1.4 1.0 1.45 1.25 1.4 7 2.92mm Series●2.92mm coaxial connectors MIL Standard Compliant Frequency characteristics (TYPICAL) 2 -1.5 1.9 -1.0 1.8 -1.0 1.8 -2.0 1.8 -1.5 1.7 -1.5 1.7 -2.5 1.7 -2.0 1.6 -2.0 1.6 -3.0 1.6 -2.5 1.5 -2.5 1.5 -3.5 1.5 -3.0 1.4 -3.0 1.4 -4.0 1.4 -3.5 1.3 -3.5 1.3 -4.5 1.3 -4.0 1.2 -4.0 1.2 -5.0 1.2 -4.5 1.1 -4.5 1.1 -5.5 1.1 10 15 20 25 30 35 ATTENUATION (dB) 0 5 10 FREQUENCY [GHz] 20 25 30 35 -6.0 0 5 10 FREQUENCY [GHz] S22 S11 HK-AT (3)-PJ 15 1 40 S12 S21 S21 S11 HK-AT (4)-PJ 15 20 25 30 35 1 40 FREQUENCY [GHz] S12 S22 S21 S11 HK-AT (5)-PJ S12 S22 -4.0 2 1.9 -4.5 1.9 -3.0 1.8 -4.0 1.8 -5.0 1.8 -3.5 1.7 -4.5 1.7 -5.5 1.7 -4.0 1.6 -5.0 1.6 -6.0 1.6 -4.5 1.5 -5.5 1.5 -6.5 1.5 -5.0 1.4 -6.0 1.4 -7.0 1.4 -5.5 1.3 -6.5 1.3 -7.5 1.3 -6.0 1.2 -7.0 1.2 -8.0 1.2 -6.5 1.1 -7.5 1.1 -8.5 1.1 -7.0 0 5 10 15 20 25 30 35 1 40 -8.0 0 5 10 FREQUENCY [GHz] 20 25 30 35 1 40 -9.0 0 5 10 FREQUENCY [GHz] S22 S11 HK-AT (6)-PJ 15 ATTENUATION (dB) 2 -3.5 V.S.W.R -3.0 1.9 ATTENUATION (dB) 2 -2.5 V.S.W.R -2.0 S12 S21 S21 S11 HK-AT (7)-PJ 15 20 25 30 35 1 40 FREQUENCY [GHz] S12 S22 S21 S11 HK-AT (8)-PJ S12 S22 2 -7.0 2 -6.5 1.9 -7.5 1.9 -6.0 1.8 -7.0 1.8 -8.0 1.8 -6.5 1.7 -7.5 1.7 -8.5 1.7 -7.0 1.6 -8.0 1.6 -9.0 1.6 -7.5 1.5 -8.5 1.5 -9.5 1.5 -8.0 1.4 -9.0 1.4 -10.0 1.4 -8.5 1.3 -9.5 1.3 -10.5 1.3 -9.0 1.2 -10.0 1.2 -11.0 1.2 -9.5 1.1 -10.5 1.1 -10.0 0 5 10 15 20 25 30 35 -11.0 1 40 0 5 10 20 25 30 35 1.1 -11.5 1 40 -12.0 0 5 10 FREQUENCY [GHz] FREQUENCY [GHz] S21 S11 HK-AT (9)-PJ 15 ATTENUATION (dB) -6.0 1.9 ATTENUATION (dB) 2 -5.5 V.S.W.R -5.0 V.S.W.R ATTENUATION (dB) V.S.W.R -5.0 S12 S22 15 20 25 30 35 1 40 FREQUENCY [GHz] S22 S11 HK-AT (10)-PJ S12 S21 S22 S11 HK-AT (20)-PJ S12 S21 2 -19.5 1.9 -9.0 1.8 -10.0 1.8 -20.0 1.8 -9.5 1.7 -10.5 1.7 -20.5 1.7 -10.0 1.6 -11.0 1.6 -21.0 1.6 -10.5 1.5 -11.5 1.5 -21.5 1.5 -11.0 1.4 -12.0 1.4 -22.0 1.4 -11.5 1.3 -12.5 1.3 -22.5 1.3 -12.0 1.2 -13.0 1.2 -23.0 1.2 -12.5 1.1 -13.5 1.1 0 5 10 15 20 25 30 FREQUENCY [GHz] 35 1 40 -14.0 0 5 10 15 20 25 FREQUENCY [GHz] 30 35 1 40 ATTENUATION (dB) -19.0 1.9 V.S.W.R 2 -9.5 ATTENUATION (dB) -9.0 1.9 V.S.W.R 2 -8.5 ATTENUATION (dB) -8.0 -13.0 V.S.W.R 5 1 40 V.S.W.R -1.0 1.9 0.0 ATTENUATION (dB) 2 -0.5 0 ATTENUATION (dB) S12 S22 1.9 -5.0 ATTENUATION (dB) S21 S11 HK-AT (2)-PJ V.S.W.R 2 S12 S22 -0.5 0.0 Mar.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. S21 S11 HK-AT (1)-PJ V.S.W.R S12 S21 V.S.W.R S22 S11 HK-AT (0)-PJ 1.1 -23.5 -24.0 0 5 10 15 20 25 30 35 1 40 FREQUENCY [GHz] Precautions 1. The diameter of the center contact pin is only 0.92mm.  Please handle with care. When mating the attenuator with the corresponding connector, rotate the hex part only. 2. When mating the attenuator, if any dust is found on the shell interface, please wipe with alcohol. ® 8 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 04/2019. Contents are subject to change without notice for the purpose of improvements.
HK-2P-MC1-A-36IN 价格&库存
很抱歉,暂时无法提供与“HK-2P-MC1-A-36IN”相匹配的价格&库存,您可以联系我们找货
HK-2P-MC1-A-36IN
  • 1+1550.116481+201.44159
  • 20+1254.8847720+163.07548
  • 40+1195.0715140+155.30259
  • 60+1168.4215760+151.83937
库存:36
