H2.4-TMP
H2.4-TMP
    HRS(广濑)
    同轴连接器 - 端接器 适配器,插头转插头 2.4mm(APC-2.4,OS-50) 50 Ohms
H2.4-TMP 数据手册
APPLICABLE STANDARD OPERATING TEMPERATURE RANGE May.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents. RATING MIL-STD-348B STORAGE TEMPERATURE RANGE CHARACTERISTIC IMPEDANCE APPLICABLE CABLE -40゚C TO +85゚C (95%RH MAX) 0.5 W CW (at 65゚C) POWER ― PECULIARITY -40゚C TO +85゚C (95%RH MAX) 50 Ω ( 0 TO 50 GHz ) ― SPECIFICATIONS ITEM TEST METHOD REQUIREMENTS QT AT X X X X MAX X X CONSTRUCTION GENERAL EXAMINATION VISUALLY AND BY MEASURING INSTRUMENT. MARKING CONFIRMED VISUALLY. ACCORDING TO DRAWING. ELECTRIC CHARACTERISTICS 1.2 VSWR FREQUENCY DC INSERTION LOSS MUST BE UNDER THE STD. VALUE AT FREQUENCY – TO - GHz TO 50 GHz - dB MAX - - CONTACT RESISTANCE - mA MAX (DC OR 1000 Hz). - mΩ MAX. - - INSULATION RESISTANCE - V DC. - MΩ MIN. - - RESISTANCE VALUE MEASURE THE RESISTANCE VALUE AT DC1V ±3% X X VOLTAGE PROOF - V AC FOR 1 min.CURRENT LEAKAGE 2mA MAX. NO FLASHOVER OR BREAKDOWN. - - 50 Ω MECHANICAL CHARACTERISTICS MECHANICAL OPERATION 500 TIMES INSERTIONS AND EXTRACTIONS. [APPLICABLE CONNECTOR : H2.4-R-SR2-1] 1) VSWR CHARACTERISTIC SHALL BE MET. 2) NO DAMAGE, CRACK AND LOOSENESS OF PARTS. X - VIBRATION FREQUENCY 10 TO 500 Hz SINGLE AMPLITUDE 0.75 mm, 98 m/s2 AT 10 CYCLES FOR 3 DIRECTIONS. 1) VSWR CHARACTERISTIC SHALL BE MET. 2) NO DAMAGE, CRACK AND LOOSENESS OF PARTS. X - SHOCK 490 m/s2 DIRECTIONS OF PULSE 11 ms AT 3 TIMES FOR 3 DIRECTIONS. X - CABLE CLAMP ROBUSTNESS (AGAINST CABLE PULL) USING A PULLING TESTER, PULL THE CABLE AXIALLY AT A RATE OF – mm/min. AND RECORD THE STRENGTH AT WHICH THE CABLE OR CONNECTOR BREAKS. - - 1) VSWR CHARACTERISTIC SHALL BE MET. 2) NO DAMAGE, CRACK AND LOOSENESS OF PARTS. X - - N MIN. ENVIRONMENTAL CHARACTERISTICS +40 ゚C, 90~95 % DAMP HEAT EXPOSED AT RAPID CHANGE OF TEMPERATURE TEMPERATURE –55 → - → +85 → - ゚C TIME 30 → 3 → 30 → 3 min. UNDER 5 CYCLES. 1) VSWR CHARACTERISTIC SHALL BE MET. 2) NO DAMAGE, CRACK AND LOOSENESS OF PARTS. X - CORROSION SALT MIST EXPOSED IN 5 % SALT WATER SPRAY FOR 48 h. VSWR CHARACTERISTIC SHALL BE MET. X - COUNT FOR 96 h DESCRIPTION OF REVISIONS DESIGNED CHECKED DATE 0 △ REMARK RoHS COMPLIANT Unless otherwise specified, refer to IEC 60512. Note QT:Qualification Test AT:Assurance Test X:Applicable Test APPROVED TS.NAKAGAWA 20210913 CHECKED AH.MIYAZAKI 20210910 DESIGNED TS.KANEKO 20210910 TS.KANEKO 20210910 DRAWN DRAWING NO. ELC-393908-00-00 SPECIFICATION SHEET PART NO. H2.4-TMP HIROSE ELECTRIC CO., LTD. CODE NO. CL0353-0174-0-00 0 △ 1/1
H2.4-TMP 价格&库存
很抱歉,暂时无法提供与“H2.4-TMP”相匹配的价格&库存,您可以联系我们找货
H2.4-TMP
  • 1+2859.055001+371.59095
  • 10+2430.6139110+315.90652
  • 25+2278.6660025+296.15788
库存:10
H2.4-TMP
