KN13C0.7-24DP-0.4V(800) 数据手册
New Product
Introduction
KN13C Series
Data Sheet
Click Here To Order
Sample Number:
US-KN13CSAMPLE-21
KN13C Series
0.4mm Pitch, 0.7mm Stacking Height, Board to FPC Connectors
FEATURES:
Space saving : 0.7mm stacking height, 2.5mm width
Robust design with metal solder tabs and ample housing thickness
Highly reliable 2-point contact design
Easy mating operation with clear tactile click and wide self
alignment range
◗ Wide vacuum pick & place area with 2.5mm width
◗ Solder wicking prevention and contact protection against dust
Highly Reliable Contact Design
Wide Vacuum Pick-up Area
PLUG
0.8m
m
Robust Design
Space Saving by Narrow Width
RECEPTACLE
PLUG
0.8m
m
RECEPTACLE
INSERT
CASE
INSERT
CASE
0.7
CONTACT
0.4
0.4
CONTACT
Space saving, yet sufficient vacuum pick & place area
Accepts universal vacuum pick & place nozzle.
1.35
2.0
METAL
FITTING
METAL
FITTING
2.45
2.5
Hirose Electric Co., LTD | www.hirose.com | US-KN13C-DS-21-341-1.0 | Issued March 2021
Long Effective Mating Length
Insertion Force Load Curve
0.15mm
Load (N)
Drastic
Drop
Clear Tactile
Click
Stroke(㎜)
0.15 mm long effective mating length provides
clear tactile and high contact reliability
Specifications
MATERIAL AND FINISH
Component
Material
Finish, Remarks
Housing
LCP *1
Black / UL94V-0
Contact
Phosphor bronze
Au plating over Nickel barrier
Metal fitting
Plug
Phosphor bronze
Receptacle
Phosphor bronze
* Note 1 : This product satisfies halogen free requirements defined as 900ppm maximum chlorine.
900ppm maximum bromine, and 1500ppm maximum total of chlorine and bromine.
PERFORMANCE CHARACTERISTICS
Rating Current
0.3A
Rating Voltage
50V AC
Operating Temperature*2
-40~+85 °C
Contact Resistance
100m
Voltage Proof
250V AC For 1Min
Insulation Resistance
100M
MAX
MIN (100V DC)
* Note 2 : Include the temperature rising by current flow.
For additional information please go to
https://www.hirose.com/product/series/KN13C
STAY CONNECTED
Specifications herein are subject to change without notice.
Contact Hirose for latest specifications, drawings, or availabilities.
KN13C0.7-24DP-0.4V(800) 价格&库存
很抱歉,暂时无法提供与“KN13C0.7-24DP-0.4V(800)”相匹配的价格&库存,您可以联系我们找货
